Hi everyone!
I need to extract components in a mixed finite element space and update them with.
But the u values I printed in two ways are different,u_test and u0 respectively.
the main code :
solver.solve(b, wn.vector)
u0 = wn.sub(0).collapse()
A0 = wn.sub(1).collapse()
p0 = wn.sub(2).collapse()
offset = W0.dofmap.index_map.size_local * W0.dofmap.index_map_bs
offset1 = W1.dofmap.index_map.size_local * W1.dofmap.index_map_bs
offset2 = W2.dofmap.index_map.size_local * W2.dofmap.index_map_bs
print('1 is',offset)
print('2 is',offset1)
print('3 is',offset2)
u_test.x.array[::]=wn.x.array[:offset]
print('wn',len(wn.x.array))
print('u0',len(u0.x.array))
print('a0',len(A0.x.array))
print('p0',len(p0.x.array))
print(u_test.x.array[:20])
print(u0.x.array[:20])
output:
1 is 19584
2 is 4184
3 is 12288
wn 36056
u0 19584
a0 4184
p0 12288
[ 7.39346510e-03 -1.28154933e-04 9.18965132e-05 7.13080626e-03
-1.20728390e-04 -3.00721578e-06 1.82657280e-04 -1.61130687e-04
-1.33367441e-04 4.45515478e-04 -7.48266475e-05 -1.00955936e-04
-3.83697155e-05 -3.13355810e-01 -3.13448153e-01 -3.01518102e-01
-3.01435827e-01 1.98569770e-03 0.00000000e+00 2.24697778e-03]
6.43970781e-03 -1.15514689e-04 -5.52278058e-05 6.25757857e-03
-3.20202251e-04 -1.78086991e-04 0.00000000e+00 0.00000000e+00]
Which one is correct?
Finally, I attach the complete code:
from dolfinx import fem
from dolfinx.fem import (Constant, Function, FunctionSpace, dirichletbc,
extract_function_spaces, form,
locate_dofs_geometrical, locate_dofs_topological)
from dolfinx.mesh import (CellType, GhostMode, create_rectangle,
locate_entities_boundary,create_unit_cube)
from ufl import div, dx, grad, inner,dot,outer,ds,dS,avg,jump,rot,cross
# Create mesh
msh = create_unit_cube(MPI.COMM_WORLD,
8,8,8,
CellType.tetrahedron, GhostMode.none)
u_element=ufl.FiniteElement("BDM", ufl.tetrahedron, 1) # H(div) Vh
A_element=ufl.FiniteElement("N1curl",ufl.tetrahedron,1) # H(curl) Ch
P_element=ufl.FiniteElement("DG",ufl.tetrahedron,1) # Qh
#fai_element=ufl.FiniteElement("DG",ufl.tetrahedron,2) # SH
TH= ufl.MixedElement([u_element, A_element,P_element])
W =fem.FunctionSpace(msh,TH)
W0,_=W.sub(0).collapse()
W1,_=W.sub(1).collapse()
W2,_=W.sub(2).collapse()
(un,An,Pn)=ufl.TrialFunctions(W) #
(v,fai,q)=ufl.TestFunctions(W) #
#Vh=fem.FunctionSpace(msh,u_element)
un_1=fem.Function(W0)
un_2=fem.Function(W0)
u_test=fem.Function(W0)
def initial_u(x):
values=np.zeros((3,x.shape[1]))
values[0,:]=0 #y
values[1,:]=0 #z
values[2,:]=0 #x
return values
un_1.interpolate(initial_u)
#Ch=fem.FunctionSpace(msh,A_element)
An_1=fem.Function(W1)
An_2=fem.Function(W1)
def initial_A(x):
values[0,:]=0 #z
values[1,:]=np.sin(x[0]) #0
values[2,:]=0 #y
return values
An_1.interpolate(initial_A)
Pn=fem.Function(W2)
def initial_P(x):
values=np.zeros((1,x.shape[1]))
values[0,:]=x[0]+x[1]+x[2]-1.5
return values
Pn.interpolate(initial_P)
def local_u(x): #mark boundary of u
#return np.logical_and(np.isclose(x[2],0),np.isclose(x[1],0)) #mark z=0 && x=0
