I am trying to implement a structural shell analysis formulation. It works with triangular elements but whenever I switch to quads, the code throws an error “Currently no support for ReferenceGrad in CoefficientDerivative.”
Here is the code I am suing:
from ufl import (
Jacobian, CellNormal, CellDiameter,
cross, dot, sqrt, as_matrix,
TrialFunction, TestFunction
from dolfinx.fem import (
Function, dirichletbc,
functionspace, locate_dofs_topological,
from dolfinx.io import gmshio
from ufl import derivative, dx, grad, split, dot, sym, as_vector
# Read mesh
msh, markers, facets = gmshio.read_from_msh("Ibeam/I_beam_quad.msh", MPI.COMM_WORLD)
num_nodes = msh.geometry.x.shape[0]
num_cell = msh.topology.original_cell_index.shape[0]
# Material and geometry
E = 210e9
nu = 0.3
h = 1e-3
A = E*h/(1-nu**2)
D = A*h**2/12.
Fs = E/2/(1+nu)*h*5./6.
# Element definition
u1 = element("Lagrange", msh.basix_cell(), 1, shape=(3,))
u2 = element("Lagrange", msh.basix_cell(), 1, shape=(3,))
V = functionspace(msh, mixed_element([u1, u2]))
w = Function(V)
w_t = TrialFunction(V)
dw = TestFunction(V)
q, theta = split(w)
# Constitutive matrices
A_mat = np.tile(np.array([A, nu*A, 0, nu*A, A, 0, 0, 0, A*(1-nu)/2.]), (num_cell, 1))
B_mat = np.tile(np.zeros((9, )), (num_cell, 1))
D_mat = np.tile(np.array([D, nu*D, 0, nu*D, D, 0, 0, 0, D*(1-nu)/2.]), (num_cell, 1))
As_mat = np.tile(np.array([Fs, 0., 0., Fs]), (num_cell, 1))
Vabd = functionspace(msh, ("DG", 0, (3, 3)))
Vs = functionspace(msh, ("DG", 0, (2, 2)))
D_max = np.amax(D_mat)
A_fun = Function(Vabd)
B_fun = Function(Vabd)
D_fun = Function(Vabd)
As_fun = Function(Vs)
A_fun.x.petsc_vec.setArray(A_mat)
B_fun.x.petsc_vec.setArray(B_mat)
D_fun.x.petsc_vec.setArray(D_mat)
As_fun.x.petsc_vec.setArray(As_mat)
# Loading (self-weight)
f_array = np.tile(np.array([0, 0.2, -1]), (num_nodes, 1))
VF = functionspace(msh, ("CG", 1, (3,)))
f = Function(VF)
f.x.petsc_vec.setArray(f_array)
# Local basis
J = Jacobian(msh)
n = CellNormal(msh)
e3 = n/sqrt(dot(n, n))
t = as_vector([J[0, 0], J[1, 0], J[2, 0]])
e1 = t/sqrt(dot(t, t))
e2 = cross(e3, e1)
# Strains
H = as_matrix([[e1[i] for i in range(0, 3)],
[e2[i] for i in range(0, 3)]])
gradq = dot(H, dot(grad(q), H.T))
eps = sym(gradq)
kappa = sym(dot(H, dot(grad(cross(e3, theta)), H.T)))
gamma = dot(H, grad(dot(q, e3))) - dot(H, cross(e3, theta))
omega = (gradq[0, 1] - gradq[1, 0])/2 + dot(theta, e3)
eps_bar = as_vector([eps[0, 0], eps[1, 1], 2*eps[0, 1]])
kappa_bar = as_vector([kappa[0, 0], kappa[1, 1], 2*kappa[0, 1]])
# Stresses
N = A_fun*eps_bar + B_fun*kappa_bar
M = B_fun*eps_bar + D_fun*kappa_bar
Q = As_fun*gamma
# Strain energy
h_mesh = CellDiameter(msh)
dx_inplane = dx(metadata={"quadrature_degree":1})
dx_shear = dx(metadata={"quadrature_degree":0})
