Hi everyone. I’m trying to solve the Poisson problem in a spherical shell; the outer sphere is a Dirichlet boundary, and the inner sphere is a Neumann boundary.
I want to specify the du/dn distribution at the inner boundary. I tried spherical harmonics to construct the distribution. The function is (I use sympy because I cannot find legendre in ufl package):
def magmap_IB(x,sph_file='SPHs/mrmqc_c2074.dat'):
# read the spherical harmonic coefficients
sphs_df = pd.read_csv(sph_file, header=None, sep='\s+', names=['l', 'm', 'glm', 'hlm'])
glm_array = np.zeros((61, 61))
hlm_array = np.zeros((61, 61))
for i in range(sphs_df.shape[0]):
glm_array[sphs_df['l'][i], sphs_df['m'][i]] = sphs_df['glm'][i]
hlm_array[sphs_df['l'][i], sphs_df['m'][i]] = sphs_df['hlm'][I]
import sympy as sp
cos_colat = x[2] / (x[0] ** 2 + x[1] ** 2 + x[2] ** 2) ** (1 / 2)
lon = ufl.acos(x[0] / ufl.sqrt(x[0] ** 2 + x[1] ** 2)) * ufl.sign(x[1]) + ufl.pi - ufl.sign(x[1]) * ufl.pi
l_max = 17
COSCOLAT,LON = sp.symbols('cos_colat,lon')
Br = 0
from ufl import sqrt,sin,cos
Br = sp.symbols('0.')
for i_l in range(l_max + 1):
for i_m in range(i_l + 1):
print('l: ', i_l, '; m:', i_m)
Plm = sp.assoc_legendre(i_l, i_m, COSCOLAT)\
* (2 * math.factorial(i_l - i_m)
/ math.factorial(i_l + i_m)) ** (1 / 2)
Br = Br + Plm * (glm_array[i_l, i_m] * sp.cos(i_m * LON)
+ hlm_array[i_l, i_m] * sp.sin(i_m * LON))
magmap = eval(str(Br))
return magmap
The main code is:
V = fem.FunctionSpace(msh, ('CG', 3))
u = ufl.TrialFunction(V)
# 边界自由度
inner_boundary_dof = fem.locate_dofs_topological(V=V, entity_dim=2, entities=inner_boundary)
outer_boundary_dof = fem.locate_dofs_topological(V=V, entity_dim=2, entities=outer_boundary)
phi0 = 0.
B0 = 100. * 1e-9
mu0 = 4 * np.pi * 1e-7
f = fem.Constant(msh, ScalarType(0))
# dirichlet B.C.
bc = fem.dirichletbc(value=ScalarType(phi0), dofs=outer_boundary_dof, V=V)
magmap = magmap_IB(x)
a = dot(grad(u), grad(v)) * dx
L = dot(f, v) * dx - dot(magmap, v) * ds
# Solve
ksp_type = 'gmres'
problem = fem.petsc.LinearProblem(a, L, bcs=[bc], petsc_options={'ksp_type': ksp_type})
uh = problem.solve()
My problems are:
(1) The code cannot work with spherical harmonics over L=17 (the error is as follows). Are there any functions in dolfinx that can generate and handle with legendre polynomials?
libffcx_forms_cb3037c64ed6c464f7c84f3d41225a03793c8870.c:59428:26: error: integer literal is too large to be represented in any integer type
sv_e0a[223] = -1 * ((495179769008019818390136611716089140625 * sv_e0a[2]) / 2) + (9738535457157723095006020030416419765625 * pow(sv_e0a[2], 3)) / 2;
(2) My plan B is to directly interpolate the distribution to the inner boundary. Is there a way in dolfinx to do that?
