Hi everyone,
I am trying to solve a nonlinear problem in a mixed space. My solution doesn’t converge due to the presence of tan(ksi) in the integrand4. I want to know if we can somehow restrict ksi to ignore the values pi/2. If yes, how can we do this? e.g. if we can substitute ksi by arctan(z) or any other trigonometric function to make this work.
I’ll highly appreciate if you can find some time to look at my code and provide me with your valuable suggestion.
Here’s my code
import fenics as fe
from ufl.operators import min_value
import scipy.integrate as integrate
import ufl as ufl
mesh = IntervalMesh(2000, 0, 10)
phiP_element = fe.FiniteElement('CG', mesh.ufl_cell(), 2)
ksi_element = fe.FiniteElement('CG', mesh.ufl_cell(), 2)
pk_element = fe.MixedElement([phiP_element, ksi_element])
pk_space = fe.FunctionSpace(mesh, pk_element)
Real_scalar = fe.FunctionSpace(mesh, 'CG', 1)
Real_vector = fe.VectorFunctionSpace(mesh, 'CG', 1)
def left(x, on_boundary):
return on_boundary and fe.near(x[0], 0.0)
def right(x, on_boundary):
return on_boundary and fe.near(x[0], 10.0)
bc_1 = fe.DirichletBC(pk_space.sub(0), fe.Constant(0.0), left)
bc_2 = fe.DirichletBC(pk_space.sub(0), fe.Constant(0.0), right)
bc_3 = fe.DirichletBC(pk_space.sub(1), fe.Constant(0.0), left)
bc_4 = fe.DirichletBC(pk_space.sub(1), fe.Constant(np.pi/2-0.00001), right)
bcs = [bc_1, bc_2, bc_3, bc_4]
marker = MeshFunction("size_t", mesh, mesh.topology().dim() - 1, 0)
for vertex in entities(mesh, 0):
if (vertex.midpoint().x() < 5.0):
marker[vertex] = 1
elif (vertex.midpoint().x() 5.0):
marker[vertex] = 2
marker[vertex] = 3
xa = Expression("x[0]",degree=1)
r=interpolate(xa,Real_scalar)
e_phiP = Expression('0.0', degree=1)
e_ksi = Expression(('atan((x[0])/(sqrt((r_0 * r_0)- (x[0]*x[0]))))'), degree=1, r_0 = 10) # expression
phiP_0 = interpolate(e_phiP, pk_space.sub(0).collapse())
ksi_0 = interpolate(e_ksi, pk_space.sub(1).collapse())
pk = fe.Function(pk_space)
assign(pk, [phiP_0, ksi_0])
phiP, ksi = fe.split(pk)
ksi=ksi_0
phiP=phiP_0
vn = fe.TestFunction(pk_space)
v1, v2 = fe.split(vn)
dx = Measure("dx", domain=mesh)
ds = Measure("dS", domain=mesh, subdomain_data=marker)
K_c = fe.Constant(1.0)
k_o = fe.Constant(0.0)
K_0 = fe.Constant(20.0)
gamma_L = fe.Constant(1.0)
delta = fe.Constant(4.0)
del_P = fe.Constant(1.0)
r_p = r + delta * sin(ksi)
integrand1 = (1 + (float(delta) *cos(ksi) *fe.Dx(ksi,0))) *2 * np.pi * r_p * (1/cos(ksi)) * ((K_c/2) * (((cos(phiP + ksi) + cos(phiP - ksi))/2) * fe.Dx(phiP + ksi,0) * ((1 + (delta * cos(ksi) * fe.Dx(ksi,0))) ** (-1)) + (sin(phiP + ksi)/r_p) - k_o) ** 2 - (k_o ** 2))
integrand2 = (K_0/2) * np.pi * r_p * (1 - cos(2 * phiP)) * (1/cos(ksi))* (1 + (float(delta) *cos(ksi) *fe.Dx(ksi,0)))
integrand3 = gamma_L * 2 * np.pi * r_p * (1/cos(ksi)) *(1 + (float(delta) *cos(ksi) *fe.Dx(ksi,0)))
integrand4 = del_P * fe.pi * (r_p * r_p) * tan(ksi) * (1 + (float(delta) *cos(ksi) *fe.Dx(ksi,0)))
functional = integrand1 * fe.dx + integrand2 * fe.dx+ integrand3 * fe.dx + integrand4 * fe.dx
Integ=functional
weak_form = fe.derivative(Integ , pk, fe.TestFunction(pk_space))
jacobian = fe.derivative(weak_form, pk, fe.TrialFunction(pk_space))
problem = fe.NonlinearVariationalProblem(weak_form, pk, bcs, jacobian)
solver = fe.NonlinearVariationalSolver(problem)
solver.solve()
and the error is:
*** Error: Unable to successfully call PETSc function ‘MatSetValuesLocal’.
*** Reason: PETSc error code is: 63 (Argument out of range).
*** Where: This error was encountered inside ./dolfin/la/PETScMatrix.cpp.
*** Process: 0
*** Git changeset: ubuntu
*** -------------------------------------------------------------------------Solving nonlinear variational problem. Newton iteration 0: r (abs) = 1.571e+00 (tol = 1.000e-10) r (rel) = 1.000e+00 (tol = 1.000e-09)
