Shape-mismatch between mixed-space mesh and the trial function
Hi Folks,
I’m new to FEniCSx and I’ve been trying learn to implement a coupled system of time-dependent equations using a mixed function space – in this case a 3D vector space which will represent a displacement of a mirror undergoing thermoelastic deformation, and a scalar finite element space which will represent the temperature of mirror.
I think I understand how to write a solver for my problem, and I have been able to run a solver end-to-end without issue. The problem I am facing arises when I try to make a movie, or plot a frame of one of the solutions following an example from Jørgen Dokken’s FEniCSx tutorial here using pyvista. Ultimately, I run into a shape mismatch between the size of the 3D mesh on one of the subspaces and the size of the solution array. Below is a MWE which just highlights the shape mismatch (I’ve removed the solver/solution because these are not necessary to reproduce the issue).
from dolfinx.io.gmshio import model_to_mesh
from dolfinx.io import gmshio, XDMFFile
from dolfinx import mesh, fem, plot, io, nls
import petsc4py.PETSc as PETSc
import pyvista as pv
import os
gmsh.model.add("mirror 3D")
R = 0.34/2      # radius [m]
H = 0.2         # height [m]
mirror = gmsh.model.occ.addCylinder(0, 0, 0 ,0, 0, H, R)
gmsh.model.occ.synchronize()
volumes = gmsh.model.getEntities(dim=3)
surfaces = gmsh.model.occ.getEntities(dim=2)
gmsh.model.addPhysicalGroup(3, [mirror], 1)
gmsh.option.setNumber("Mesh.CharacteristicLengthMin",0.02)
gmsh.option.setNumber("Mesh.CharacteristicLengthMax",0.02)
gmsh.model.mesh.generate(3)
model_rank = 0
mesh, cell_tags, facet_tags = model_to_mesh(gmsh.model, MPI.COMM_WORLD, model_rank)
# Define the function spaces
v_uel = ufl.VectorElement('Lagrange', mesh.ufl_cell(), 2)
v_tel = ufl.FiniteElement('Lagrange', mesh.ufl_cell(), 2)
mel = ufl.MixedElement([v_uel, v_tel])
Vue = fem.FunctionSpace(mesh, v_uel)
Vte = fem.FunctionSpace(mesh, v_tel)
#the mixed element space
Y = fem.FunctionSpace(mesh, v_uel* v_tel)
#trial functions
U = fem.Function(Y)  # current solution
# pyvista stuff
os.environ["PATH"] += os.pathsep + '/opt/X11/bin' # THIS is for xvfb (requires xQuartz on Mac)
pv.start_xvfb()
# Create plotter and pyvista grid
p = pv.Plotter()
#extract the subspace for the vector solution V0
V0, dofs = Y.sub(0).collapse()
topology, cell_types, geometry = plot.create_vtk_mesh(V0)
grid = pv.UnstructuredGrid(topology, cell_types, geometry)
# Attach vector values to grid and warp grid by vector
grid["u"] = U.sub(0).x.array.reshape((geometry.shape[0], 3))
This fails with the message
ValueError                                Traceback (most recent call last)
Cell In[6], line 14
     11 grid = pv.UnstructuredGrid(topology, cell_types, geometry)
     13 # Attach vector values to grid and warp grid by vector
---> 14 grid["u"] = U.sub(0).x.array.reshape((geometry.shape[0], 3))
ValueError: cannot reshape array of size 68744 into shape (17186,3)
The code versions are
dolfinx: ‘0.6.0’
ufl: ‘2023.1.1.post0’
pyvista: ‘0.38.2’
gmsh: ‘4.11.1’
OS: MacOS Monterey 12.2.1
Thank you in advance!
A function in a sub space (called to sub) does not restrict the underlying array to the sub space (that array is non-contiguous).
Thus, you would have to call U.sub(0).collapse().x.array.reshape(...) to get the contiguous array you want.
Thank you for the prompt reply! This solves the issue.
-rs
