I tried to use the smooth method for 3d mesh of triangles and I got this error:
RuntimeError:
*** Error: Unable to find normal.
*** Reason: Normal vector is not defined in dimension 3 (only defined when the triangle is in R^2.
*** Where: This error was encountered inside TriangleCell.cpp.
*** Process: 0
*** DOLFIN version: 2019.1.0
*** Git changeset:
The code to reproduce this error:
mesh_cube = UnitCubeMesh(2,2,2)
bnd_mesh = BoundaryMesh(mesh_cube, 'exterior')
bnd_mesh.smooth(10) # Error
Does anyone if there is a way to use smooth for this kind of mesh ?
