I know this has been asked - and solved - before in dolfin (i.e. https://fenicsproject.org/qa/11448/assign-values-to-function-in-parallel), however I haven’t figured out how to do this in the recent dolfin-x version as there is no HDF5File(…) read function anymore.
Consider the following MWE. I have a data text file with 3 components per DOF and want to assign these to a vector function living in a CG1 function space.
Problem: Executing this in parallel does not yield the same vector field as in serial.
#!/usr/bin/env python3
from dolfinx import BoxMesh, VectorFunctionSpace, Function
import dolfinx.cpp.mesh
from numpy import loadtxt
from ufl import sin, cos
comm = MPI.COMM_WORLD
mode = 'parallel' # serial, parallel
mesh = BoxMesh(comm, [np.array([0.0, 0.0, 0.0]),np.array([2.0, 1.0, 1.0])], [5, 5, 5],
dolfinx.cpp.mesh.CellType.tetrahedron, dolfinx.cpp.mesh.GhostMode.none)
V = VectorFunctionSpace(mesh, ("CG", 1))
# generate some data
filename = 'tmp/data.txt'
fl = open(filename, 'wt')
# one vector per node
for i in range(int(V.dim/3)):
x, y, z = sin(i), cos(i), 1.0
fl.write(str(x) + " " + str(y) + " " + str(z) + "\n")
fl.close()
# load data - V.dim x 3 array
data = loadtxt('tmp/data.txt')
# roll out to 3*V.dim x 1 array
data_flat = data.flatten()
# function to be filled with data
f0 = Function(V, name="fiber")
# set function
f0.vector[:] = data_flat
# write mesh and function
with XDMFFile(comm,'tmp/tmp_'+mode+'.xdmf','w') as outfile:
#mesh.topology.create_connectivity_all() # Not sure if needed? Does not change output...
outfile.write_mesh(mesh)
outfile.write_function(f0)
So I guess in parallel, the DOFs are re-ordered and do not correspond to the ordering of the text file anymore. How can I know how this ordering happens so that I can map between the initial sorting and the new one?
I would appreciate if somebody has a solution to this!
Thanks,
Marc
