Hi, I’ve been using dolfinx.io.XDMFFile to visualise my solutions since I started to use dolfinx. But recently I updated dolfinx to around the commit Add test of symmetric tensor elements (#2880) · FEniCS/dolfinx@dd38c63 · GitHub And with that update, saving a Function with xdmf seems to cause paraview to crash immediately when opening. I have an MWE that saves an xdmf as follows:
from dolfinx.fem import Function, functionspace
from dolfinx import io
from dolfinx import mesh
msh = mesh.create_unit_square(MPI.COMM_WORLD, 10, 10)
V = functionspace(msh, ('Lagrange', 1))
u.name = 'u'
with io.XDMFFile(MPI.COMM_WORLD, './test.xdmf', 'w') as xdmf:
xdmf.write_mesh(msh)
xdmf.write_function(u)
but trying to open test.xdmf immediately crashes Paraview with no error output. Here is a google drive of the output files.
For your information I’m using Paraview 5.10.0 and the script was run on CentOS 8 with a dolfinx installed via conda (following the instructions for C++ core build and pip install).
