Seemingly incorrect answers for Neumann Boundary Conditions
I am currently trying to solve the poisson equation for neumann boundary conditions and I seem to get seemingly incorrect answers. I am inexperienced with differential equation and FEM and I would hope that there could be some light shed on this topic.
I am trying to solve a simple zero neumann boundary condition poisson equation with a dirac delta source in a circle.
In order for a neumann boundary condition PDE to be well defined, there are two conditions that need to be met.
  • The integral of the source must be equal to the integral of the boundary function g ( referring to the neumann poisson). This is due to the physics of the problem.
  • Either the integral of the solution u must be 0 or some point must be known. This is due to fact that the solution is up to a constant and therefore some point must be fixed to a value.
According to the neumann poisson post, if you enforce the solution of u to be zero you sort of meet both conditions described. Unfortunately following the recipe on thsi post is not possible on fenicsx so instead I attempt to remove the nullspace manually from the linear system.
my code looks like this
import dolfinx.fem as fem
from petsc4py.PETSc import ScalarType as default_scalar_type
from dolfinx.fem import petsc
# Define group names mapping
GROUP_NAMES = {"Cancellous Bone": 1, "Cortical Bone": 2, "Muscle": 3, "Fat": 4, "Skin": 5, "Boundary": 6}
# Define conductivity constants
ANISOTROPY_RATIO = 5
CONDUCTIVITY = {
    "Cancellous Bone": 0.075,
    "Cortical Bone": 0.02,
    "Fat": 0.0379,
    "Skin": 4.55E-4,
    "Muscle": np.diag(
            0.2455,
            ANISOTROPY_RATIO * 0.2455
from dolfinx import mesh,plot
from dolfinx.fem import FunctionSpace,Function,form
from dolfinx.fem.petsc import create_vector,assemble_matrix,assemble_vector
from ufl import inner,TrialFunction,TestFunction,ds,dx,grad,exp,sin,SpatialCoordinate
# To solve pure neumann conditions PDE, we constraint the solutions
# to sum to zero as in Neurodec
# Alternative options include using a lagrange multiplier in legacy dolfin
class ConstrainedLinearProblem():
    def __init__(self, a, L, V):
        self.a = a
        self.L = L
        self.V = V
    def solve(self):
        A = assemble_matrix(form(self.a))
        b=create_vector(form(self.L))
        with b.localForm() as b_loc:
            b_loc.set(0)
        assemble_vector(b,form(self.L))
        # Solution Function
        uh = Function(self.V)
        # Create Krylov solver
        solver = PETSc.KSP().create(A.getComm())
        solver.setOperators(A)
        # Create vector that spans the null space
        nullspace = PETSc.NullSpace().create(constant=True,comm=MPI.COMM_WORLD)
        A.setNullSpace(nullspace)
        # orthogonalize b with respect to the nullspace ensures that
        # b does not contain any component in the nullspace
        nullspace.remove(b)
        # Finally we are able to solve our linear system ::
        solver.solve(b,uh.vector)
        return uh
class FixedPointProblem():
    def __init__(self, a, L, V, bcs):
        self.a = a
        self.L = L
        self.V = V
        self.bc = bcs
    def solve(self):
        A = petsc.assemble_matrix(fem.form(self.a), bcs=[self.bc])
        b = petsc.assemble_vector(fem.form(self.L))
        fem.apply_lifting(b, [fem.form(self.a)], [[self.bc]])
        fem.set_bc(b, [self.bc])
        solver = PETSc.KSP().create(MPI.COMM_WORLD)
        # solver.setType(PETSc.KSP.Type.PREONLY)
        # solver.getPC().setType(PETSc.PC.Type.LU)
        solver.setFromOptions()
        uh = fem.Function(self.V)
        solver.solve(b, uh.vector)
        uh.x.scatter_forward()
        return uh
class DiskFEMModel:
    def __init__(self, msh_file_path: str):
        self.mesh, self.cell_markers, self.facet_markers  = dolfinx.io.gmshio.read_from_msh(msh_file_path, MPI.COMM_WORLD, gdim=2)
        self.mesh_geometry = self.mesh.geometry
        self.mesh_topology = self.mesh.topology
        self.build_model()
    def build_model(self):
        # Build out index references
        self.tree = dolfinx.geometry.bb_tree(self.mesh, self.mesh.topology.dim)
        self.midpoints = dolfinx.geometry.create_midpoint_tree(self.mesh, self.mesh.topology.dim, np.arange(self.cell_markers.values.size, dtype=np.int32))
        # Link the 1D and 3D topology
        self.mesh_topology.create_connectivity(self.mesh.topology.dim, 0)
        self.cell_to_vertex = self.mesh_topology.connectivity(self.mesh.topology.dim, 0)
        # Define function spaces
        element = ufl.TensorElement("DG", self.mesh.ufl_cell(), degree=0, shape=(2, 2))
        self.V_tensor = fem.functionspace(self.mesh, element)
        #self.V_tensor = fem.TensorFunctionSpace(self.mesh, ("DG", 1), shape=(3, 3))
        self.V_scalar = fem.FunctionSpace(self.mesh, ("CG", 1))
        self.V_source = fem.FunctionSpace(self.mesh, ("CG", 1))
        # Assign conductivity
        self.build_conductivity_map()
    def build_conductivity_map(self):
        self.sigma_anisotropic = fem.Function(self.V_tensor)
        num_cells = len(self.mesh.topology.connectivity(2, 0))
        with self.sigma_anisotropic.vector.localForm() as lf:
            for i in range(num_cells):
                lf.setValuesBlocked([i], CONDUCTIVITY['Muscle'].flatten())
    def extend_array(self, x):
        zeros_column = np.zeros((x.shape[0], 1))
        extended_array = np.hstack((x, zeros_column))
