Reading xdmf file from FEniCSx with python is not working
Thank you Dr. Dokken for your reply.
I am trying to approximate the following system of PDEs (with m and T are the unknowns functions).
\dfrac{\partial {m}}{\partial t} \ = \ a_m \Delta m + a_m \nu \Delta T \ , \hspace{1cm} in \ \Omega \times [0, tf] \hspace{4cm} \textbf{(1)}
c \rho_{0} \dfrac{\partial {T}}{\partial t} \ = k \Delta T + R \epsilon \dfrac{\partial {m}}{\partial t} \ , \hspace{1cm} in \ \Omega \times [0, tf] \hspace{4.2cm} \textbf{(2)}
with initial conditions m(x, y, 0) = 0.30 and T(x, y, 0) = 10.
The boundary boundary conditions are:
m(x=1, y, t) = 0.12, m(x, y=1, t), T(x=1, y, t) = 60 and T(x, y=1, t) = 60.
To do so, I am following this tutorial Test problem 1: Channel flow (Poiseuille flow) — FEniCSx tutorial, using a mixed space element as in Solving Stokes equation with NewtonSolver - #4 by dokken and https://fenicsproject.org/olddocs/dolfin/latest/python/demos/cahn-hilliard/demo_cahn-hilliard.py.html.
Here is the implementation of the mesh, mixed element, boundary conditions and initial conditions, variational formulation. Using a NonProblem solver, it converges in two iterations.
import os
from dolfinx.io import VTXWriter
import math
from math import sqrt
# For plotting
from dolfinx.fem import (Constant, dirichletbc, Function, FunctionSpace, assemble_scalar,
                         form, locate_dofs_geometrical, locate_dofs_topological, set_bc)
from dolfinx import log, plot
#from dolfinx.plot import vtk_mesh
from dolfinx.fem import Function, FunctionSpace
from dolfinx.fem.petsc import NonlinearProblem, LinearProblem
from dolfinx.io import XDMFFile, VTXWriter
from dolfinx.mesh import CellType, create_rectangle, locate_entities_boundary
from dolfinx.nls.petsc import NewtonSolver
from ufl import dx, grad, inner, TrialFunction, derivative, dot
from dolfinx import fem, io, mesh, plot
from petsc4py.PETSc import ScalarType
import math
try:
    import pyvista as pv
    import pyvistaqt as pvqt
    have_pyvista = True
    if pv.OFF_SCREEN:
        pv.start_xvfb(wait=0.5)
except ModuleNotFoundError:
    print("pyvista and pyvistaqt are required to visualise the solution")
    have_pyvista = False
# Save all logging to file
log.set_output_file("log.txt")
print(f"DOLFINx version: {dolfinx.__version__} based on GIT commit: {dolfinx.git_commit_hash} of https://github.com/FEniCS/dolfinx/")
#lx = 1.0  #length of x-axis
# parmeters
r_0 = 0
r_b = 1  # the coordinate of right boundary
# Define mesh            #nums =  [8, 16, 32,64,128,255] number of cells
nx, ny = 15, 15
msh = mesh.create_rectangle(MPI.COMM_WORLD, [np.array([r_0, r_0]), np.array([r_b, r_b])],
                               [nx, ny], mesh.CellType.quadrilateral)
#### Parameters : time and load and material ######
am = fem.Constant(msh, ScalarType(3.e-06 ))
k = fem.Constant(msh, ScalarType(0.12))
c = fem.Constant(msh, ScalarType(1284.))
rho_0 = fem.Constant(msh, ScalarType(500.))
R = fem.Constant(msh, ScalarType(2400.))
alpha = k/(c*rho_0)
beta = R/(c*rho_0)
epsilon = fem.Constant(msh, ScalarType(0.1))
nu = fem.Constant(msh, ScalarType(1.e-02))
## Time parametrization
t         = 0                # Start time
Tf        = 10.            # End time
num_steps = 100    # Number of time steps
dt = (Tf-t)/num_steps # Time step size
########## Mixed Space of resolution ##############
# Define ME function space
# Lagrange" is type of the finite element, and 1 is the degree
m1 = ufl.FiniteElement("Lagrange", msh.ufl_cell(), 1)
T1 = ufl.FiniteElement("Lagrange", msh.ufl_cell(), 1)
ME = FunctionSpace(msh, m1 * T1)
#Q = FunctionSpace(msh, m1) #ME.sub(0)
#V = FunctionSpace(msh, T1) #ME.sub(1)
# Create the initial and solution functions of space
u = Function(ME)  # current solution
u_n = Function(ME)  # solution from previous converged step (i.e., initial solution)
#du = TrialFunction(ME)
#We create four python functions for determining the facets to apply boundary conditions to
def right(x):
    return np.isclose(x[0], r_b)  #right (x = 0.1)
def top(x):
    return np.isclose(x[1], r_b)  #top (y = 0.1)
######## Dirichlet boundary conditions #############
boundary_facets_right = locate_entities_boundary(msh, msh.topology.dim - 1, right)
boundary_dofs_right = locate_dofs_topological(ME.sub(0), msh.topology.dim - 1, boundary_facets_right)
