I’m trying to use a .msh file generated from a .geo file, reading it in using gmshio.read_from_msh. Everything works until it is time to solve the problem (Stokes flow), when the program crashes giving ‘Segmentation fault: 11’ or ‘Bus error:10’. Output below:
Info : Reading 'basic_box_pillar_from_2d.msh'...
Info : 33 entities
Info : 12397 nodes
Info : 14688 elements
Info : Done reading 'basic_box_pillar_from_2d.msh'
Setting up variational problem
Solving Stokes flow
Bus error: 10
I have seen a similar issue in another post:
And I guess I’m looking to see if my error can be replicated in other folks’ installations of fenicsx.
The gmsh (4.13) and fenicsx (v0.8) are shown below:
GMSH (.geo)
SetFactory("OpenCASCADE");
// Element parameters
lc_coarse = 0.1;
lc_med = 0.08;
lc_fine = 0.04;
// Geometry
L = 6.0;
W = 1.0;
H = 0.25;
// Number of layers in extrusion
n_layers = Round(H/lc_fine);
x_min = -2.0;
x_max = x_min + L;
y_min = -0.5*W;
y_max = 0.5*W;
// Build geometry
Rectangle(1) = {x_min, y_min, 0, L, W, 0};
Circle(5) = {0, 0, 0, 0.25, 0, 2*Pi};
Curve Loop(2) = {3, 4, 1, 2};
Curve Loop(3) = {5};
// Form plane with hole for cylinder
Plane Surface(2) = {2, 3};
Recursive Delete {
Curve{3};
Recursive Delete {
Surface{1};
// Set element size over entire domain
Field[1] = Box;
Field[1].VIn = lc_med;
Field[1].VOut = lc_coarse;
Field[1].XMax = x_max*1.1;
Field[1].XMin = x_min*1.1;
Field[1].YMax = y_max*1.1;
Field[1].YMin = y_min*1.1;
// Set refined element size near cylinder
Field[2] = Box;
Field[2].VIn = lc_fine;
Field[2].VOut = lc_med;
Field[2].XMax = 1;
Field[2].XMin = -0.5;
Field[2].YMax = y_max*1.1;
Field[2].YMin = y_min*1.1;
// Set background mesh
Field[3] = Min;
Field[3].FieldsList = {1, 2};
Background Field = 3;
Mesh.Algorithm = 8;
Recombine Surface{2};
Extrude {0, 0, H} {
Surface{2}; Layers {n_layers}; Recombine;
Physical Volume("fluid") = {1};
Physical Surface("inlet") = {4};
Physical Surface("outlet") = {6};
Physical Surface("walls") = {2,3,5,7,8};
FENICSX CODE (using an msh file from the above called ‘basic_box_pillar_from_2d.msh’
#!/usr/bin/env python
import os
os.environ['OMP_NUM_THREADS'] = '1'
from dolfinx import fem, io, mesh, plot, log
from dolfinx.fem import Constant, Function, form, Expression
from dolfinx.fem import functionspace
from dolfinx.io import XDMFFile, gmshio
from ufl import dx, grad, inner, TestFunctions, TrialFunctions, dot, div
comm = MPI.COMM_WORLD
# Read in mesh
msh, _, ft = gmshio.read_from_msh('basic_box_pillar_from_2d.msh', comm, 0, 3)
ft.name = 'Facet markers'
if comm.rank == 0:
print('Setting up variational problem', flush=True)
# P1-P1 elements with GLS/Grad-Div stabilization
P1_v = element('Lagrange', msh.basix_cell(), 1, shape=(msh.geometry.dim,))
P1_p = element('Lagrange', msh.basix_cell(), 1)
MX = mixed_element([P1_v, P1_p])
W = functionspace(msh, MX)
# No slip condition on walls (meshtag 4)
W0,_ = W.sub(0).collapse()
noslip = Function(W0)
wall_dofs = fem.locate_dofs_topological((W.sub(0), W0), msh.topology.dim-1, ft.find(4))
bc_walls = fem.dirichletbc(noslip, dofs=wall_dofs, V=W.sub(0))
# Use inlet of all 1's for now
def inlet_velocity_expr(x):
zero_val = np.zeros(x.shape[1], dtype=np.float64)
one_val = np.ones(x.shape[1], dtype=np.float64)
return (one_val, zero_val, zero_val)
# Inlet velocity of 1's for now (meshtag 2)
inlet_velocity = Function(W0)
inlet_velocity.interpolate(inlet_velocity_expr)
inlet_dofs = fem.locate_dofs_topological((W.sub(0), W0), msh.topology.dim-1, ft.find(2))
bc_inlet = fem.dirichletbc(inlet_velocity, dofs=inlet_dofs, V=W.sub(0))
# Outlet pressure condition of 0 (meshtag 3)
W0,_ = W.sub(1).collapse()
outflow_pressure = Function(W0)
outlet_dofs = fem.locate_dofs_topological((W.sub(0), W0), msh.topology.dim-1, ft.find(3))
bc_outlet = fem.dirichletbc(outflow_pressure, dofs=outlet_dofs, V=W.sub(1))
bcs = [bc_walls, bc_inlet, bc_outlet]
# STOKES FLOW
W0 = W.sub(0)
Q, _ = W0.collapse()
(v, q) = ufl.TestFunctions(W)
f = Function(Q)
# GLS Stabilization parameter
h = ufl.CellDiameter(msh)
Beta = 0.1 # Seems ok for 3D
mu_T = Beta*h*h # Stabilization coefficient
# Stokes flow residual
a -= inner(p, div(v)) * dx
a += inner(div(u), q) * dx
L = inner(f,v) * dx
# Stabilization terms
a += mu_T*inner(grad(p), grad(q)) * dx # GLS
L -= mu_T * inner(f, grad(q)) * dx # GLS
a += 1.0 * inner(div(u), div(v)) * dx # Grad-Div
problem = LinearProblem(a, L, bcs = bcs)
u_stokes = problem.solve()
