Setting scalar function for BDM boundary condition with controlled flux [mixed Poisson]
I’m interested in systems with controlled flux at the boundary. As I understand the divergence-conforming elements such as BDM (or Raviart-Thomas) are a natural choice for this. Following the example of the mixed Poisson demo, the boundary condition for vector-valued function \sigma is
\sigma \cdot n = g \; \mathrm{on\ } \Gamma_N
so the flux (normal component) at the boundary is determined by scalar function g.
What I want is a symmetric solution with the same scalar function g applied at top and bottom.
But in the mixed Poisson demo the boundary condition is implemented as a vector-valued Dirichlet BC, rather than the scalar function g directly. To try to understand how it is applied, I modified the demo to set a constant value 1 at the top and bottom, via
    values[1, :] = 1
for both f1 and f2, equivalent to applying the same f1 to both the top and bottom boundaries. This does not obtain a symmetric solution. A cross section of u in the y-direction is
The vector-valued Dirichlet BC is applied literally, giving a vector value +1 in the y direction both at top and bottom.
What I want is the same flux “into” the domain, so the vector value at the bottom should be opposite (negative) to the top. That is, I want to control the boundary with scalar function g only, with direction determined by the normal vector.
In the case of the mixed Poisson demo, I can obtain the desired symmetric solution by manually setting the value to -1 in f2 (modified code below).
But that does not extend well to the case of applying a simple scalar boundary condition (for the normal component) over a complex boundary?
How should a scalar function g be applied as a BDM boundary condition?
Modified mixed Poisson demo:
from dolfinx import fem, io, mesh
from dolfinx.fem import Function
from ufl import (Measure, SpatialCoordinate, TestFunctions, TrialFunctions,
                 div, exp, inner)
domain = mesh.create_unit_square(MPI.COMM_WORLD, 32, 32, mesh.CellType.quadrilateral)
k = 1
Q_el = element("BDMCF", domain.basix_cell(), k)
P_el = element("DG", domain.basix_cell(), k - 1)
V_el = mixed_element([Q_el, P_el])
V = fem.functionspace(domain, V_el)
(sigma, u) = TrialFunctions(V)
(tau, v) = TestFunctions(V)
x = SpatialCoordinate(domain)
f = 10.0 * exp(-((x[0] - 0.5) * (x[0] - 0.5) + (x[1] - 0.5) * (x[1] - 0.5)) / 0.02)
dx = Measure("dx", domain)
a = inner(sigma, tau) * dx + inner(u, div(tau)) * dx + inner(div(sigma), v) * dx
L = -inner(f, v) * dx
facets_top = mesh.locate_entities_boundary(domain, fdim, lambda x: np.isclose(x[1], 1.0))
Q, _ = V.sub(0).collapse()
dofs_top = fem.locate_dofs_topological((V.sub(0), Q), fdim, facets_top)
def f1(x):
    values = np.zeros((2, x.shape[1]))
    values[1, :] = 1
    return values
f_h1 = fem.Function(Q)
f_h1.interpolate(f1)
bc_top = fem.dirichletbc(f_h1, dofs_top, V.sub(0))
facets_bottom = mesh.locate_entities_boundary(domain, fdim, lambda x: np.isclose(x[1], 0.0))
dofs_bottom = fem.locate_dofs_topological((V.sub(0), Q), fdim, facets_bottom)
def f2(x):
    # setting the same value as f2
    # gives an asymmetric solution, not desired
    #values[1, :] = 1
    # gives the desired symmetric solution
    # but can this be done using a simple scalar value
    # of the normal component in any direction?
    values[1, :] = -1
    return values
f_h2 = fem.Function(Q)
f_h2.interpolate(f2)
bc_bottom = fem.dirichletbc(f_h2, dofs_bottom, V.sub(0))
bcs = [bc_top, bc_bottom]
problem = LinearProblem(a, L, bcs=bcs, petsc_options={"ksp_type": "preonly", "pc_type": "lu",
                                                      "pc_factor_mat_solver_type": "mumps"})
try:
    w_h = problem.solve()
except PETSc.Error as e:  # type: ignore
    if e.ierr == 92:
        print("The required PETSc solver/preconditioner is not available. Exiting.")
