Retrieve vector size from c file
can I retrieve the vector size (block size) from a generated c-file?
For example:
from pathlib import Path
import ffcx.main
cwd = Path.cwd()
infile = cwd / "elasticity.py"
ffcx.main.main(["-o", str(cwd), "--visualise", str(infile)])
with elasticity.py
from dolfinx import fem, mesh
from ufl import Identity, TestFunction, TrialFunction, dx, inner, nabla_grad, tr
domain = mesh.create_unit_square(MPI.COMM_WORLD, 1, 1, mesh.CellType.quadrilateral)
E = 7e9
nu = 0.33
lam = E*nu/((1+nu)*(1-2*nu))
mu = 0.5*E/(1+nu)
def sigma(v):
    return 2.0 * mu * epsilon(v) + lam * tr(epsilon(v)) * Identity(len(v))
a = inner(sigma(u), epsilon(v)) * dx
From elasticity.c I would like to retrieve the vector size (=2).
(Fenics 0.9)
Thanks in advance!
I don’t think you can do that.
Why would you need to do this?
It would have been helpful to me for testing element matrices with input data of the right size. I found some information in ufcx_form and I thought I might have missed it.
What exactly is your workflow with FFCx/DOLFINx?
In the example above, you mix the DOLFINx python interface with the “pure” ufl/basix/ffcx interface.
With the pure ufl formulation I ran into the following problem:
MWE:
import basix.ufl
from ufl import FunctionSpace, Identity, Mesh, TestFunction, TrialFunction, dx, grad, inner, tr
element = basix.ufl.element("Lagrange", "quadrilateral", 1)
domain = Mesh(basix.ufl.element("Lagrange", "quadrilateral", 1, shape=(2,)))
V = FunctionSpace(domain, element)
E = 7e9
nu = 0.33
mu = 0.5*E/(1+nu)
    return 0.5*(grad(u) + grad(u).T)
def sigma(v):
error message:
  File "/home/bjoern/ffcx/demo/elasticity.py", line 18, in <module>
  File "/home/bjoern/ffcx/demo/elasticity.py", line 17, in sigma
  File "/home/bjoern/ffcx/demo/elasticity.py", line 15, in epsilon
  File "/usr/lib/python3/dist-packages/ufl/exproperators.py", line 365, in _transpose
    return Transposed(self)
  File "/usr/lib/python3/dist-packages/ufl/tensoralgebra.py", line 106, in __init__
    raise ValueError("Transposed is only defined for rank 2 tensors.")
ValueError: Transposed is only defined for rank 2 tensors.
But would the original example not be the right way to formulate the problem using dolfinx?
I generate c-files of different order/ element type and then I call he tabulate_tensor_integral for different inputs (to test vs. comsol). However, since I only test a few problems, I can hard code the vector size as well.
You get your error message due to the fact that you want a vector element, i.e.
element = basix.ufl.element("Lagrange", "quadrilateral", 1, shape=(2, ))
Usually users do not manually generate the C files to call tabulate_tensor_integral. It is usually achieved through dolfinx.fem.form or dolfinx.fem.create_form, as shown in:
Create domain independent forms and call dolfinx.fem.create_form
**Create problem specific forms and call dolfinx.fem.form:
Thank you for the clarification! The links are very helpful and I can print the matrices. For the domain independent form, I was wondering how I reduce the block size to 1. Or is this not possible in that case?
MWE (the commented line would raise a segmentation fault)
import basix.ufl
element = basix.ufl.element("Lagrange", "quadrilateral", 1, shape=(2,))
domain = ufl.Mesh(element)
V = ufl.FunctionSpace(domain, element)
u = ufl.TrialFunction(V)
a = ufl.inner(ufl.grad(u), ufl.grad(v)) * ufl.dx
mesh = dolfinx.mesh.create_unit_square(MPI.COMM_WORLD, 1, 1, cell_type=dolfinx.mesh.CellType.quadrilateral)
V = dolfinx.fem.functionspace(mesh,element)
# V = dolfinx.fem.functionspace(mesh, ("Lagrange", 1))
a_compiled = dolfinx.fem.compile_form(MPI.COMM_WORLD, a)
bilinear_form = dolfinx.fem.create_form(a_compiled, [V, V], mesh, {}, {}, {})
A = dolfinx.fem.create_matrix(bilinear_form)
A_scipy = A.to_scipy()
print(f"{A_scipy=}")
dolfinx.fem.assemble_matrix(A, bilinear_form, bcs=[])
print(A_scipy.todense())
Then you need to change this to a scalar element, ie the element here should be a blocked element.
Got it, thanks again!
