Hello, everyone:
The purpose of this post is to discuss the following problem: When solving multiphysics field equations, suppose we have two domains - Domain F is a rectangle [0.0, 1.0]×[0.0, 1.0] and Domain S is [0.0, 1.0]×[-1.0, 0.0] (with non-conforming mesh), sharing a common interface [0.0, 1.0]×[0.0, 0.0].
I need to use a function u_s (the solution of a PDE solved on Domain S, a finite element function) in the equations for Domain F. I’m considering two approaches:
Method A: Define a function u_f1 on Domain F by extrapolating u_s to u_f1.
Method B: Define u_f2 on Domain F by assigning u_s as Dirichlet boundary condition for u_f2.
My question is: Are there any essential differences between these two approaches?
import mshr
domain_f = mshr.Rectangle(Point(0.0, 0.0), Point(1.0, 1.0))
domain_s = mshr.Rectangle(Point(0.0, -1.0), Point(1.0, 0.0))
mesh_f = mshr.generate_mesh(domain_f, 30)
mesh_s = mshr.generate_mesh(domain_s, 50)
# mark boundary
class BottomBoundary_f(SubDomain):
return on_boundary and near(x[1], 0.0)
class RightBoundary_f(SubDomain):
return on_boundary and near(x[0], 1.0)
class TopBoundary_f(SubDomain):
return on_boundary and near(x[1], 1.0)
class LeftBoundary_f(SubDomain):
return on_boundary and near(x[0], 0.0)
bottom_f = BottomBoundary_f()
right_f = RightBoundary_f()
top_f = TopBoundary_f()
left_f = LeftBoundary_f()
bmf_f = MeshFunction("size_t", mesh_f, mesh_f.topology().dim() - 1)
bmf_f.set_all(0)
bottom_f.mark(bmf_f, 1)
right_f.mark(bmf_f, 2)
top_f.mark(bmf_f, 3)
left_f.mark(bmf_f, 4)
ds_f = Measure("ds", domain=mesh_f, subdomain_data=bmf_f)
class BottomBoundary_s(SubDomain):
return on_boundary and near(x[1], -1.0)
class RightBoundary_s(SubDomain):
class TopBoundary_s(SubDomain):
class LeftBoundary_s(SubDomain):
bottom_s = BottomBoundary_s()
right_s = RightBoundary_s()
top_s = TopBoundary_s()
left_s = LeftBoundary_s()
bmf_s = MeshFunction("size_t", mesh_s, mesh_s.topology().dim() - 1)
bmf_s.set_all(0)
bottom_s.mark(bmf_s, 1)
right_s.mark(bmf_s, 2)
top_s.mark(bmf_s, 3)
left_s.mark(bmf_s, 4)
ds_s = Measure("ds", domain=mesh_s, subdomain_data=bmf_s)
# Function Expression
func01 = Expression(('100*sin(x[0]) + 100*sin(x[1]) + 3.0', '100*x[0]*x[0] + 100*x[1]*x[1] + 3.0'), degree = 5)
V_f = VectorFunctionSpace(mesh_f, "CG", 2)
u_f01 = Function(V_f)
u_f02 = Function(V_f)
V_s = VectorFunctionSpace(mesh_s, "CG", 2)
u_s01 = Function(V_s)
u_s02 = Function(V_s)
u_s01.interpolate(func01)
u_s02.interpolate(func01)
u_s01.set_allow_extrapolation(True)
u_s02.set_allow_extrapolation(True)
u_f01.set_allow_extrapolation(True)
u_f02.set_allow_extrapolation(True)
# Mathod A
u_f01.interpolate(u_s01)
# Mathod B
B_f02 = DirichletBC(V_f, u_s02, bmf_f, 1)
B_f02.apply(u_f02.vector())
# int on ds(1)
print("u_f01*ds(1):", assemble(dot(u_f01, u_f01)*ds_f(1)))
print("u_f02*ds(1):", assemble(dot(u_f02, u_f02)*ds_f(1)))
# vector on ds(1)
v_f = TestFunction(V_f)
v_s = TestFunction(V_s)
form_f01 = assemble(dot(u_s01, v_f)*ds_f(1)).get_local()
form_f02 = assemble(dot(u_f02, v_f)*ds_f(1)).get_local()
bool01 = form_f01 == form_f02
for a01 in bool01:
if a01:
continue
print(a01)
error = form_f01 - form_f02
print("error:", np.linalg.norm(error, ord = 2))
print("----done---"
The motivation behind my question stems from solving a complex fluid-structure interaction problem, where I observed that when using Method A, the solution fails to converge, whereas Method B yields convergent results.
Additionally, this raises a broader question regarding multiphysics simulations: What are the recommended approaches when one needs to use functions defined on domain B (with non-matching grids) in computations for domain A?
I would be truly grateful if anyone could provide professional advice or suggestions on this matter.