U = 0.5*dot(N, eps_bar)*dx_inplane + \
0.5*dot(M, kappa_bar)*dx_inplane + \
0.5*dot(Q, gamma)*dx_shear + \
0.5*(D_max*12*omega/h_mesh**2)*omega*dx
# BCs
Vu, _ = V.sub(0).collapse()
left_dofs = locate_dofs_topological((V.sub(0), Vu), 1, facets.find(1))
right_dofs = locate_dofs_topological((V.sub(0), Vu), 1, facets.find(2))
uD = Function(Vu)
bcs = [
dirichletbc(uD, left_dofs, V.sub(0)),
dirichletbc(uD, right_dofs, V.sub(0)),
# Total energy
Wext = dot(f, q)*dx
Pi = U - Wext
F = derivative(Pi, w, dw)
K = derivative(F, w, w_t)
problem = LinearProblem(
K,
-F,
bcs=bcs,
petsc_options={"ksp_type": "preonly", "pc_type": "lu", "pc_factor_mat_solver_type": "mumps"},
w = problem.solve()
The mesh file with triangular elements: I_beam.msh
$MeshFormat
4.1 0 8
$EndMeshFormat
$Entities
17 16 5 0
1 0.07499999999999998 -0.05 -0.1299038105676658 0
2 0.07499999999999998 0 -0.1299038105676658 0
3 0.07499999999999998 0.05 -0.1299038105676658 0
4 -0.07499999999999998 -0.1 0.1299038105676658 0
5 -0.07499999999999998 0 0.1299038105676658 0
6 -0.07499999999999998 0.1 0.1299038105676658 0
7 1.925 -0.05 -0.1299038105676658 0
8 1.925 0 -0.1299038105676658 0
12 1 -0.05 -1.732050807568877 0
14 1 0 -1.732050807568877 0
16 1.925 0.05 -0.1299038105676658 0
22 1 0.05 -1.732050807568877 0
24 2.075 0 0.1299038105676658 0
25 2.075 -0.1 0.1299038105676658 0
30 1 -0.1 -1.732050807568877 0
32 2.075 0.1 0.1299038105676658 0
38 1 0.1 -1.732050807568877 0
1 0.07499999999999998 -0.05 -0.1299038105676658 0.07499999999999998 0 -0.1299038105676658 1 1 2 1 -2
2 0.07499999999999998 0 -0.1299038105676658 0.07499999999999998 0.05 -0.1299038105676658 1 1 2 2 -3
3 -0.07499999999999998 0 -0.1299038105676658 0.07499999999999998 0 0.1299038105676658 1 1 2 2 -5
4 -0.07499999999999998 -0.1 0.1299038105676658 -0.07499999999999998 0 0.1299038105676658 1 1 2 4 -5
5 -0.07499999999999998 0 0.1299038105676658 -0.07499999999999998 0.1 0.1299038105676658 1 1 2 5 -6
6 1.925 -0.05 -0.1299038105676658 1.925 0 -0.1299038105676658 1 2 2 7 -8
7 0.07499999999999973 -0.05 -0.1299038105676664 1.925000000000001 -0.05 0.1148192852329688 0 2 1 -7
8 0.07499999999999973 0 -0.1299038105676664 1.925000000000001 0 0.1148192852329688 0 2 2 -8
10 1.925 0 -0.1299038105676658 1.925 0.05 -0.1299038105676658 1 2 2 8 -16
12 0.07499999999999973 0.05 -0.1299038105676664 1.925000000000001 0.05 0.1148192852329688 0 2 3 -16
14 1.925 0 -0.1299038105676658 2.075 0 0.1299038105676658 1 2 2 8 -24
16 -0.07500000000000018 0 0.129903810567666 2.075000000000001 0 0.4143117327143495 0 2 5 -24
18 2.075 -0.1 0.1299038105676658 2.075 0 0.1299038105676658 1 2 2 25 -24
19 -0.07500000000000018 -0.1 0.129903810567666 2.075000000000001 -0.1 0.4143117327143495 0 2 4 -25
22 2.075 0 0.1299038105676658 2.075 0.1 0.1299038105676658 1 2 2 24 -32