        print(e)
        exit(0)
        raise e
sigma_h, u_h = w_h.split()
with io.XDMFFile(domain.comm, "out_mixed_poisson/u.xdmf", "w") as file:
    file.write_mesh(domain)
    file.write_function(u_h)
Vl = fem.functionspace(domain, ("Lagrange", k, (domain.geometry.dim,)))
sigmal_h = Function(Vl)
sigmal_h.interpolate(sigma_h)
with io.VTXWriter(domain.comm, "out_mixed_poisson/sigmal.bp", sigmal_h) as file:
    file.write(0)
Since the dofs are associated with an edge, I would probably project the Facet normal into the space, using code similar to: dolfinx_mpc/python/dolfinx_mpc/utils/mpc_utils.py at afa9fd51eb7deb8098469fcb3b9185c4ce3099c0 · jorgensd/dolfinx_mpc · GitHub
Here is a version (i bashed it together quickly, so there could be typos):
from dolfinx import fem, io, mesh, fem, cpp
                 div, exp, inner)
def facet_normal_approximation(V):
    Approximate the facet normal by projecting it into the function space for a set of facets
    Args:
        V: The function space to project into
    n = ufl.FacetNormal(V.mesh)
    nh = fem.Function(V)
    ds = ufl.ds(domain=V.mesh)
    a = (ufl.inner(u, v) * ds)
    L = ufl.inner(n, v) * ds
    # Find all dofs that are not boundary dofs
    imap = V.dofmap.index_map
    all_blocks = np.arange(imap.size_local, dtype=np.int32)
    boundary_facets = mesh.exterior_facet_indices(V.mesh.topology)
    top_blocks = fem.locate_dofs_topological(
        V, V.mesh.topology.dim - 1, boundary_facets)
    deac_blocks = all_blocks[np.isin(all_blocks, top_blocks, invert=True)]
    # Note there should be a better way to do this
    # Create sparsity pattern only for constraint + bc
    bilinear_form = fem.form(a)
    pattern = fem.create_sparsity_pattern(bilinear_form)
    pattern.insert_diagonal(deac_blocks)
    pattern.finalize()
    u_0 = fem.Function(V)
    u_0.vector.set(0)
    bc_deac = fem.dirichletbc(u_0, deac_blocks)
    A = cpp.la.petsc.create_matrix(V.mesh.comm, pattern)
    A.zeroEntries()
    # Assemble the matrix with all entries
    form_coeffs = cpp.fem.pack_coefficients(bilinear_form._cpp_object)
    form_consts = cpp.fem.pack_constants(bilinear_form._cpp_object)
    cpp.fem.petsc.assemble_matrix(A, bilinear_form._cpp_object,
                                  form_consts, form_coeffs, [bc_deac._cpp_object])
    if bilinear_form.function_spaces[0] is bilinear_form.function_spaces[1]:
        A.assemblyBegin(PETSc.Mat.AssemblyType.FLUSH)  # type: ignore
        A.assemblyEnd(PETSc.Mat.AssemblyType.FLUSH)  # type: ignore
        cpp.fem.petsc.insert_diagonal(A, bilinear_form.function_spaces[0], [
            bc_deac._cpp_object], 1.0)
    linear_form = fem.form(L)
    b = fem.petsc.assemble_vector(linear_form)
    fem.petsc.apply_lifting(b, [bilinear_form], [[bc_deac]])
    b.ghostUpdate(addv=PETSc.InsertMode.ADD_VALUES,
                  mode=PETSc.ScatterMode.REVERSE)  # type: ignore
    fem.petsc.set_bc(b, [bc_deac])
    # Solve Linear problem
    solver = PETSc.KSP().create(V.mesh.comm)  # type: ignore
    solver.setType("cg")
    solver.rtol = 1e-8
    solver.setOperators(A)
    solver.solve(b, nh.vector)
    nh.vector.ghostUpdate(addv=PETSc.InsertMode.INSERT,
                          mode=PETSc.ScatterMode.FORWARD)  # type: ignore
    return nh
k = 1
a = inner(sigma, tau) * dx + inner(u, div(tau)) * \
nh = facet_normal_approximation(Q)
bc_top = fem.dirichletbc(nh, dofs_top, V.sub(0))
bc_bottom = fem.dirichletbc(nh, dofs_bottom, V.sub(0))
try:
    if e.ierr == 92:
        print(e)
        exit(0)
        raise e
Vl = fem.functionspace(domain, ("DG", k+1, (domain.geometry.dim,)))
with io.VTXWriter(domain.comm, "out_mixed_poisson/sigmal.bp", sigmal_h, engine="BP4") as file:
    file.write(0)
giving
Please let me know if this helps.
