Questions about using an RT0 variable to approximate the gradient of a DGP0 variable
Hi everyone!
I want to use an RT0 variable to approximate the gradient of a DGP0 variable obtained from the mass-conservation equation.
The governing equations of \phi(\boldsymbol{x},t) and \boldsymbol{r}(\boldsymbol{x},t) are
\partial_{t} \phi+\nabla\cdot(\phi \boldsymbol{u})=0 in \Omega
\boldsymbol{r}=\nabla \phi in \Omega.
with boundary condition \nabla \phi\cdot \boldsymbol{n}=0 on \partial\Omega. Here \boldsymbol{u}(\boldsymbol{x},t) is the known velocity function used in the upwind operator.
We choose \phi\in DGP_{0} and \boldsymbol{r}\in RT_{0}, and use the upwind strategy: for any \psi\in DGP_{0} and \boldsymbol{s}\in RT_{0}, we have
step1: (\phi^{k+1}/\delta t, \psi)_{K}+(\phi^{k+1}_{upwind}(\boldsymbol{u}^{k}\cdot\boldsymbol{n}_{\partial K}), \psi)_{\partial K}=(\phi^{k}/\delta t, \psi)_{K}+(f_{source}^{k+1}, \psi)_{K},
​ where \phi^{k+1}_{upwind}=\phi^{k+1}|_{K^{+}} when \boldsymbol{u}^{k}\cdot\boldsymbol{n}_{\partial K}\geq 0, \phi^{k+1}_{upwind}=\phi^{k+1}|_{K^{-}} when \boldsymbol{u}^{k}\cdot\boldsymbol{n}_{\partial K}<0
step2: (\boldsymbol{r}^{k+1},\boldsymbol{s})_{K}=-(\phi^{k+1},\nabla\cdot\boldsymbol{s})_{K}+(\{\phi^{k+1} \boldsymbol{n}_{\partial K}\},[\boldsymbol{s}])_{\partial K}. with \boldsymbol{r}^{k+1}\cdot\boldsymbol{n}=0 on \partial\Omega.
The convergence order of \phi seems correct, but that of \boldsymbol{r} seems incorrect.
phi errors:
h        | phi_L2        order   | phi_Linf      order   | phi_H1        order
1/4      | 9.5643e-02            | 2.6140e-01            | 9.9982e-01
1/8      | 3.9099e-02    1.2905  | 1.3968e-01    0.9041  | 9.9966e-01    0.0002
1/16     | 1.7238e-02    1.1815  | 6.8275e-02    1.0327  | 9.9965e-01    0.0000
1/32     | 8.0085e-03    1.1060  | 3.3997e-02    1.0059  | 9.9965e-01    0.0000
r errors:
h        | r_L2          order   | r_Linf        order   | div r L2      order
1/4      | 5.6128e-01            | 1.2313e+00            | 6.5194e+00
1/8      | 4.6141e-01    0.2827  | 1.6404e+00    -0.4138 | 1.6878e+01    -1.3723
1/16     | 4.1555e-01    0.1510  | 2.0346e+00    -0.3108 | 3.6188e+01    -1.1004
1/32     | 3.9387e-01    0.0773  | 1.9944e+00    0.0288  | 7.3077e+01    -1.0139
At first, I suspected that the problem was caused by an incorrect implementation of \boldsymbol{r}.
Interestingly, when I replace the update of \phi with the interpolated exact solution, the computation of \boldsymbol{r} becomes correct.
  """update phi by exact solution"""
  # phi_now.interpolate(lambda x: phi_e_expr(x, t_now))
r errors:
1/4      | 2.2790e-01            | 5.6240e-01            | 1.3033e+00
1/8      | 1.1347e-01    1.0061  | 2.7839e-01    1.0145  | 6.2398e-01    1.0625
1/16     | 5.6680e-02    1.0014  | 1.3889e-01    1.0031  | 3.0516e-01    1.0320
1/32     | 2.8333e-02    1.0003  | 6.9408e-02    1.0008  | 1.5093e-01    1.0157
This might be a finite element theory issue, or it could be a problem with my implementation.
