Reproducibility in parallel programming
Dear community,
Recently, I found the results can not be reproduced in parallel programming. Here is the MWE:
from dolfinx.generation import RectangleMesh
from dolfinx.mesh import CellType
from dolfinx.fem import VectorFunctionSpace, FunctionSpace, Function, DirichletBC
from dolfinx.nls import NewtonSolver
# mesh and function space
mesh = RectangleMesh(MPI.COMM_WORLD, [[0, 0, 0], [1, 1, 0]], [200, 200], CellType.quadrilateral)
fdim = mesh.topology.dim - 1
V = VectorFunctionSpace(mesh, ("CG", 1))
S = FunctionSpace(mesh, ("DG", 0))
u = Function(V)  # test function
v = ufl.TestFunction(V)  # trial function
# kinematics
lambda_, mu = 0.5769, 0.3846
P = 2.0*mu*ufl.sym(ufl.grad(u)) + lambda_*ufl.tr(ufl.sym(ufl.grad(u)))*ufl.Identity(len(u))
dx = ufl.Measure("dx", metadata={"quadrature_degree": 4})
R = ufl.inner(ufl.grad(v), P)*dx
# boundary conditions
def left(x):
    return np.isclose(x[0], 0)
def right(x):
    return np.isclose(x[0], 1)
u1 = Function(V)
boundary_facets = dolfinx.mesh.locate_entities_boundary(mesh, fdim, left)
with u1.vector.localForm() as loc:
    loc.set(0)
bc1 = DirichletBC(u1, dolfinx.fem.locate_dofs_topological(
    V, fdim, boundary_facets))
u2 = Function(V)
boundary_facets = dolfinx.mesh.locate_entities_boundary(mesh, fdim, right)
with u2.vector.localForm() as loc:
    loc.set(1)
bc2 = DirichletBC(u2, dolfinx.fem.locate_dofs_topological(
bcs = [bc1, bc2]
# FEniCSx built-in solver
problem = dolfinx.fem.NonlinearProblem(R, u, bcs)
solver.solve(u)
print(u.vector.norm())
If we run this code 10 times with 3 cores, we can see that the results are random:
167.69866130498036
167.69866130497905
167.69866130498082
167.69866130498008
167.6986613049795
167.69866130498286
167.69866130498218
167.69866130497863
167.69866130498133
167.69866130498036
Although these results are relatively close to each other, the small difference can still be accumulated to a much larger one in the end in time-stepping problems. I wonder if we have some ways to ensure reproducibility? Or at least if we can ensure reproducibility with the same number of cores?
I cannot reproduce this issue using the dolfinx/dolfinx:nightly docker container with the following adaptation:
from dolfinx.mesh import create_rectangle
from dolfinx.fem import VectorFunctionSpace, FunctionSpace, Function, dirichletbc
mesh = create_rectangle(MPI.COMM_WORLD, [[0, 0], [1, 1]], [200, 200], cell_type=CellType.quadrilateral)
# kinematics
def left(x):
def right(x):
u1 = Function(V)
    loc.set(0)
bc1 = dirichletbc(u1, dolfinx.fem.locate_dofs_topological(
u2 = Function(V)
    loc.set(1)
bc2 = dirichletbc(u2, dolfinx.fem.locate_dofs_topological(
bcs = [bc1, bc2]
problem = dolfinx.fem.petsc.NonlinearProblem(R, u, bcs)
solver.solve(u)
But please note that the difference in norm is at the magnitude of 10^{-12}, which is fairly close to machine precision and lower than the default tolerances of the Newton Solver (and most likely the underlying ksp solver).