The issue atm is the facet normal approximated at the corner. that would need some better treatment.
@dparsons I improved the facet representations a bit, but it doesn’t seem to be sufficient:
                 div, exp, inner)
def facet_normal_approximation(V, mt: mesh.MeshTags, mt_id: int):
    Args:
    ds = ufl.ds(domain=V.mesh, subdomain_data=mt, subdomain_id=mt_id)
    a = ufl.inner(u, v) * ds
        V, V.mesh.topology.dim - 1, mt.find(mt_id))
    pattern.finalize()
    u_0.vector.set(0)
    A.zeroEntries()
    b.ghostUpdate(addv=PETSc.InsertMode.INSERT,
    solver.rtol = 1e-8
    return nh
k = 1
vals_top = np.full_like(facets_top, 3, dtype=np.int32)
vals_bottom = np.full_like(facets_bottom, 7, dtype=np.int32)
all_facets = np.hstack([facets_top, facets_bottom])
sort = np.argsort(all_facets)
all_values = np.hstack([vals_top, vals_bottom])[sort]
mt = mesh.meshtags(domain, fdim, all_facets[sort], all_values)
dofs_top = fem.locate_dofs_topological((V.sub(0), Q), fdim, mt.find(3))
nh_top = facet_normal_approximation(Q, mt, 3)
bc_top = fem.dirichletbc(nh_top, dofs_top, V.sub(0))
dofs_bottom = fem.locate_dofs_topological((V.sub(0), Q), fdim, mt.find(7))
nh_bot = facet_normal_approximation(Q, mt, 7)
bc_bottom = fem.dirichletbc(nh_bot, dofs_bottom, V.sub(0))
try:
    if e.ierr == 92:
        print(e)
        exit(0)
        raise e
n_out = Function(Vl)
n_out.name = "nh_top"
n_out.interpolate(nh_top)
n_b = Function(Vl)
n_b.name = "nh_bottom"
n_b.interpolate(nh_bot)
with io.VTXWriter(domain.comm, "out_mixed_poisson/sigmal.bp", [sigmal_h, n_out, n_b], engine="BP4") as file:
    file.write(0)
I guess a more robust approach would be to push the facet normal forward to the physical domain with Piola map, as shown in: Setting boundary conditions on H(div) spaces defined on general meshes - #2 by dokken
Let’s see if I have further time to look at this soon.
Thanks for that. The idea makes sense, generating the complex boundary vector function which is to be used as the Direchlet BC for the BDM vector function.
I gather an alternative approach could be to impose the condition in weak form via Nitsche’s method. Would be interesting to see how the two approaches compare.
I apologise for being a bit obtuse, but I have to ask, where is the actual scalar function here? There is the function u_0, but it is set to 0. There is the constant 1.0 in
but changing it does not change the value of the vector solution.
What the code above does is that it sets the boundary condition sigma = n where n is the facet normal (in physical space).
The Dirichlet bc in that function just inserts diagonal entries for all dofs not on a given boundary.
The justification behind my thoughts here is by looking at the basis functions: DefElement
I see it now. Multiplying that L by the value I need gives the control I’m looking for.
