Running `CR` in parallel: Error detected in HDF5
Thanks for your reply Nate! So I prepared a minimal code that still fails in parallel, albeit with a different error. For reference I follow a similar approach as mentioned in COMET for creating a periodic map between the dofs, and the hyperelasticity example in demos.
import os
comm = MPI.comm_world
set_log_level(20)
workdir = os.path.join(os.getcwd(), "DiscourseTrial", "CR")
os.makedirs(workdir, exist_ok=True)
parameters["ghost_mode"] = "shared_facet"
parameters["form_compiler"]["quadrature_degree"] = 5
parameters["form_compiler"]["representation"]="uflacs"
ffc_options = {"optimize": True, \
               "eliminate_zeros": True, \
               "precompute_basis_const": True, \
               "precompute_ip_const": True}
snes_solver_parameters = {"nonlinear_solver": "snes",
                          "snes_solver": {"linear_solver": "lu",   #lu or gmres or cg or bicgstab 'preconditioner: ilu, amg, jacobi'
                                        "preconditioner": "petsc_amg",
                                        "maximum_iterations": 50,
                                        "report": True,
                                        "line_search": 'basic',
                                        "error_on_nonconvergence": False,
                                        "relative_tolerance":1e-7,
                                        "absolute_tolerance":1e-8}}
msh = UnitCubeMesh(6, 6, 6) # tried with a periodic mesh
class PeriodicBoundary(SubDomain):
    def __init__(self, vertices, tolerance=DOLFIN_EPS):
        """ vertices stores the coordinates of the 4 unit cell corners"""
        SubDomain.__init__(self, tolerance)
        self.tol = tolerance
        self.vv = vertices
        self.a1 = self.vv[1,:]-self.vv[0,:] # first vector generating periodicity
        self.a2 = self.vv[2,:]-self.vv[0,:] # second vector generating periodicity
        self.a3 = self.vv[3,:]-self.vv[0,:] # third vector generating periodicity
            return True if on left, bottom, or back faces
            and not on one of the top, front or right faces
            or associate edges (and vertices) as defined below
        # faces
        left = near(x[0],self.vv[0,0])
        bottom = near(x[1],self.vv[0,1])
        back = near(x[2],self.vv[0,2])
        right = near(x[0],self.vv[1,0])
        top = near(x[1],self.vv[2,1])
        front = near(x[2],self.vv[3,2])
        # line-segments (bottom 4; top 4; vertical 4)
        bottom_front = bottom and front
        bottom_right = bottom and right
        top_left = top and left
        top_back = top and back
        left_front = left and front
        right_back = right and back
        return bool((left or back or bottom) and
                    (not( (top_left) or (left_front) or (top_back) or (right_back) or (bottom_right) or (bottom_front))) and on_boundary)
        # return bool( bool(left and not((top_left) or (left_front))) or bool(back and not((top_back) or (right_back))) or
        #         bool(bottom and not((bottom_right) or (bottom_front))) and on_boundary )
    def map(self, x, y):
        """ Mapping the right boundary to left and top to bottom"""
        # faces
        # line-segments
        top_right = top and right
        top_front = top and front
        right_front = right and front
        point_6 = right and front and top
        if point_6:
            y[0] = x[0] - (self.a1[0] + self.a2[0] + self.a3[0])
            y[1] = x[1] - (self.a1[1] + self.a2[1] + self.a3[1])
            y[2] = x[2] - (self.a1[2] + self.a2[2] + self.a3[2])
        elif top_right:
            y[0] = x[0] - (self.a1[0] + self.a2[0])
            y[1] = x[1] - (self.a1[1] + self.a2[1])
            y[2] = x[2] - (self.a1[2] + self.a2[2])
        elif top_front:
            y[0] = x[0] - (self.a2[0] + self.a3[0])
            y[1] = x[1] - (self.a2[1] + self.a3[1])
            y[2] = x[2] - (self.a2[2] + self.a3[2])
        elif right_front:
            y[0] = x[0] - (self.a1[0] + self.a3[0])
            y[1] = x[1] - (self.a1[1] + self.a3[1])
            y[2] = x[2] - (self.a1[2] + self.a3[2])
        elif right:
            y[0] = x[0] - (self.a1[0])
            y[1] = x[1] - (self.a1[1])
            y[2] = x[2] - (self.a1[2])
        elif front:
            y[0] = x[0] - (self.a3[0])
            y[1] = x[1] - (self.a3[1])
            y[2] = x[2] - (self.a3[2])
        elif top:
            y[0] = x[0] - (self.a2[0])
            y[1] = x[1] - (self.a2[1])
            y[2] = x[2] - (self.a2[2])
            y[0] = -1.
            y[1] = -1.
            y[2] = -1.
