Good evening,
I cannot install RBniCSx.
After I run
git clone https://github.com/RBniCS/RBniCSx
cd RBniCSx
python3 -m pip install .
I get the following error:
Processing /mnt/c/RBniCSx
Installing build dependencies ... error
error: subprocess-exited-with-error
× pip subprocess to install build dependencies did not run successfully.
│ exit code: 1
╰─> [88 lines of output]
Collecting nanobind>=1.8.0
Using cached nanobind-1.9.2-py3-none-any.whl.metadata (1.4 kB)
Collecting petsc4py
Using cached petsc4py-3.21.0.tar.gz (415 kB)
Preparing metadata (setup.py): started
Preparing metadata (setup.py): finished with status 'done'
Collecting scikit-build-core[pyproject]
Using cached scikit_build_core-0.8.2-py3-none-any.whl.metadata (19 kB)
Collecting numpy (from petsc4py)
Using cached numpy-1.26.4-cp312-cp312-manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (61 kB)
Collecting petsc<3.22,>=3.21 (from petsc4py)
Using cached petsc-3.21.0.tar.gz (17.3 MB)
Collecting packaging>=20.9 (from scikit-build-core[pyproject])
Using cached packaging-24.0-py3-none-any.whl.metadata (3.2 kB)
Collecting pathspec>=0.10.1 (from scikit-build-core[pyproject])
Using cached pathspec-0.12.1-py3-none-any.whl.metadata (21 kB)
Collecting pyproject-metadata>=0.5 (from scikit-build-core[pyproject])
Using cached pyproject_metadata-0.7.1-py3-none-any.whl.metadata (3.0 kB)
Using cached nanobind-1.9.2-py3-none-any.whl (192 kB)
Using cached packaging-24.0-py3-none-any.whl (53 kB)
Using cached pathspec-0.12.1-py3-none-any.whl (31 kB)
Using cached pyproject_metadata-0.7.1-py3-none-any.whl (7.4 kB)
Using cached numpy-1.26.4-cp312-cp312-manylinux_2_17_x86_64.manylinux2014_x86_64.whl (18.0 MB)
Using cached scikit_build_core-0.8.2-py3-none-any.whl (140 kB)
Building wheels for collected packages: petsc4py, petsc
Building wheel for petsc4py (setup.py): started
Building wheel for petsc4py (setup.py): finished with status 'error'
× python setup.py bdist_wheel did not run successfully.
│ exit code: 1
╰─> [34 lines of output]
running bdist_wheel
PETSC_DIR not specified
running build
running build_src
fetching build requirement 'Cython >= 3.0.0'
using Cython 3.0.10
cythonizing 'petsc4py/PETSc.pyx' -> 'petsc4py/PETSc.c'
running build_py
creating build
creating build/lib.linux-x86_64-cpython-312
creating build/lib.linux-x86_64-cpython-312/petsc4py
copying src/petsc4py/__main__.py -> build/lib.linux-x86_64-cpython-312/petsc4py
copying src/petsc4py/typing.py -> build/lib.linux-x86_64-cpython-312/petsc4py
copying src/petsc4py/PETSc.py -> build/lib.linux-x86_64-cpython-312/petsc4py
copying src/petsc4py/__init__.py -> build/lib.linux-x86_64-cpython-312/petsc4py
creating build/lib.linux-x86_64-cpython-312/petsc4py/lib
copying src/petsc4py/lib/__init__.py -> build/lib.linux-x86_64-cpython-312/petsc4py/lib
copying src/petsc4py/__main__.pyi -> build/lib.linux-x86_64-cpython-312/petsc4py
copying src/petsc4py/__init__.pyi -> build/lib.linux-x86_64-cpython-312/petsc4py
copying src/petsc4py/py.typed -> build/lib.linux-x86_64-cpython-312/petsc4py
copying src/petsc4py/PETSc.pxd -> build/lib.linux-x86_64-cpython-312/petsc4py
copying src/petsc4py/PETSc.h -> build/lib.linux-x86_64-cpython-312/petsc4py
copying src/petsc4py/PETSc_api.h -> build/lib.linux-x86_64-cpython-312/petsc4py
creating build/lib.linux-x86_64-cpython-312/petsc4py/include
creating build/lib.linux-x86_64-cpython-312/petsc4py/include/petsc4py
copying src/petsc4py/include/petsc4py/numpy.h -> build/lib.linux-x86_64-cpython-312/petsc4py/include/petsc4py
copying src/petsc4py/include/petsc4py/pyscalar.h -> build/lib.linux-x86_64-cpython-312/petsc4py/include/petsc4py
copying src/petsc4py/include/petsc4py/pybuffer.h -> build/lib.linux-x86_64-cpython-312/petsc4py/include/petsc4py
copying src/petsc4py/include/petsc4py/petsc4py.h -> build/lib.linux-x86_64-cpython-312/petsc4py/include/petsc4py
copying src/petsc4py/include/petsc4py/petsc4py.i -> build/lib.linux-x86_64-cpython-312/petsc4py/include/petsc4py
copying src/petsc4py/lib/__init__.pyi -> build/lib.linux-x86_64-cpython-312/petsc4py/lib
copying src/petsc4py/lib/petsc.cfg -> build/lib.linux-x86_64-cpython-312/petsc4py/lib
running build_ext
error: PETSc not found
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed building wheel for petsc4py
Running setup.py clean for petsc4py
Building wheel for petsc (setup.py): started
Building wheel for petsc (setup.py): finished with status 'error'
│ exit code: 1
╰─> [1 lines of output]
petsc: this package cannot be built as a wheel
[end of output]
Failed to build petsc4py petsc
ERROR: Could not build wheels for petsc4py, petsc, which is required to install pyproject.toml-based projects
[end of output]
│ exit code: 1
╰─> See above for output.
I can see the problem is related to petsc and petsc4py.
When I run
pip install petsc4py
I get
Requirement already satisfied: petsc4py in /home/carlo/anaconda3/envs/fenicsx-env/lib/python3.12/site-packages (3.20.4)
Requirement already satisfied: numpy in /home/carlo/anaconda3/envs/fenicsx-env/lib/python3.12/site-packages (from petsc4py) (1.26.3)
However, when I try to run
pip install petsc
I get
Collecting petsc
Preparing metadata (setup.py) ... done
Building wheel for petsc (setup.py) ... error
│ exit code: 1
[end of output]
ERROR: Could not build wheels for petsc, which is required to install pyproject.toml-based projects
Indeed I installed petsc through
conda install -c conda-forge petsc
And everything seems to work fine, indeed I get:
Channels:
- conda-forge
- defaults
Platform: linux-64
Collecting package metadata (repodata.json): done
Solving environment: done
# All requested packages already installed.
I cannot understand what is the problem related to petsc, and therefore with the installation of RBniCSx.
Thank you for your help.
