I got results like this, is there any way to make it wider, do I need to code something or I can change it in paraview? I would like to read some references.
As you are visualizing a 1 dimensional domain, you can make it wider by using the visualization wireframe, and set linewidth to a larger number.
However, I would suggest you use the “Plot Over Line” filter to visualize your results.
