Results depend on type of mesh in simple heat equation example
Hi all, I am a new FEniCS user. I am trying to practice the configuration of FEniCS from the simplest one, one of which is a heat equation. I simply copied and pasted the example code, and changed the input mesh. Then, the results were very weird as follows. When I used the crossed mesh, the error has regionally big values whereas the error was small with the left and right mesh. The code is attached here.
FEniCS tutorial demo program: Heat equation with Dirichlet conditions.
Test problem is chosen to give an exact solution at all nodes of the mesh.
u’= Laplace(u) + f in the unit square
u = u_D on the boundary
u = u_0 at t = 0
u = 1 + x^2 + alphay^2 + \betat
f = beta - 2 - 2*alpha
T = 2.0            # final time
num_steps = 10     # number of time steps
alpha = 3          # parameter alpha
beta = 1.2         # parameter beta
nx = ny = 8
#mesh = UnitSquareMesh(nx, ny,'crossed')
#mesh = UnitSquareMesh(nx, ny,'left')
#mesh = UnitSquareMesh(nx, ny,'right')
# Define boundary condition
u_D = Expression('1 + x[0]*x[0] + alpha*x[1]*x[1] + beta*t',
                 degree=2, alpha=alpha, beta=beta, t=0)
def boundary(x, on_boundary):
    return on_boundary
# Define initial value
u_n = interpolate(u_D, V)
#u_n = project(u_D, V)
f = Constant(beta - 2 - 2*alpha)
F = u*v*dx + dt*dot(grad(u), grad(v))*dx - (u_n + dt*f)*v*dx
a, L = lhs(F), rhs(F)
# Time-stepping
t = 0
vtkfile = File('tutorial.pvd')
for n in range(num_steps):
    # Update current time
    u_D.t = t
    # Compute solution
    solve(a == L, u, bc)
    # Plot solution
    plot(u)
    vtkfile << (u,t)
    # Compute error at vertices
    u_e = interpolate(u_D, V)
    error = np.abs(u_e.vector()[:] - u.vector()[:]).max()
    print('t = %.2f: error = %.3g' % (t, error))
    # Update previous solution
    u_n.assign(u)
# Hold plot
#interactive()
A specific description of code is given here,
This is the error plot over the domain with the crossed mesh
untitled
What you are observing is a super-convergence for structured grids.
The “left” and “right” orientation gives the approximation field certain nice properties, which a “crossed” mesh does not.
You can observe this by for instance increasing the polynomial degree of your approximation space from 1 to 2. Then you will see a maximum error of order 1e-14, which is close to machine precision.
You should also consider the L^2(\Omega) error as opposed to the max error at vertices, i.e.
print("t", errornorm(u_D, u))
Which gives you a better picture of the accumulated error.
Thank you for the considerate comment. But I have never heard about super-convergence in this field. Can you elaborate a little bit more about it please??
The meshes with “left”/“right” orientation, combined with a P1 finite element perfectly approximates the solution to your quadratic problem at the mesh vertices.
However, as you are using a first order function space to approximate a second order polynomial, the solution is not exact at any other point. That is why one usually uses the “L2” error computation, see Solving PDEs in Minutes - <br> The FEniCS Tutorial Volume I and the remaining bits of the chapter.
You should also consider computing convergence rates, as described in: Solving PDEs in Minutes - <br> The FEniCS Tutorial Volume I