I would appreciate any insights or explanations!
Below is my code.
import sympy as sp
from dolfinx import mesh
from dolfinx.fem import (Function, functionspace, dirichletbc, assemble_scalar,
                        form, locate_dofs_topological, Constant)
from dolfinx.fem.petsc import assemble_matrix, assemble_vector, create_vector, apply_lifting, set_bc
from ufl import (CellDiameter, FacetNormal, TestFunction, TrialFunction, avg, jump,
                nabla_grad, nabla_div, conditional, dot, dS, ds, dx, gt, inner, outer)
if np.issubdtype(PETSc.ScalarType, np.complexfloating):
    print("Demo should only be executed with DOLFINx real mode")
    exit(0)
def norm_l2(comm, v):
    return np.sqrt(comm.allreduce(assemble_scalar(form(inner(v, v) * dx)), op=MPI.SUM))
def norm_h1(comm, v):
    return np.sqrt(comm.allreduce(assemble_scalar(form(inner(nabla_grad(v), nabla_grad(v)) * dx)), op=MPI.SUM))
def norm_linf_phi(comm, u_h, u_exact_func, t_final, high_degree=5):
    msh = u_h.function_space.mesh
    V_high = functionspace(msh, ("Lagrange", high_degree))
    u_h_high = Function(V_high)
    u_h_high.interpolate(u_h)
    u_exact_high = Function(V_high)
    u_exact_high.interpolate(lambda x: u_exact_func(x, t_final))
    local_max = np.max(np.abs(u_h_high.x.array - u_exact_high.x.array))
    return comm.allreduce(local_max, op=MPI.MAX)
def norm_linf_r(comm, u_h, u_exact_func, t_final, high_degree=5):
    gdim = msh.geometry.dim
    V_high = functionspace(msh, ("Lagrange", high_degree, (gdim,)))
# TODO: exact solution(sympy)
sp_x, sp_y = sp.symbols('x y')
sp_t = sp.symbols('t')
"""variable"""
phi_sp = sp.cos(sp.pi * sp_t) * sp.cos(sp.pi * sp_x) * sp.cos(sp.pi * sp_y) * 0.45 + 0.5
u_sp = sp.Matrix([sp.cos(sp.pi * sp_t) * sp.sin(sp.pi * sp_x) * sp.sin(2 * sp.pi * sp_y),
                -sp.cos(sp.pi * sp_t) * sp.sin(sp.pi * sp_y) * sp.sin(2 * sp.pi * sp_x)])
r_sp = sp.Matrix([sp.diff(phi_sp, sp_x),
                sp.diff(phi_sp, sp_y)])
div_r_sp = sp.diff(r_sp[0], sp_x) + sp.diff(r_sp[1], sp_y)
_phi_e_expr = sp.lambdify((sp_x, sp_y, sp_t), phi_sp, 'numpy')
_u_e_expr = sp.lambdify((sp_x, sp_y, sp_t), u_sp, 'numpy')
_r_e_expr = sp.lambdify((sp_x, sp_y, sp_t), r_sp, 'numpy')
_div_r_e_expr = sp.lambdify((sp_x, sp_y, sp_t), div_r_sp, 'numpy')
"""mass eq"""
phi_u_sp = phi_sp * u_sp
rhs_phi_sp = sp.diff(phi_sp, sp_t) + sp.diff(phi_u_sp[0], sp_x) + sp.diff(phi_u_sp[1], sp_y)
_f_phi_expr = sp.lambdify((sp_x, sp_y, sp_t), rhs_phi_sp, 'numpy')
def phi_e_expr(x, t):
    return _phi_e_expr(x[0], x[1], t)
def r_e_expr(x, t):
    vals = _r_e_expr(x[0], x[1], t)
    return np.array(vals).reshape(2, -1) if len(x.shape) > 1 else np.array(vals).flatten()
def div_r_e_expr(x, t):
    return _div_r_e_expr(x[0], x[1], t)
def u_e_expr(x, t):
    vals = _u_e_expr(x[0], x[1], t)