@dparsons @jackhale
I’ve made a prototype that leverages the dolfinx.fem.Expression support of facet entities (Support evaluation of facets in `dolfinx.fem.Expression` by jorgensd · Pull Request #3062 · FEniCS/dolfinx · GitHub) to do interpolation into spaces with integral moments.
See the following code for an example.
The code is a bit clunky, as I had to pull back points from the coordinate element to the reference facet, and there is an implicit assumption that for each bc, only a single facet from any cell is present (If you use multiple bcs to enforce the bc over multiple facets of a cell it will work (test the code below with a 1x1 unit square).
Maybe @mscroggs could comment on how we could make the interfacing with basix here less complicated.
Compute DirichletBC in normal direction on arbitrary domains
Author: Jørgen S. Dokken
Licenses:
- LGPL: 3.0 for `compute_exterior_facet_entities`
- All other code is licensed under MIT
import numpy.typing as npt
def compute_exterior_facet_entities(mesh, facets):
    """Helper function to compute (cell, local_facet_index) pairs for exterior facets
    Licensed under LGPL: 3.0, part of DOFLINx, https://github.com/FEniCS/dolfinx/
    tdim = mesh.topology.dim
    mesh.topology.create_connectivity(tdim - 1, tdim)
    mesh.topology.create_connectivity(tdim, tdim - 1)
    c_to_f = mesh.topology.connectivity(tdim, tdim - 1)
    f_to_c = mesh.topology.connectivity(tdim - 1, tdim)
    integration_entities = np.empty(2 * len(facets), dtype=np.int32)
    for i, facet in enumerate(facets):
        cells = f_to_c.links(facet)
        assert len(cells) == 1
        cell = cells[0]
        local_facets = c_to_f.links(cell)
        local_pos = np.flatnonzero(local_facets == facet)
        integration_entities[2 * i] = cell
        integration_entities[2 * i + 1] = local_pos[0]
    return integration_entities
def create_normal_contribution_bc(Q: dolfinx.fem.FunctionSpace, expr: ufl.core.expr.Expr,  facets: npt.NDArray[np.int32]) -> dolfinx.fem.Function:
    Create function representing normal vector
    SPDX-License-Identifier:    MIT
    domain = Q.mesh
    Q_el = Q.element
    # Compute integration entities (cell, local_facet index) for all facets
    boundary_entities = compute_exterior_facet_entities(domain, facets)
    interpolation_points = Q_el.basix_element.x
    c_el = domain.ufl_domain().ufl_coordinate_element()
    ref_top = c_el.reference_topology
    ref_geom = c_el.reference_geometry
    cell_to_facet = {"interval": "vertex",
                     "triangle": "interval", "quadrilateral": "interval",
                     "tetrahedron": "triangle", "hexahedron": "quadrilateral"}
    # Pull back interpolation points from reference coordinate element to facet reference element
    facet_cmap = element(
        "Lagrange", cell_to_facet[domain.topology.cell_name()], c_el.degree, shape=(domain.geometry.dim, ), dtype=np.float64)
    facet_cel = dolfinx.cpp.fem.CoordinateElement_float64(
        facet_cmap.basix_element._e)
    reference_facet_points = None
    for i, points in enumerate(interpolation_points[fdim]):
        geom = ref_geom[ref_top[fdim][i]]
        ref_points = facet_cel.pull_back(points, geom)
        # Assert that interpolation points are all equal on all facets
        if reference_facet_points is None:
            reference_facet_points = ref_points
            assert np.allclose(reference_facet_points, ref_points)
    # Create expression for BC
    normal_expr = dolfinx.fem.Expression(
        expr, reference_facet_points)
    points_per_entity = [sum(ip.shape[0] for ip in ips)
                         for ips in interpolation_points]
    offsets = np.zeros(domain.topology.dim+2, dtype=np.int32)
    offsets[1:] = np.cumsum(points_per_entity[:domain.topology.dim+1])
    values_per_entity = np.zeros(
        (offsets[-1], domain.geometry.dim), dtype=dolfinx.default_scalar_type)
    entities = boundary_entities.reshape(-1, 2)