return np.isclose(x[1],0)
def u_D(x):
values[0,:]=0 #y
values[1,:]=0 #z
values[2,:]=0 #x
return values
u_boundary = fem.Function(Vh)
u_boundary.interpolate(u_D)
facets = locate_entities_boundary(msh,2, local_u)
dofs = locate_dofs_topological((W.sub(0), Vh), 2, facets)
bc0 = dirichletbc(u_boundary, dofs, W.sub(0))
bcs=[bc0]
h = ufl.CellDiameter(msh)
n = ufl.FacetNormal(msh)
unv=(un+un_1)*0.5
uns=1.5*un_1-0.5*un_2
Anv=(An+An_1)*0.5
Ans=1.5*An_1-0.5*An_2
lmbda = ufl.conditional(ufl.gt(dot(un_1, n), 0), 1, 0)
u_uw = lmbda("+") * unv("+") + lmbda("-") * unv("-") # u -> upwind flux
tao_1=1000
k=1
Rm=1
alph=10
b = 2*tao_1*inner(unv,v)*dx
b -= inner(unv,div(outer(uns,v)))*dx
b += inner((dot(uns, n))("+") * u_uw, v("+")) * dS+inner((dot(uns, n))("-") * u_uw, v("-")) * dS #
b += inner(dot(uns, n) * lmbda * unv, v) * ds
b += inner(grad(unv),grad(v))*dx +alph/h('+')*inner(jump(unv),jump(v))*dS
b -= inner(avg(dot(grad(unv),n)),jump(v))*dS-inner(avg(dot(grad(v),n)),jump(unv))*dS
b += 2*k*tao_1*inner(rot(Anv),rot(fai))*dx
b += k*inner(2*tao_1*Anv+cross(rot(Ans),unv),2*tao_1*fai+cross(rot(Ans),v))*dx
b += inner(2*tao_1*un_1,v)*dx+k*inner(2*tao_1*An_1,2*tao_1*fai+cross(rot(Ans),v))*dx
b += 2*tao_1*inner(div(unv),div(v))*dx-inner(div(unv),q)*dx-inner(div(v),Pn)*dx
b -= inner(u_boundary,dot(grad(v),n))*ds+alph/h*inner(u_boundary,v)*ds
a=ufl.lhs(b)
L=ufl.rhs(b)
a=fem.form(a)
L=fem.form(L)
create_vector, set_bc)
A=assemble_matrix(a,bcs=bcs)
b=create_vector(L)
solver = PETSc.KSP().create(msh.comm)
solver.setOperators(A)
solver.setType(PETSc.KSP.Type.BCGS)
pc1 = solver.getPC()
pc1.setHYPREType("boomeramg")
solver.setFromOptions()
def domain_average(msh, v):
"""Compute the average of a function over the domain"""
vol = msh.comm.allreduce(fem.assemble_scalar(fem.form(fem.Constant(msh, 1.0) * dx)), op=MPI.SUM)
return (1 / vol) * msh.comm.allreduce(fem.assemble_scalar(fem.form(v * dx)), op=MPI.SUM)
wn=Function(W)
t=0
for n in range(1):
if n==0:
t += 0.001
un_2.x.array[::]=un_1.x.array[::]
An_2.x.array[::]=An_1.x.array[::]
fem.petsc.assemble_matrix(a,bcs=bcs) # type: ignore
assemble_vector(b, L)
apply_lifting(b, [a], [bcs])
set_bc(b, bcs)
un_1.x.array[::]=u0.x.array[::]
An_1.x.array[::]=A0.x.array[::]
un_2.x.scatter_forward()
un_1.x.scatter_forward()
An_2.x.scatter_forward()
An_1.x.scatter_forward()
Pn.x.array[::]=p0.x.array[::]
t += 0.001
with b.localForm() as b_loc:
b_loc.set(0)
set_bc(b, bcs)
print('t is',t)
u = wn.sub(0).collapse()
A = wn.sub(1).collapse()
p = wn.sub(2).collapse()
with XDMFFile(MPI.COMM_WORLD, "out_WH/velocity.xdmf", "w") as ufile_xdmf:
u.x.scatter_forward()
ufile_xdmf.write_mesh(msh)
ufile_xdmf.write_function(u)
with XDMFFile(MPI.COMM_WORLD, "out_WH/A.xdmf", "w") as pfile_xdmf:
A.x.scatter_forward()
pfile_xdmf.write_mesh(msh)
pfile_xdmf.write_function(A)
with XDMFFile(MPI.COMM_WORLD, "out_WH/p.xdmf", "w") as pfile_xdmf:
p.x.scatter_forward()
pfile_xdmf.write_function(p)
Any answer will be welcomed!Thanks very much !