def f_phi_expr(x, t):
    return _f_phi_expr(x[0], x[1], t)
def boundary_marker(x):
    return np.isclose(x[0], 0.0) | np.isclose(x[0], 1.0) | np.isclose(x[1], 0.0) | np.isclose(x[1], 1.0)
left, right = 0, 1
bottom, top = 0, 1
t_final = 1
degree_phi = 0
degree_u = 1
mesh_i = np.array([4, 8, 16, 32])
mesh_j = mesh_i
mesh_t = (mesh_i**2).astype(int)
max_iter = np.size(mesh_i)
error_phi = np.zeros([max_iter, 3])
error_r = np.zeros([max_iter, 3])
for it in range(max_iter):
    msh = mesh.create_rectangle(
        comm=MPI.COMM_WORLD,
        points=((left, bottom), (right, top)),
        n=(mesh_i[it], mesh_j[it]),
        cell_type=mesh.CellType.triangle,
# TODO: finite element space
    P = functionspace(msh, ("Discontinuous Lagrange", degree_phi))
    phi, psi = TrialFunction(P), TestFunction(P)
    Q = functionspace(msh, ("Discontinuous Lagrange", degree_phi + 1))
    K = functionspace(msh, ("Raviart-Thomas", degree_u))
    r, s = TrialFunction(K), TestFunction(K)
    # V = functionspace(msh, ("Brezzi-Douglas-Marini", degree_u))
    V = functionspace(msh, ("Raviart-Thomas", degree_u + 1))
    n = FacetNormal(msh)
    nt = mesh_t[it]
    dt = Constant(msh, t_final / nt)
    t_now = 0.0
    mass_err = np.zeros(nt)
    momentum_err = np.zeros(nt)
    fdim = msh.topology.dim - 1
    boundary_facets = mesh.locate_entities_boundary(msh, fdim, boundary_marker)
    r_D = Function(K)
    r_D.interpolate(lambda x: r_e_expr(x, t_now))
    boundary_vel_dofs_K = locate_dofs_topological(K, fdim, boundary_facets)
    bc_r = dirichletbc(r_D, boundary_vel_dofs_K)
    bcs_r = [bc_r]
    r_now = Function(K)
    f_phi = Function(Q)
    f_phi.interpolate(lambda x: f_phi_expr(x, t_now))
    phi_old = Function(P)
    phi_now = Function(P)
    u_old = Function(V)
    u_now = Function(V)
    u_now.interpolate(lambda x: u_e_expr(x, t_now))
    """lmbda = 1 (u_old dot n > 0); lmbda = 0 (u_old dot n <= 0)"""
    lmbda = conditional(gt(dot(u_old, n), 0), 1, 0)
    phi_uw = lmbda("+") * phi("+") + lmbda("-") * phi("-") # upwind
# TODO: mass equation
    a_phi = form(
        inner(phi / dt, psi) * dx
        # convective terms
        + inner((dot(u_old, n))("+") * phi_uw, psi("+")) * dS
        + inner((dot(u_old, n))("-") * phi_uw, psi("-")) * dS
    L_phi = form(
        inner(phi_old / dt, psi) * dx
        + inner(f_phi, psi) * dx
# TODO: grad phi
    a_r = form(
        inner(r, s) * dx
    L_r = form(
        - inner(phi_now, nabla_div(s)) * dx
        + inner(avg(phi_now * n), jump(s)) * dS
    A_phi = assemble_matrix(a_phi, [])
    A_phi.assemble()
    b_phi = create_vector(L_phi)
    A_r = assemble_matrix(a_r, bcs_r)
    A_r.assemble()
    b_r = create_vector(L_r)
    solver_phi = PETSc.KSP().create(msh.comm)
    solver_phi.setOperators(A_phi)
