Dear all, I use the HDF5 file to run the MPI, but the result is really bad.
my HDF5.py:
from mpi4py import MPI as mpimesh = Mesh(“New3D_Denticles61000.xml”)
markers = MeshFunction(“size_t”, mesh, “New3D_Denticles61000_physical_region.xml”)
boundaries = MeshFunction(“size_t”, mesh, “New3D_Denticles61000_facet_region.xml”)
hdf = HDF5File(MPI.comm_world, “2New3D_Denticles61000.h5”, “w”)
hdf.write(mesh, “/mesh”)
hdf.write(markers, “/markers”)
hdf.write(boundaries, “/boundaries”)
parallel.py:(min. file)
from mpi4py import MPI as mpiQUAD_DEG = 2*k
dx = dx(metadata={“quadrature_degree”:QUAD_DEG})mesh = Mesh()
hdf = HDF5File(MPI.comm_world, “New3D_Denticles61000.h5”, “r”)
hdf.read(mesh, “/mesh”, False)
markers = MeshFunction(“size_t”, mesh, mesh.topology().dim())
hdf.read(markers, “/markers”)
boundaries = MeshFunction(“size_t”, mesh, mesh.topology().dim()-1)
hdf.read(boundaries, “/boundaries”)#Define boundary conditions
bcu_inflow = DirichletBC(V.sub(0), Expression(inflow_profile, degree=1), boundaries, 1)
bcu_walls = DirichletBC(V.sub(0), Constant((0, 0, 0)), boundaries, 3)
bcu_walls2 = DirichletBC(V.sub(0).sub(2), Constant(0), boundaries, 4)
bcu_denticles = DirichletBC(V.sub(0), Constant((0, 0, 0)), boundaries, 5)
bcp_outflow = DirichletBC(V.sub(1), Constant(0), boundaries, 2)
bcs = [bcu_inflow, bcu_walls, bcu_walls2, bcu_denticles, bcp_outflow]
I run the
mpirun -np 8 python3 file.py
The result (red circle is weird):
My question is how I can fix the problem. Thanks for anyone’s help!