24 -0.07500000000000018 0.1 0.129903810567666 2.075000000000001 0.1 0.4143117327143495 0 2 6 -32
9 0.07499999999999973 -0.05 -0.1299038105676664 1.925000000000001 0 0.1148192852329688 1 1 4 1 8 -6 -7
13 0.07499999999999973 0 -0.1299038105676664 1.925000000000001 0.05 0.1148192852329688 1 1 4 2 12 -10 -8
17 -0.07500000000000018 0 -0.1299038105676664 2.075000000000001 0 0.4143117327143495 1 1 4 3 16 -14 -8
21 -0.07500000000000018 -0.1 0.1299038105676658 2.075000000000001 0 0.4143117327143495 1 1 4 4 16 -18 -19
25 -0.07500000000000018 0 0.1299038105676658 2.075000000000001 0.1 0.4143117327143495 1 1 4 5 24 -22 -16
$EndEntities
$Nodes
33 24 1 24
0 1 0 1
1
0 2 0 1
2
0 3 0 1
3
0 4 0 1
4
0 5 0 1
5
0 6 0 1
6
0 7 0 1
7
0 8 0 1
8
0 16 0 1
9
0 24 0 1
10
0 25 0 1
11
0 32 0 1
12
1 1 0 0
1 2 0 0
1 3 0 2
13
14
0.02500000000011773 0 -0.04330127018942585
-0.02499999999987315 0 0.04330127018900226
1 4 0 0
1 5 0 0
1 6 0 0
1 7 0 1
15
0.9999999999999999 -0.05 0.1179491924311227
1 8 0 1
16
0.9999999999999999 0 0.1179491924311227
1 10 0 0
1 12 0 1
17
0.9999999999999999 0.05 0.1179491924311227
1 14 0 2
18
19
1.974999999999882 0 -0.04330127018942576
2.024999999999873 0 0.04330127018900232
1 16 0 1
20
0.9999999999999999 0 0.4179491924311229
1 18 0 0
1 19 0 1
21
0.9999999999999999 -0.1 0.4179491924311229
1 22 0 0
1 24 0 1
22
0.9999999999999999 0.1 0.4179491924311229
2 9 0 0
2 13 0 0
2 17 0 2
23
24
0.9999999999999999 0 0.2179491924308874
1 0 0.3179491924308693
2 21 0 0
2 25 0 0
$EndNodes
$Elements
15 42 1 42
1 1 1 1
1 1 2
1 2 1 1
2 2 3
1 3 1 3
3 2 13
4 13 14
5 14 5
1 4 1 1
6 4 5
1 5 1 1
7 5 6
1 6 1 1
8 7 8
1 10 1 1
9 8 9
1 14 1 3
10 8 18
11 18 19
12 19 10
1 18 1 1
13 11 10
1 22 1 1
14 10 12
2 9 2 4
15 1 2 16
16 1 16 15
17 15 16 8
18 15 8 7
2 13 2 4
19 2 3 17
20 2 17 16
21 16 17 9
22 16 9 8
2 17 2 12
23 2 13 23
24 2 23 16
25 16 23 18
26 16 18 8
27 13 14 24
28 13 24 23
29 23 24 19
30 23 19 18
31 14 5 20
32 14 20 24
33 24 20 10
34 24 10 19
2 21 2 4
35 4 5 20
36 4 20 21
37 21 20 10
38 21 10 11
2 25 2 4
39 5 6 22
40 5 22 20
41 20 22 12
42 20 12 10
$EndElements
Mesh file with quads: I_beam_quad.msh
$MeshFormat
4.1 0 8
$EndMeshFormat
$Entities
17 16 5 0
$EndEntities
$Nodes
33 55 1 55
0 1 0 1
1
0 2 0 1
2
0 3 0 1
3
0 4 0 1
4
0 5 0 1
5
0 6 0 1
6
0 7 0 1
7
0 8 0 1
8
0 16 0 1
9
0 24 0 1
10
0 25 0 1
11
0 32 0 1
12
1 1 0 1
13
0.07499999999999998 -0.02500000001223876 -0.1299038105676658
1 2 0 1
14
0.07499999999999998 0.02499999998776124 -0.1299038105676658
1 3 0 1
15
3.67162689141054e-11 0 -6.359443527337305e-11
1 4 0 1
16
-0.07499999999999998 -0.05000000002447752 0.1299038105676658
1 5 0 1
17
-0.07499999999999998 0.04999999997552249 0.1299038105676658
1 6 0 1
18
1.925 -0.02500000001223876 -0.1299038105676658
1 7 0 3
19
20
21
