Set values of PETScVector from numpy array
How can I set the values of a variable of type PETScVector from a numpy array?
This is a very general question, whose answer depend on a few things:
  • what version of fenics are you using?
  • should your code work in parallel, if so, how is the numpy array distributed?
To answer the questions above, please provide a minimal reproducible example.
  • FEniCS 2019.1.0
  • not parallel
(not reproducible) code is like this:
def func(u)
ā€œā€"
u is a PETScVector
ā€œā€"
u_t = func_returning _numpy_array()
I need to fill u with the values in u_t
u.set_local(u_t) should do it.
Thanks dokken. I passed many times by set_local in the documentation but was not sure about using it.
Thanks.