def freeEnergyNG(u, params):
    I = Identity(3)             # Identity tensor
    F = I + grad(u)             # Deformation gradient
    C = F.T*F                   # Right Cauchy-Green tensor
    J = det(F)
    I1 = tr(C)
    mu1, mu2, alph1, alph2, mu_pr = params
    psiEq = 3**(1-alph1)/(2.*alph1) * mu1 * (I1**alph1 - 3**alph1) + \
            3**(1-alph2)/(2.*alph2) * mu2 * (I1**alph2 - 3**alph2) - \
                (mu1 + mu2) * ln(J) + mu_pr/2*(J-1)**2
    # psiEq = (mu1+mu2)/2.*(I1-3.) - (mu1+mu2)*ln(J) + mu_pr/2.*(J-1)**2
    return psiEq
def assignLoading(i, fVal):
    Gamm_Voight = np.zeros(9)
    Gamm_Voight[0] = 1. * fVal
    Gamm_Voight[4] = Gamm_Voight[0]**(-0.5)
    Gamm_Voight[8] = Gamm_Voight[0]**(-0.5)
    return np.array([[Gamm_Voight[0]-1,    Gamm_Voight[1],       Gamm_Voight[2]],
                     [Gamm_Voight[3],      Gamm_Voight[4]-1 ,    Gamm_Voight[5]],
                     [Gamm_Voight[6],      Gamm_Voight[7],       Gamm_Voight[8]-1 ]])
deg = 1
Lx = Ly = Lz = 1
vertices = np.array([[0., 0,   0],   # 0: Origin
                     [Lx, 0,   0],   # 1: Right
                     [0,  Ly,  0],   # 2: Top
                     [0,  0,  Lz]])  # 3
kap_by_mu = Constant(1000)
rad = (0.2/(4./3*np.pi))**(1./3)
origin = CompiledSubDomain("near(x[0],0) && near(x[1],0) && near(x[2],0) && on_boundary")
rightPoint = CompiledSubDomain("near(x[0], Lx) && near(x[1],0) && near(x[2],0) && on_boundary", Lx = Lx)
topPoint = CompiledSubDomain("near(x[0],0) && near(x[1], Ly) && near(x[2],0) && on_boundary",   Ly = Ly)
frontPoint = CompiledSubDomain("near(x[0],0) && near(x[1],0) && near(x[2],Lz) && on_boundary",  Lz = Lz)
Wu = VectorElement("CR", msh.ufl_cell(), deg) # for displacement
Wlam = VectorElement("R", msh.ufl_cell(), 0)
V = FunctionSpace(msh, MixedElement([Wu, Wlam]), constrained_domain=PeriodicBoundary(vertices))
wper = Function(V)
uper, lamper = split(wper)
wper_  = TrialFunction(V)
uper_, lamper_ = split(wper)
dw_per = TestFunction(V)
du_per, dlam_per = split(dw_per)
Vplot = VectorFunctionSpace(msh, "CG", deg)
VQeplot = TensorFunctionSpace(msh, "DG", deg-1)  # at least one order lower
uplot = Function(Vplot, name="disp")
# *********************Non Gaussian Parameters ***********************
mu1 = Constant(1)
mu2 = Constant(1)
mu_pr = Constant(kap_by_mu*2)
alph1 = Constant(1)
alph2 = Constant(1)
facMul = Constant(1000)
matParamsMatrix = [mu1, mu2, alph1, alph2, mu_pr]
matParamsParts = [mu1*facMul, mu2*facMul, alph1, alph2, mu_pr*facMul]
matParams = np.vstack((matParamsMatrix, matParamsParts))
qvals = Constant(20*(mu1 + mu2))
h = FacetArea(msh)
hAvg = 1./2*(h('+') + h('-'))
Hbar = Constant( ( (0,0,0), (0,0,0), (0,0,0) ))
x = SpatialCoordinate(msh)
bcOrigin = DirichletBC(V.sub(0), Constant((0., 0., 0.)), origin, method="pointwise")
bcAll = [bcOrigin]
amuv = derivative(freeEnergyNG(uper + dot(Hbar, x), matParams[0]), wper, dw_per) * dx
# amuv += inner(lamper_, du_per) * dx + inner(dlam_per, uper_) * dx
amuv += qvals/hAvg*inner(jump(uper), jump(du_per))*dS   # penalize the jump across inner facets
Jac = derivative(amuv, wper, wper_)
prblm  = NonlinearVariationalProblem(amuv, wper, bcAll, J=Jac)
solver = NonlinearVariationalSolver(prblm)
solver.parameters.update(snes_solver_parameters)
wfil = XDMFFile(comm, os.path.join(workdir, 'dispTrialSphereTension.xdmf'))
wfil.parameters["flush_output"] = True
wfil.parameters["functions_share_mesh"] = True
wfil.parameters["rewrite_function_mesh"] = False
Hbar.assign(Constant(assignLoading(0, 1.5)))
solver.solve()
uper, lamper = wper.split(True)
uplot.assign(project(uper + dot(Hbar, x) , Vplot))
wfil.write(uplot, 0)
gives the following error when run in parallel
RuntimeError:
*** DOLFIN encountered an error. If you are not able to resolve this issue
*** using the information listed below, you can ask for help at
***     fenics-support@googlegroups.com
*** Remember to include the error message listed below and, if possible,
*** include a *minimal* running example to reproduce the error.
*** Error:   Unable to access vector of degrees of freedom.
*** Reason:  Cannot access a non-const vector from a subfunction.
*** Where:   This error was encountered inside Function.cpp.
*** Process: 1
*** DOLFIN version: 2019.1.0
*** Git changeset:  74d7efe1e84d65e9433fd96c50f1d278fa3e3f3f
Edit: If requred I can furnish the entire code (with the mesh) that should reproduce the exact error that I posted in the first place. However I feel that the issue is with using “CR” elements on a periodic domain, and running the code in parallel