        return extended_array
    # Maybe create a more generic way of doing this instead of repeating code.
    def evaluate_solution_at_points(self, points: np.array):
        points = self.extend_array(points)
        cell_ids = dolfinx.geometry.compute_closest_entity(self.tree, self.midpoints, self.mesh, points).squeeze()
        return self.uh.eval(points, cell_ids)
    def evaluate_f_at_points(self, points: np.array):
        return self.source_function.eval(points, cell_ids)
    def point_to_cell_id(self, point: np.array):
        # Get the closest cell ID to the point
        cell_id = dolfinx.geometry.compute_closest_entity(self.tree, self.midpoints, self.mesh, point).squeeze()
        # Check if point is in the cell
        # vertex_indices = self.cell_to_vertex.links(cell_id)
        # vertices = self.mesh.geometry.x[vertex_indices]
        # min_bounds = vertices.min(axis=0)
        # max_bounds = vertices.max(axis=0)
        # assert np.all(point >= min_bounds) and np.all(point <= max_bounds), "Point co-ordinate's are not inside the volume."
        return cell_id
    def point_to_vertex_locations(self, point: np.array):
        cell_id = self.point_to_cell_id(point)
        return np.array([self.mesh_geometry.x[vertex_index] for vertex_index in vertex_indices])
    def point_to_cell_material(self, point: np.array):
        material_marker = self.cell_markers.values[cell_id]
        material_name = {v: k for k, v in GROUP_NAMES.items()}[material_marker]
        return material_name
    def assign_source_to_point(self, point: np.array, source_value: float = 1.0):
        # Initialize the source function
        self.source_function = fem.Function(self.V_source)
        with self.source_function.vector.localForm() as local:
            local.set(0.0)
        def gaussian_nd(x, x_mu, sigma):
            Calculate the n-dimensional Gaussian function for a given mean vector and scalar variance.
            :param x: ndarray, where each row represents a coordinate in n-dimensional space.
            :param x_mu: ndarray, the mean vector in n-dimensional space.
            :param sigma: float, the standard deviation (sqrt of variance).
            :return: ndarray, values of the Gaussian function at each point in x.
            # Ensure x and x_mu are numpy arrays for broadcasting
            # x = np.array(x)
            # x_mu = np.array(x_mu)
            x = x.T
            # Calculate the squared Euclidean distance from each point in x to the mean
            squared_dist = np.sum((x - x_mu)**2, axis=-1)
            # Compute the Gaussian function
            return 1 / ((2 * np.pi * sigma**2) ** (x.shape[-1] / 2)) * np.exp(-squared_dist / (2 * sigma**2))
        self.source_function.interpolate(lambda x: gaussian_nd(x, point, 0.1))
        integral = fem.assemble_scalar(fem.form(self.source_function * dx))
        print(integral)
        #self.source_function.vector.axpy(-integral, self.source_function.vector)
        u_constant  = fem.Constant(self.mesh, default_scalar_type(1.))