    solver_phi.setType(PETSc.KSP.Type.PREONLY)
    solver_phi.getPC().setType(PETSc.PC.Type.LU)
    solver_r = PETSc.KSP().create(msh.comm)
    solver_r.setOperators(A_r)
    solver_r.setType(PETSc.KSP.Type.PREONLY)
    solver_r.getPC().setType(PETSc.PC.Type.LU)
    phi_h = Function(P)
    r_h = Function(K)
# TODO: time looping
    for jt in range(nt):
        t_now += dt.value
        phi_old.x.array[:] = phi_now.x.array
        phi_old.x.scatter_forward()
        u_old.x.array[:] = u_now.x.array
        u_old.x.scatter_forward()
# TODO: solve phi
        A_phi.zeroEntries()
        assemble_matrix(A_phi, a_phi, [])
        A_phi.assemble()
        with b_phi.localForm() as loc_b_phi:
            loc_b_phi.set(0)
        assemble_vector(b_phi, L_phi)
        apply_lifting(b_phi, [a_phi], [[]])
        b_phi.ghostUpdate(addv=PETSc.InsertMode.ADD_VALUES, mode=PETSc.ScatterMode.REVERSE)
        solver_phi.solve(b_phi, phi_h.x.petsc_vec)
        phi_h.x.scatter_forward()
        phi_now.x.array[:] = phi_h.x.array
        phi_now.x.scatter_forward()
# TODO: solve grad phi
        bcs_r = [bc_r]
        A_r.zeroEntries()
        assemble_matrix(A_r, a_r, bcs_r)
        A_r.assemble()
        with b_r.localForm() as loc_b_r:
            loc_b_r.set(0)
        assemble_vector(b_r, L_r)
        apply_lifting(b_r, [a_r], [bcs_r])
        b_r.ghostUpdate(addv=PETSc.InsertMode.ADD_VALUES, mode=PETSc.ScatterMode.REVERSE)
        set_bc(b_r, bcs_r)
        solver_r.solve(b_r, r_h.x.petsc_vec)
        r_h.x.scatter_forward()
        r_now.x.array[:] = r_h.x.array
        r_now.x.scatter_forward()
# TODO: update u
        if msh.comm.rank == 0:
            print('h = 1/%d, step = %d, t = %.4f' % (mesh_i[it], (jt + 1), t_now,))
    P_e = functionspace(msh, ("Lagrange", degree_phi + 3))
    V_e = functionspace(msh, ("Lagrange", degree_u + 3, (gdim,)))
    phi_e = Function(P_e)
    phi_e.interpolate(lambda x: phi_e_expr(x, t_now))
    error_phi[it, 0] = norm_l2(msh.comm, phi_now - phi_e)
    error_phi[it, 1] = norm_linf_phi(msh.comm, phi_now, phi_e_expr, t_now)
    error_phi[it, 2] = norm_h1(msh.comm, phi_now - phi_e)
    r_e = Function(V_e)
    r_e.interpolate(lambda x: r_e_expr(x, t_now))
    div_r_e = Function(P_e)
    div_r_e.interpolate(lambda x: div_r_e_expr(x, t_now))
    error_r[it, 0] = norm_l2(msh.comm, r_now - r_e)
    error_r[it, 1] = norm_linf_r(msh.comm, r_now, r_e_expr, t_now)
    error_r[it, 2] = norm_l2(msh.comm, nabla_div(r_now) - div_r_e)
    print("phi errors:")
    print(f"{'h':<8} | {'phi_L2':<13} {'order':<7} | {'phi_Linf':<13} {'order':<7} | {'phi_H1':<13} {'order':<7}")
    print('-'*80)
    for i in range(max_iter):
        h_str = f"1/{mesh_i[i]}"
        phi_l2, phi_linf, phi_h1 = error_phi[i, :]
        if i == 0:
            print(f"{h_str:<8} | {phi_l2:<13.4e} {'':<7} | {phi_linf:<13.4e} {'':<7} | {phi_h1:<13.4e} {'':<7}")
            phi_order_l2   = np.log(error_phi[i - 1, 0] / phi_l2)   / np.log(2)
            phi_order_linf = np.log(error_phi[i - 1, 1] / phi_linf) / np.log(2)
            phi_order_h1   = np.log(error_phi[i - 1, 2] / phi_h1)   / np.log(2)
            print(f"{h_str:<8} | {phi_l2:<13.4e} {phi_order_l2:<7.4f} | {phi_linf:<13.4e} {phi_order_linf:<7.4f} | {phi_h1:<13.4e} {phi_order_h1:<7.4f}")
    print("r errors:")
    print(f"{'h':<8} | {'r_L2':<13} {'order':<7} | {'r_Linf':<13} {'order':<7} | {'div r L2':<13} {'order':<7}")
    print('-'*80)
        r_l2, r_linf, div_r = error_r[i, :]
        if i == 0:
            print(f"{h_str:<8} | {r_l2:<13.4e} {'':<7} | {r_linf:<13.4e} {'':<7} | {div_r:<13.4e} {'':<7}")
            r_order_l2    = np.log(error_r[i - 1, 0] / r_l2)   / np.log(2)
            r_order_linf  = np.log(error_r[i - 1, 1] / r_linf) / np.log(2)
            div_r_order   = np.log(error_r[i - 1, 2] / div_r)  / np.log(2)
            print(f"{h_str:<8} | {r_l2:<13.4e} {r_order_l2:<7.4f} | {r_linf:<13.4e} {r_order_linf:<7.4f} | {div_r:<13.4e} {div_r_order:<7.4f}")
Hi everyone!
After some debugging, I found that \boldsymbol{r} gradually becomes incorrect as the time step increases.
Currently, I suspect that this might be caused by an error in computing \phi.
Below are the results obtained for setting nt = 1 and nt = 10.
nt = 1
phi errors:
1/4      | 5.8397e-02            | 2.2551e-01            | 9.8061e-01
1/8      | 2.9402e-02    0.9900  | 1.1790e-01    0.9357  | 9.9846e-01    -0.0260
1/16     | 1.4723e-02    0.9978  | 5.9136e-02    0.9954  | 9.9957e-01    -0.0016
1/32     | 7.3632e-03    0.9997  | 2.9495e-02    1.0036  | 9.9964e-01    -0.0001
r errors:
1/4      | 2.9484e-01            | 7.7164e-01            | 3.2633e+00
1/8      | 1.4937e-01    0.9810  | 4.8913e-01    0.6577  | 4.1180e+00    -0.3356
1/16     | 7.7315e-02    0.9501  | 2.6948e-01    0.8601  | 4.8828e+00    -0.2458
1/32     | 3.9865e-02    0.9556  | 1.4389e-01    0.9052  | 5.3254e+00    -0.1252
nt = 10
phi errors:
1/4      | 4.7042e-02            | 1.5648e-01            | 3.8261e-01
1/8      | 3.1539e-02    0.5768  | 1.1622e-01    0.4291  | 8.8162e-01    -1.2043
1/16     | 1.5063e-02    1.0662  | 6.2545e-02    0.8939  | 9.9213e-01    -0.1704
1/32     | 7.4292e-03    1.0197  | 3.0157e-02    1.0524  | 9.9918e-01    -0.0102
r errors:
1/4      | 4.3301e-01            | 1.5002e+00            | 6.0309e+00
1/8      | 3.8688e-01    0.1625  | 1.2543e+00    0.2582  | 1.4680e+01    -1.2834
1/16     | 2.8113e-01    0.4607  | 9.2467e-01    0.4399  | 2.5550e+01    -0.7994
1/32     | 1.9270e-01    0.5448  | 6.6103e-01    0.4842  | 3.6354e+01    -0.5088