bc_m_right = dirichletbc(PETSc.ScalarType(0.12), boundary_dofs_right, ME.sub(0))
boundary_facets_top = locate_entities_boundary(msh, msh.topology.dim - 1, top)
boundary_dofs_top = locate_dofs_topological(ME.sub(0), msh.topology.dim - 1, boundary_facets_top)
bc_m_top = dirichletbc(PETSc.ScalarType(0.12), boundary_dofs_top, ME.sub(0))
boundary_dofs_right = locate_dofs_topological(ME.sub(1), msh.topology.dim - 1, boundary_facets_right)
bc_T_right = dirichletbc(PETSc.ScalarType(60.), boundary_dofs_right, ME.sub(1))
boundary_dofs_top = locate_dofs_topological(ME.sub(1), msh.topology.dim - 1, boundary_facets_top)
bc_T_top = dirichletbc(PETSc.ScalarType(60.), boundary_dofs_top, ME.sub(1))
bcs = [bc_m_right, bc_m_top, bc_T_right, bc_T_top]  #dirichlet boundary conditions
############## Initial Values #####################
Mi = 0.30 #Initial moisture content
M_n_, M_n_to_ME = ME.sub(0).collapse()
FM_n_ = Function(M_n_)
with FM_n_.vector.localForm() as initial_local:
	initial_local.set(ScalarType(Mi))
# # Re assign in u_n
u_n.x.array[M_n_to_ME] = FM_n_.x.array
u_n.x.scatter_forward()
Ti = 10. #Initial temperature content
T_n_, T_n_to_ME = ME.sub(1).collapse()
FT_n_ = Function(T_n_)
with FT_n_.vector.localForm() as initial_local:
	initial_local.set(ScalarType(Ti))
u_n.x.array[T_n_to_ME] = FT_n_.x.array
# Identify the unknowns from the function
# Split mixed functions
m, T = ufl.split(u)
m_n, T_n = ufl.split(u_n)
# Set up the test functions (q, v)
q, v = ufl.TestFunctions(ME)
############## Variationnal form ##################
#Variational formulation of the system
F0 = inner(m, q) * dx - inner(m_n, q) * dx + dt*am * inner(grad(m), grad(q)) * dx + dt*am*nu * inner(grad(T), grad(q)) * dx
#F1 = c*rho_0* inner(T, v) * dx - c*rho_0* inner(T_n, v) * dx + dt*k * inner(grad(T), grad(v)) * dx - R*epsilon * inner(m, v) * dx + R*epsilon * inner(m_n, v) * dx
F1 = inner(T, v) * dx - inner(T_n, v) * dx + dt*alpha * inner(grad(T), grad(v)) * dx - beta*epsilon * inner(m, v) * dx + beta*epsilon * inner(m_n, v) * dx
F = F0 + F1
# Non linear problem definition
#Compute the jacobian
Jac = derivative(F, u, du)
problem = NonlinearProblem(F, u, bcs = bcs, J = Jac)
#Solve variational problem
# Create nonlinear problem and Newton solver
#problem = NonlinearProblem(F, u, bcs = bcs)     #Replace
solver = NewtonSolver(MPI.COMM_WORLD, problem)
solver.convergence_criterion = "incremental"      #residual    #incremental
# Absolute tolerance
solver.atol = 5e-10
solver.rtol = 1e-12 #0.0 #1e-14 #0.0 #1e-12
#solver.max_it = 70
solver.report = True
#solver.max_it = 100        #To increase the number of iterations
solver.error_on_nonconvergence = False
solver.max_it = 2
info = solver.solve(u)
print(info)
The next step is to create a loop over time. I built three xdmf files with xdmf1 and xdmf2 containing the solutions m and T.
################ Pre-processing ###################
# Create an output xdmf file to store the values
# xdmf = XDMFFile(mesh.comm, "Column.xdmf", "w")
# xdmf.write_mesh(mesh)
# We prepare output files for the velocity and pressure data, and write the mesh and initial conditions to file
file = XDMFFile(msh.comm, "problem_rectangle_mesh_4th_march2024_alhaatim.xdmf", "w")
file.write_mesh(msh)
#with io.XDMFFile(MPI.COMM_WORLD, "moisture_4th_March2024.xdmf", [u_n.sub(0).collapse()], "w") as xdmf1:
with io.XDMFFile(MPI.COMM_WORLD, "moisture_4th_March2024.xdmf", "w") as xdmf1:
    xdmf1.write_mesh(msh)
with io.XDMFFile(MPI.COMM_WORLD, "temperature_4th_March2024.xdmf", "w") as xdmf2:
    xdmf2.write_mesh(msh)
################ Processing #######################
# time steps to evaluate the pressure in space:
#n0, n1, n2 = 200,400,800
t = 0
#L2_p = np.zeros(num_steps, dtype=PETSc.ScalarType)
for n in range(num_steps):
	t += dt
	try:
		num_its, converged = solver.solve(u)
	except:
		if MPI.COMM_WORLD.rank == 0:
			print("*************")
			print("Solver failed")
			pass
	u.x.scatter_forward()
	# Update Value
	u_n.x.array[:] = u.x.array
	__m, __T = u.split()
	# Export the results
	__m.name = "Moisture"
	__T.name = "Temperature"
	xdmf1.write_function(__m,t)
	xdmf2.write_function(__T,t)
file.close()
xdmf1.close()
xdmf2.close()
The above doesn’t return an error, but when I try to use Paraview to visualise my results, it doesn’t work (i.e. empty file with no data).
Thank you for your time and your patience.