        volume = fem.assemble_scalar(fem.form(u_constant * dx))
        #self.source_function.interpolate(lambda x: gaussian_nd(x, point, 0.1)-integral/volume)
        self.source_integral = fem.assemble_scalar(fem.form(self.source_function * dx))
    def fix_cell_value(self, point, value = 1.0):
        u_D = fem.Function(self.V_scalar)
        with u_D.vector.localForm() as loc:
            loc.set(0)
        u_D.vector[vertex_indices[0]] = value
        u_D.vector[vertex_indices[1]] = value
        u_D.vector[vertex_indices[2]] = value
        boundary_dofs = vertex_indices
        bc = fem.dirichletbc(u_D, boundary_dofs)
        return bc
    def solve_for_point(self, point: np.array, source_value: float = 1.0):
        # Create the point source
        self.assign_source_to_point(point, source_value)
        # Define the test and trial functions of weak form
        u = ufl.TrialFunction(self.V_scalar)
        v = ufl.TestFunction(self.V_scalar)
        g = fem.Constant(self.mesh, default_scalar_type(self.source_integral))  # Neumann boundary condition
        # Define the variational problem
        a = ufl.dot(ufl.grad(u), ufl.grad(v)) * ufl.dx
        #a = ufl.dot(ufl.dot(self.sigma_anisotropic, ufl.grad(u)), ufl.grad(v)) * ufl.dx
        L = self.source_function * v * ufl.dx - g * v * ufl.ds
        # Apply Dirichlet boundary condition
        def on_boundary(x):
            return np.isclose(np.sqrt(x[0]**2 + x[1]**2), 1)
        #boundary_facets = facet_indices[np.where(facet_values == GROUP_NAMES["Boundary"])]
        boundary_dofs = fem.locate_dofs_geometrical(self.V_scalar, on_boundary)
        u_bc = fem.Function(self.V_scalar)
        with u_bc.vector.localForm() as loc:
            loc.set(5.0)
        boundary_condition = fem.dirichletbc(u_bc, boundary_dofs)
        # Pass to dolfinx and solve
        print(point)
        # bcs = self.fix_cell_value(point[0])
        problem = ConstrainedLinearProblem(a, L, self.V_scalar)
        #problem = LinearProblem(a, L, petsc_options={"ksp_type": "preonly", "pc_type": "lu"} )
        #problem = FixedPointProblem(a, L, self.V_scalar, bcs=bcs)
        self.uh = problem.solve()
        return np.array(self.uh.vector)
# if __name__ == "__main__":
#     model = DiskFEMModel("cylinders.msh")
#     point = np.expand_dims(np.array([[20, 10, 10]], dtype=np.float64), 0)
#     cell_material = model.point_to_cell_material(point[0])
#     print(cell_material, "\n", model.point_to_conductivity(point[0]))
#     uh = model.solve_for_point(point)
#     print(uh)
#     print(np.nonzero(uh))
Pay attention at the ConstrainedProblem definition that essentially adds the removal of the nullspace from a regular linear problem.
The main topic of my question is the following. If I use this solution to solve the PDE my results look strange. Here follows a source function and the solution just by ensuring the integral of u is zero using the nullspace trick.
solution: image0sol.png - Google Drive
Now these are the results when I enforce the source function to have integral 0 as per the 1st condition for the pure neumann condition poisson.
solution: image1sol.png - Google Drive
I am not sure if both results are correct. I can understand just enforcing the 2nd condition can be enough to have a well-posed problem, but what does this mean physically and why do the results look so different.
Another question is how does this solution differ from the solution using fenics and a lagrangian constraint.
Thank you
The post I am reffering to is this
https://fenicsproject.org/olddocs/dolfin/1.6.0/python/demo/documented/neumann-poisson/python/documentation.html . As I could not add more links on the original post .
See for instance:
that implements the Lagrange multiplier/real space formulation in DOLFINx v0.8.0 and for dolfinx nightly.
As for your encountered issues, I would strongly advise you to reduce the amount of code to a bare minimum. There is a lot of code in your post that surely doesn’t relate to «just» solving the singular Poisson equation.
There is also a singular poisson formulation available at
Thanks. This helped quite a lot. Regardless my code I would like to reformulate my questions in a theoretical manner.
  1. Are there any non-trivial differences when formulating the pure-neumann poisson with the lagrange multiplier vs the removal of the nullspace?
  2. In this the post https://fenicsproject.org/olddocs/dolfin/1.6.0/python/demo/documented/neumann-poisson/python/documentation.html . The following is stated
This condition is not satisfied by the specific right-hand side chosen for this test problem, which means that the partial differential equation is not well-posed. However, the variational problem expressed below is well-posed as the Lagrange multiplier introduced to satisfy the condition ∫Ωudx=0∫Ωudx=0 effectively redefines the right-hand side such that it safisfies the necessary condition ∫Ωfdx=−∫∂Ωgds∫Ωfdx=−∫∂Ωgds.
The lagrange multiplier does force the compability condition. Does using the approach of the removal of the nullspace also ensures the condition?
On a linear algebra level the formulations are very different.
Removing the null-space using PETSc ensures that you can solve your problem consistently, see: KSP: Linear System Solvers — PETSc v3.21.5-632-g6e9ef3a988d documentation
Solving Singular Systems
Sometimes one is required to solver singular linear systems. In this case, the system matrix has a nontrivial null space. For example, the discretization of the Laplacian operator with Neumann boundary conditions has a null space of the constant functions. PETSc has tools to help solve these systems. This approach is only guaranteed to work for left preconditioning (see KSPSetPCSide()); for example it may not work in some situations with KSPFGMRES.
First, one must know what the null space is and store it using an orthonormal basis in an array of PETSc Vecs. The constant functions can be handled separately, since they are such a common case. Create a MatNullSpace object with the command
I would suggest reading: https://open.clemson.edu/cgi/viewcontent.cgi?article=5105&context=all_theses