    values = np.zeros(entities.shape[0]*offsets[-1]*domain.geometry.dim)
    for i, entity in enumerate(entities):
        insert_pos = offsets[fdim] + \
            reference_facet_points.shape[0] * entity[1]
        normal_on_facet = normal_expr.eval(domain, entity)
        values_per_entity[insert_pos: insert_pos + reference_facet_points.shape[0]
                          ] = normal_on_facet.reshape(-1, domain.geometry.dim)
        values[i*offsets[-1] *
               domain.geometry.dim: (i+1)*offsets[-1]*domain.geometry.dim] = values_per_entity.reshape(-1)
    qh = dolfinx.fem.Function(Q)
    qh._cpp_object.interpolate(
        values.reshape(-1, domain.geometry.dim).T.copy(), boundary_entities[::2].copy())
    qh.x.scatter_forward()
    return qh
    MPI.COMM_WORLD, 13, 15, mesh.CellType.quadrilateral)
k = 2
expr = ufl.FacetNormal(domain)
nh_top = create_normal_contribution_bc(Q, expr,  mt.find(3))
nh_bot = create_normal_contribution_bc(Q, expr, mt.find(7))
w_h = dolfinx.fem.Function(V)
dolfinx.fem.set_bc(w_h.x.array, bcs)
w_h.x.scatter_forward()
sigmal_h = fem.Function(Vl)
n_out = fem.Function(Vl)
n_b = fem.Function(Vl)
with io.VTXWriter(domain.comm, "test.bp", [sigmal_h, n_out, n_b], engine="BP4") as file:
    file.write(0)
Thanks. I’ll see how it fits with what we (think we) want.
Note that any scaling of the normal now falls into expr, so multiplying by a scalar/constant or dolfinx.fem.Function here should do the trick.
This is really useful, thanks!
Finally checking the pattern here against what I need, it’s not what I thought I wanted, but it’s exactly what I need. I thought I wanted control of total flux (which in different applications I do want). But in some systems the total flux has multiple components, e.g. total electrical current in semiconductors, j_{tot} = j_{electrons} + j_{holes}. If the separate fluxes are what’s being evaluated explicity, then that total current condition needs to be imposed as a separate term.
But what I really wanted was surface source terms for each component (e.g. a photoactive surface generating electrons and holes), for which the solution here is perfect. The “controlled flux” comes from the rate of generation of the electrons and holes.
I’ll probably make this a convenience function within scifem next week, and maybe discuss with Jack, Matthew, Chris and Garth if we could add it to DOLFINx, or smooth out how to do this nicely within the core.
postscriptum
It’s actually relatively trivial to impose this flux BC weakly, with or without Nitsche’s penalty parameter.
And that’s what you’d need to do anyway if the condition depends on the solution. For instance a surface reaction flux is determined by reactant concentrations at the surface. In particular it would be needed for a time-dependent boundary in a stiff system that requires the implicit (backward) Euler method to update the value for the next time step.
It can be done either as a vector condition (the condition discussed above in this thread), or directly as the normal projection, which is arguably more direct.
  • vector
    strong form: σ=σ_{norm} on Γ_N, where σ_{norm} must be constructed such that σ_{norm}⋅n=g
    (the question addressed above).
    weak form: \int_{Γ_N} σ \cdot τ~ ds = \int_{Γ_N} σ_{norm}\cdot τ~ ds ~~ \forall τ (τ is the vector test function)
  • normal
    strong form: σ⋅n=g on Γ_N
    weak form: \int_{Γ_N} (σ \cdot n) (τ \cdot n)~ds = \int_{Γ_N} g (τ \cdot n)~ds ~~ \forall τ
In the latter “normal” method, I’m multiplying by the scalar term term (τ \cdot n) instead of the vector test function τ. Intuitively I think this should be right, and it does work. But I don’t know how to prove that it’s exactly equivalent to the “vector” method. I don’t think integration by parts or the divergence theorem gets you from one to the other. I would be interested to hear if anyone knows the formal mathematics to prove it.
