This is the whole code:
from dolfinx import mesh, fem, plot
import basix
from dolfinx.fem import dirichletbc, locate_dofs_topological
from ufl import Measure, SpatialCoordinate, TestFunctions, TrialFunctions, div, inner, dot
import pyvista as pv
# Material properties
E = 2000000.0 # Young's modulus in PSI (for structural wood)
nu = 0.299999 # Poisson's ratio (for structural wood)
L = 72 # Beam length in inches
W = 4.0 # Beam width in inches
w = 100.0 # Distributed load in lbs/inch
# Define the mesh with tetrahedral cells
domain = mesh.create_box(MPI.COMM_WORLD, [np.array([0, 0, 0]), np.array([L, W, W])],
[20, 6, 6], cell_type=mesh.CellType.tetrahedron)
# Define elements for displacements (3 DOF) and rotations (3 DOF)
elem_disp = basix.ufl.element("Lagrange", domain.topology.cell_name(), 1, shape=(3,))
elem_rot = basix.ufl.element("Lagrange", domain.topology.cell_name(), 1, shape=(3,))
elem_mixed = basix.ufl.mixed_element([elem_disp, elem_rot])
V = fem.functionspace(domain, elem_mixed)
VV = fem.functionspace(domain, elem_disp)
# Strain tensor as a symmetric gradient of the displacement field
return 0.5 * (ufl.grad(u) + ufl.grad(u).T)
# Stress tensor derived from Hooke's law
def sigma(u):
lambda_ = E * nu / ((1 + nu) * (1 - 2 * nu)) # First Lamé parameter
mu = E / (2 * (1 + nu)) # Shear modulus (second Lamé parameter)
return lambda_ * ufl.tr(epsilon(u)) * ufl.Identity(3) + 2 * mu * epsilon(u)
# Define trial and test functions for displacements (u) and rotations (theta)
(u, theta) = TrialFunctions(V)
(v, tau) = TestFunctions(V)
# Weak form for the elasticity problem (displacement part)
a_disp = inner(sigma(u), epsilon(v)) * ufl.dx
# Rotational-related terms (rotations theta and tau)
a_rot = inner(theta, tau) * ufl.dx
# Coupling terms between displacement and rotation (optional)
a_coupling = inner(theta, v) * ufl.dx + inner(u, tau) * ufl.dx
# Final variational form: combining displacements, rotations, and coupling
a = a_disp + a_rot + a_coupling
# Get subspace of V for displacements
V0 = V.sub(0)
Q, _ = V0.collapse()
# Locate the entities where x=0 (left boundary) and x=L (right boundary)
def locate_left_boundary(x):
return np.isclose(x[0], 0.0)
def locate_right_boundary(x):
return np.isclose(x[0], L)
facets_left = mesh.locate_entities_boundary(domain, fdim, locate_left_boundary)
facets_right = mesh.locate_entities_boundary(domain, fdim, locate_right_boundary)
# Apply boundary condition at the left boundary where x = 0 (clamping)
dofs_left = locate_dofs_topological(V0, fdim, facets_left)
u_left = fem.Function(Q)
with u_left.vector.localForm() as loc:
loc.set(0.0) # Zero displacement in all directions
bc_left = dirichletbc(u_left, dofs_left)
# Apply boundary condition at the right boundary where x = L (clamping)
dofs_right = locate_dofs_topological(V0, fdim, facets_right)
u_right = fem.Function(Q)
with u_right.vector.localForm() as loc:
bc_right = dirichletbc(u_right, dofs_right)
# Compute the distributed load per node and apply it
nodes = domain.geometry.x
num_nodes = len(nodes)
# Create force function f in the same mixed space V
f = fem.Function(V)
# Assign distributed force (downward in -y) and moment (around x-axis)
I = (W**4) / 12 # Moment of inertia for a rectangular cross-section
# Compute the number of degrees of freedom per node
dofs_per_node = 6
# Loop over all nodes to apply the distributed load and moment
for i, node in enumerate(nodes):
fy = -w * L / num_nodes # Distributed load down the -y axis
y = node[1] # y-coordinate of the node
mx = -(w * abs(y) * L**2) / (2 * I) # Moment around x-axis
# Apply fy to the displacement component in y and mx to the rotational component around x
f.vector.setValue(i * dofs_per_node + 1, fy) # Displacement force in y
f.vector.setValue(i * dofs_per_node + 3, mx) # Rotational moment around x
# Define the right-hand side (RHS) for the variational problem
l = inner(f, v) * ufl.dx # Adjust RHS to match the shape of the test function v
# Create the linear problem and solve it
#problem = LinearProblem(a, l, bcs=[bc_left, bc_right])
#uh = problem.solve()
# Save the solution to a CSV file
#np.savetxt('U.csv', uh.x.array)
#print('done...')
with traceback:
File "/home/prusso/dolfinx-beam_w/compute_displacements2.py", line 115, in <module>
File "/home/prusso/spack/var/spack/environments/fenicsx-env/.spack-env/view/lib/python3.10/site-packages/ufl/operators.py", line 213, in inner
return Inner(a, b)
File "/home/prusso/spack/var/spack/environments/fenicsx-env/.spack-env/view/lib/python3.10/site-packages/ufl/tensoralgebra.py", line 166, in __new__
raise ValueError(f"Shapes do not match: {ufl_err_str(a)} and {ufl_err_str(b)}")
ValueError: Shapes do not match: <Coefficient id=128873217154304> and <ListTensor id=128873219570112>
If I understand it, there is a shape problem building the linear form after using the force vector this way.
This is the desired algorithm so far:
(Set a distributed load, small cursive w, and a moment of force for each node):
As an alternative to troubleshoot the problem I had also tried this way:
V0 = V.sub(0)
f_disp = fem.Function(Q)
# Loop over all nodes to apply the distributed load (displacement force)
f_disp.vector.setValue(i * 3 + 1, fy) # Displacement force in y
l = inner(f_disp, v[0]) * ufl.dx # Adjust RHS to match the shape of the test function v
which leads to a different traceback:
File "/home/prusso/dolfinx-beam_w/compute_displacements3.py", line 99, in <module>
return Inner(a, b)
ValueError: Shapes do not match: <Coefficient id=132880029505664> and <Indexed id=132880029444000>
What is going wrong here? How can I set up the desired algorithm to work as far as setting the forces and moments for this type of problem?
