Thank you for your response and your time !
Yes, my problem is almost like this. More precisely, the design variable alpha is defined throughout the rectangular domain of length 1, while my objective function is calculated only on a vertical line at x=0.9 (i.e. close to the output). But I’d like the optimiser to be able to change the value of alpha only upstream (i.e. x < 0.80 for example).
For the moment, I’ve applied an inequality constraint which consists of having an average of alpha = 1 at the output so that the optimiser is obliged to leave fluid there. However, I’ve found quite a few papers that separate the optimisation zone from the objective zone but using fenics and ipopt I’ve found this, it’s not exactly like me but they manage to disable zones of the optimiser: Topology optimization of subsonic compressible flows | Structural and Multidisciplinary Optimization
Here are the main stages of my code, which I think will be of interest to you:
## The Mesh
mesh = RectangleMesh(Point(x_min, y_min), Point(x_max, y_max), N_mesh, 300, diagonal)
## Define sub-domain for BC and Optimizer
class Inlet(SubDomain):
return on_boundary and (x[0] == x_min)
class Outlet(SubDomain):
return on_boundary and (x[0] == x_max)
class Walls(SubDomain):
return on_boundary and (x[1] == y_min or x[1] == y_max)
class Section_Obj(SubDomain):
return (x[0] >= 0.9 * x_max-0.05) and (x[0] <= 0.9 * x_max+0.05)
class UpstreamZone(SubDomain):
return (x[0] > 0.9 * x_max-0.1)
marker_numbers = {'unset' : 0, 'wall' : 1, 'inlet' : 2, 'outlet' : 3, 'section_obj' : 4}
boundary_markers = MeshFunction('size_t', mesh, mesh.topology().dim() - 1)
boundary_markers.set_all(marker_numbers['unset'])
Walls().mark(boundary_markers, marker_numbers['wall'])
Inlet().mark(boundary_markers, marker_numbers['inlet'])
Outlet().mark(boundary_markers, marker_numbers['outlet'])
domains = MeshFunction("size_t", mesh, mesh.topology().dim())
domains2 = MeshFunction("size_t", mesh, mesh.topology().dim())
domains.set_all(0)
domains2.set_all(0)
Section_Obj().mark(domains, 6) # Objective section
UpstreamZone().mark(domains2,7) #Optimizer section
dx = Measure('dx', domain=mesh, subdomain_data=domains)
dx2 = Measure('dx', domain=mesh, subdomain_data=domains2)
## NS weak form
I_ = as_tensor(np.eye(2)); sigma = -p*I_ + mu_*(grad(v) + grad(v).T);
F_PV = (rho_ * inner(v - v_prev1, w_v) / dt * dx
+ rho_ * (inner(grad(v) * v_prev1, w_v)+ inner(grad(v_prev1) * v, w_v)- inner(grad(v_prev1) * v_prev1, w_v)) * dx
+ div(v) * w_p * dx
+ inner(grad(w_v), sigma) * dx
+ inner(k(alpha) * v, w_v) * dx)
dF = derivative(F, u); problem = NonlinearVariationalProblem(F, u, bcs, dF)
solver.solve()
## Objective function
J = assemble(w_ud*dot(v - u_target, v - u_target) * dx(6) + inner(k(alpha) * v, v)*dx)
##Optimizer
alpha_C = Control(alpha)
Jhat = ReducedFunctional(J, alpha_C, derivative_cb_post = derivative_cb_post)
problem_min = MinimizationProblem(Jhat, bounds = (0.0, 1.0), constraints = [UFLInequalityConstraint((alpha-1)*dx2(7), alpha_C)])
max_iterations = 50 if idx == 0 else 150
tol = 1e-6
solver_opt = IPOPTSolver(problem_min, parameters = {'maximum_iterations': max_iterations, 'tol':tol, 'print_level' : 5,'linear_solver' : 'ma86' })
# Perform topology optimization
alpha_opt = solver_opt.solve()
Have a nice day !