Here is my original example from above, modified for weak imposition of this Dirichlet boundary flux. I included both the “vector” and “normal” versions, set by weak_type (here set to “normal”).
The normal method seems to be more accurate, in the sense that the cross-section in the y-direction of the y-component of σ is slightly but noticeably less smooth in the vector method compared to the normal method. Likely @dokken’s create_normal_contribution_bc would improve that for the weak formulation of the vector method.
The weak condition solves with or without a (Nitsche**) penalty parameter, but the solution is better (with a boundary value closer to the target value) if it is used. I used h = CellDiameter since the Circumradius used at Weak imposition of Dirichlet conditions for the Poisson problem — FEniCSx tutorial is not defined for the quadrilateral CellType used here.
# https://fenicsproject.discourse.group/t/setting-scalar-function-for-bdm-boundary-condition-with-controlled-flux-mixed-poisson/13508
from dolfinx import fem, io, mesh, default_scalar_type
from ufl import (CellDiameter, FacetNormal, Measure, SpatialCoordinate, TestFunctions, TrialFunctions,
                 div, exp, inner)
#weak_type="vector"
weak_type="normal"
top_boundary = lambda x: np.isclose(x[1], 1.0)
bottom_boundary = lambda x: np.isclose(x[1], 0.0)
top_bc_i = 1
bottom_bc_i = 2
boundaries = [(top_bc_i, top_boundary),
              (bottom_bc_i, bottom_boundary)]
    facets = mesh.locate_entities(domain, fdim, locator)
    facet_indices.append(facets)
facet_tag = mesh.meshtags(domain, fdim, facet_indices[sorted_facets], facet_markers[sorted_facets])
ds = Measure("ds", domain=domain, subdomain_data=facet_tag)
k = 1
boundary_flux_value = 1
def f1(x):
    values[1, :] = boundary_flux_value
    return values
def f2(x):
    #values[1, :] = boundary_flux_value
    values[1, :] = -boundary_flux_value
    return values
# impose BC weakly
bcs = []
# weak condition
n = FacetNormal(V.mesh)
# Nitsche penalty parameter
h = CellDiameter(domain)
alpha = fem.Constant(domain, default_scalar_type(10))
Nitsche_penalty = alpha/h
if weak_type == "vector":
    # weak condition as vector
    a += (Nitsche_penalty*inner(sigma, tau) * ds(top_bc_i)
          + Nitsche_penalty*inner(sigma, tau) * ds(bottom_bc_i))
    L += (Nitsche_penalty*inner(f_h1, tau) * ds(top_bc_i)
          + Nitsche_penalty*inner(f_h2, tau) * ds(bottom_bc_i))
    # weak condition as scalar normal projection
    boundary_flux = fem.Constant(domain, default_scalar_type(boundary_flux_value))
    a += (Nitsche_penalty*inner(sigma, n) * inner(tau,n)  * ds(top_bc_i)
          + Nitsche_penalty*inner(sigma, n) * inner(tau,n)  * ds(bottom_bc_i))
    L += (Nitsche_penalty*boundary_flux * inner(tau,n)  * ds(top_bc_i)
          + Nitsche_penalty*boundary_flux * inner(tau,n)  * ds(bottom_bc_i))
try:
    if e.ierr == 92:
        print(e)
        exit(0)
        raise e
with io.XDMFFile(domain.comm, f"out_mixed_poisson_weak_{weak_type}/u.xdmf", "w") as file:
with io.VTXWriter(domain.comm, f"out_mixed_poisson_weak_{weak_type}/sigmal.bp", sigmal_h) as file:
    file.write(0)
** I here I use a penalty parameter without Nitsche’s symmetry term. It is not clear what a symmetry term should be in this context)
@Stein 's work at Comput. Methods Appl. Mech. Engrg. 417 (2023) 116483 corroborates my idea to apply a vector Nitsche method via \int (α/h) (σ \cdot n) (τ · n) ds.