0.5211847671599293 -0.05 0.05491197122655911
1.478815232098933 -0.05 0.05491197142514648
1 8 0 3
22
23
24
0.5211847671599293 0 0.05491197122655911
1.478815232098933 0 0.05491197142514648
1 10 0 1
25
1.925 0.02499999998776124 -0.1299038105676658
1 12 0 3
26
27
28
0.5211847671599293 0.05 0.05491197122655911
1.478815232098933 0.05 0.05491197142514648
1 14 0 1
29
1.999999999963284 0 -6.359443527337305e-11
1 16 0 3
30
31
32
0.443539053068413 0 0.3446897189630251
1.556460947134918 0 0.3446897189085425
1 18 0 1
33
2.075 -0.05000000002447752 0.1299038105676658
1 19 0 3
34
35
36
0.443539053068413 -0.1 0.3446897189630251
1.556460947134918 -0.1 0.3446897189085425
1 22 0 1
37
2.075 0.04999999997552249 0.1299038105676658
1 24 0 3
38
39
40
0.443539053068413 0.1 0.3446897189630251
1.556460947134918 0.1 0.3446897189085425
2 9 0 3
41
42
43
0.9999999999999999 -0.02499999999914538 0.1179491924311227
0.521184767159951 -0.02500000000040423 0.0549119712265651
1.478815232101 -0.02500000000040423 0.0549119714245927
2 13 0 3
44
45
46
0.9999999999999999 0.02500000000085462 0.1179491924311227
0.521184767159951 0.02499999999959578 0.0549119712265651
1.478815232101 0.02499999999959578 0.0549119714245927
2 17 0 3
47
48
49
0.999999999988275 0 0.2622288582336462
0.4837854862407983 0 0.1944804172286039
1.516214513477559 0 0.1944804173040565
2 21 0 3
50
51
52
0.9999999999999999 -0.04999999999766757 0.4179491924311229
0.4435390530684149 -0.05000000000045631 0.3446897189630251
1.556460947134878 -0.05000000000045629 0.3446897189085532
2 25 0 3
53
54
55
0.9999999999999999 0.05000000000233244 0.4179491924311229
0.4435390530684373 0.04999999999954369 0.3446897189630309
1.556460947134928 0.04999999999954371 0.3446897189085394
$EndNodes
$Elements
15 60 1 60
1 1 1 2
1 1 13
2 13 2
1 2 1 2
3 2 14
4 14 3
1 3 1 2
5 2 15
6 15 5
1 4 1 2
7 4 16
8 16 5
1 5 1 2
9 5 17
10 17 6
1 6 1 2
11 7 18
12 18 8
1 10 1 2
13 8 25
14 25 9
1 14 1 2
15 8 29
16 29 10
1 18 1 2
17 11 33
18 33 10
1 22 1 2
19 10 37
20 37 12
2 9 3 8
21 1 13 42 19
22 13 2 22 42
23 42 22 24 41
24 19 42 41 21
25 21 41 43 20
26 41 24 23 43
27 43 23 8 18
28 20 43 18 7
2 13 3 8
29 2 14 45 22
30 14 3 26 45
31 45 26 28 44
32 22 45 44 24
33 24 44 46 23
34 44 28 27 46
35 46 27 9 25
36 23 46 25 8
2 17 3 8
37 2 15 48 22
38 15 5 30 48
39 48 30 32 47
40 22 48 47 24
41 24 47 49 23
42 47 32 31 49
43 49 31 10 29
44 23 49 29 8
2 21 3 8
45 4 16 51 34
46 16 5 30 51
47 51 30 32 50
48 34 51 50 36
49 36 50 52 35
50 50 32 31 52
51 52 31 10 33
52 35 52 33 11
2 25 3 8
53 5 17 54 30
54 17 6 38 54
55 54 38 40 53
56 30 54 53 32
57 32 53 55 31
58 53 40 39 55
59 55 39 12 37
60 31 55 37 10
$EndElements
I would love to get some insights into this, as I just started using Fenicsx a few months back. I am using the latest release (v0.9).