With respect to the symmetry term, I like his argument at Implementing Nitsche's method for perfect-slip BCs with a nontrivial normal vector - #11 by Stein , “You don’t care too much about the symmetry term”
To follow up on setting this strongly.
After some discussion with @cdaversin and @MiroK, I’ve reworked the strong imposition operator:
import basix.ufl
from dolfinx import default_scalar_type as dolfinx_default_scalar_type
from dolfinx.fem import (
    FunctionSpace,
    Function,
    Expression,
from dolfinx.cpp.fem import CoordinateElement_float64
from dolfinx.mesh import compute_incident_entities
def strong_bc_bdm_function(
    Q: FunctionSpace,
    facets: npt.NDArray[np.int32],
) -> Function:
    Create a function $u_h\in Q$ such that $u_h=\text{expr}$ for all dofs belonging
    to a subset of ``facets``. All other dofs are set to zero.
    Note:
        The resulting function  is only correct in the "normal" direction,
        i.e. :math:`u_{bc}\cdot n = expr`, while the tangential component is uncontrolled.
        This makes it hard to visualize the function when outputting it to file, either
        through interpolation to an appropriate DG space, or to a point-cloud.
    Args:
        Q: The function space to create the function $u_h$ in.
        expr: The expression to evaluate.
        facets: The facets on which to evaluate the expression.
    domain = Q.mesh
    Q_el = Q.element
    domain.topology.create_connectivity(fdim, domain.topology.dim)
    facet_types = set(basix.cell.subentity_types(domain.basix_cell())[fdim])
    assert len(facet_types) == 1, "All facets must have the same topology"
    facet_cmap = basix.ufl.element(
        "Lagrange",
        facet_types.pop(),
        c_el.degree,
        shape=(domain.geometry.dim,),
        dtype=np.float64,
    facet_cel = CoordinateElement_float64(facet_cmap.basix_element._e)
    normal_expr = Expression(expr, reference_facet_points)
    points_per_entity = [sum(ip.shape[0] for ip in ips) for ips in interpolation_points]
    offsets = np.zeros(domain.topology.dim + 2, dtype=np.int32)
    offsets[1:] = np.cumsum(points_per_entity[: domain.topology.dim + 1])
        (offsets[-1], domain.geometry.dim), dtype=dolfinx_default_scalar_type
    all_connected_cells = compute_incident_entities(
        domain.topology, facets, domain.topology.dim - 1, domain.topology.dim
    values = np.zeros(len(all_connected_cells) * offsets[-1] * domain.geometry.dim)
    domain.topology.create_connectivity(domain.topology.dim, fdim)
    c_to_f = domain.topology.connectivity(domain.topology.dim, fdim)
    num_facets_on_process = (
        domain.topology.index_map(fdim).size_local
        + domain.topology.index_map(fdim).num_ghosts
    is_marked = np.zeros(num_facets_on_process, dtype=np.int8)
    is_marked[facets] = 1
    for i, cell in enumerate(all_connected_cells):
        values_per_entity[:] = 0.0
        for j, lf in enumerate(local_facets):
            if not is_marked[lf]:
                continue
            insert_pos = offsets[fdim] + reference_facet_points.shape[0] * j
            # Backwards compatibility
            entity = np.array([[cell, j]], dtype=np.int32)
            try:
            except (AttributeError, AssertionError):
                normal_on_facet = normal_expr.eval(domain, entity.flatten())
            # NOTE: evaluate within loop to avoid large memory requirements
            values_per_entity[
                insert_pos : insert_pos + reference_facet_points.shape[0]
        values[
            i * offsets[-1] * domain.geometry.dim : (i + 1)
            * offsets[-1]
    qh = Function(Q)
        values.reshape(-1, domain.geometry.dim).T.copy(), all_connected_cells
    return qh
which now works with both v0.9.0 and the nightly branch, and added a note regarding visualizing the resulting BC function, as if you look at it, you need to remember that only the normal component is enforced, thus the tangential component at the boundaries will not be zero.
I also attach a code to illustrate this:
import basix.ufl
import basix
    functionspace,
    Function,
from dolfinx.mesh import (
    create_unit_cube,
    exterior_facet_indices,
from solver import strong_bc_bdm_function
N = 4
mesh = create_unit_cube(MPI.COMM_WORLD, N, N, N)
order = 2
element_u = basix.ufl.element(basix.ElementFamily.BDM, mesh.basix_cell(), order)
V = functionspace(mesh, element_u)
regions_facets = exterior_facet_indices(mesh.topology)
nh = ufl.FacetNormal(mesh)
inlet_expr = nh * (ufl.sin(x[0]) + x[1])
u_bc = strong_bc_bdm_function(V, inlet_expr, regions_facets)
from dolfinx.fem import locate_dofs_topological
bdofs = locate_dofs_topological(V, mesh.topology.dim - 1, regions_facets)
import basix.ufl
    Expression,
    IntegralType,
    functionspace,
    compute_integration_domains,
def move_to_facet_quadrature(ufl_expr, mesh, sub_facets, scheme="default", degree=6):
    fdim = mesh.topology.dim - 1
    # Create submesh
    bndry_mesh, entity_map, _, _ = dolfinx.mesh.create_submesh(mesh, fdim, sub_facets)
    # Create quadrature space on submesh
    q_el = basix.ufl.quadrature_element(
        bndry_mesh.basix_cell(), ufl_expr.ufl_shape, scheme, degree
    Q = functionspace(bndry_mesh, q_el)
    # Compute where to evaluate expression per submesh cell
    if hasattr(entity_map, "sub_topology_to_topology"):
        parent_entities = entity_map.sub_topology_to_topology(
            np.arange(bndry_mesh.topology.index_map(fdim).size_local, dtype=np.int32),
            inverse=False,
        id_args = {}
        id_args = {"dim": fdim}
    integration_entities = compute_integration_domains(
        IntegralType.exterior_facet, mesh.topology, parent_entities, **id_args
    ).reshape(-1, 2)
    try:
        compiled_expr = Expression(ufl_expr, Q.element.interpolation_points)
    except AttributeError:
        compiled_expr = Expression(ufl_expr, Q.element.interpolation_points())
    # Evaluate expression
    q = Function(Q)
    try:
        q.x.array[:] = compiled_expr.eval(mesh, integration_entities).reshape(-1)
    except TypeError:
        q.x.array[:] = compiled_expr.eval(mesh, integration_entities.flatten()).reshape(
            -1
    return q
exterior_facets = dolfinx.mesh.exterior_facet_indices(mesh.topology)
flux = u_bc
q = move_to_facet_quadrature(flux, mesh, exterior_facets, degree=8)
q.name = "u_at_quadrature"
import scifem
scifem.xdmf.create_pointcloud("flux.xdmf", [q])
V_DG = functionspace(mesh, ("DG", order + 1, (mesh.geometry.dim,)))
u_bc_DG = Function(V_DG)
u_bc_DG.interpolate(u_bc)
with VTXWriter(mesh.comm, "u_bc_vtx.bp", [u_bc_DG]) as vtx:
    vtx.write(0.0)
error = (
    ufl.inner(ufl.dot(u_bc, nh) * nh - inlet_expr, ufl.dot(u_bc, nh) * nh - inlet_expr)
    * ufl.ds
global_error = np.sqrt(
    mesh.comm.allreduce(
        dolfinx.fem.assemble_scalar(dolfinx.fem.form(error)), op=MPI.SUM
print("L2 error in normal component of u_bc:", global_error, flush=True)
which yields
L2 error in normal component of u_bc: 6.667253143399306e-05
when the scaling functions is not in the space, and machine precision if it is.
I will probably add this function to scifem, with an illustrative demo in 2D soon.
The function is now added to scifem (0.10.0) under the name:
interpolate_function_onto_facet_dofs
ref: API reference — scifem
with two tests at:
scifem/tests/test_bcs.py at v0.10.0 · scientificcomputing/scifem · GitHub
that checks normal and tangent enforcement.
