I’m trying to write part of a solution into a file, with each line having three values for the node coordinates and the three following values being flow velocity components.
The code is the following:
from dolfinx import mesh, fem, io, log
from ufl import inner, div, grad, dx
import basix
import time
height = 0.06
width = 0.08
n_h = 20
n_w = 10
msh = mesh.create_box(MPI.COMM_WORLD, ((-width/2, -width/2, 0.0), (width/2,width/2,height)), (n_h,n_h,n_w), mesh.CellType.tetrahedron)
fdim = msh.topology.dim - 1
rho_air = fem.Constant(msh, 1.225)
mu_air = fem.Constant(msh, 1.8e-5)
# Function to mark noslip
def noslip_boundary1(x):
return np.isclose(x[2], height)
P2 = basix.ufl.element("Lagrange", msh.topology.cell_name(), 2, shape=(msh.geometry.dim, ))
P1 = basix.ufl.element("Lagrange", msh.topology.cell_name(), 1)
V, Q = fem.functionspace(msh, P2), fem.functionspace(msh, P1)
# Create the function space
TH = basix.ufl.mixed_element([P2, P1])
W = fem.functionspace(msh, TH)
W0, _ = W.sub(0).collapse()
# No slip boundary condition 1
noslip = fem.Function(V)
facets1 = mesh.locate_entities_boundary(msh, fdim, noslip_boundary1)
dofs1 = fem.locate_dofs_topological((W.sub(0), V), fdim, facets1)
bc0 = fem.dirichletbc(noslip, dofs1, W.sub(0))
# Since for this problem the pressure is only determined up to a constant, we pin it at a point
zero = fem.Function(Q)
zero.x.array[:] = 0
dofs = fem.locate_dofs_geometrical(
(W.sub(1), Q), lambda x: np.isclose(x.T, [0, 0, 0]).all(axis=1))
bc2 = fem.dirichletbc(zero, dofs, W.sub(1))
def body_force_fun(x):
F_max = 2.0e-2
z_offset = 0.02
r_xy = np.sqrt(x[0]**2 + x[1]**2)
a = 0.005
max_val = a * np.exp(-0.5)
Fr_val = np.exp(-r_xy**2/(2*a**2)) / max_val
b = 0.005
Fz_val = np.exp(-(x[2]-z_offset)**2/(2*b**2))
F_mag = F_max * Fr_val * Fz_val
# -ve sign to get clockwise rotation from array top
return -F_mag * np.vstack((x[1], -x[0], np.zeros_like(x[2])))
Force_per_unit_vol = fem.Function(V)
Force_per_unit_vol.interpolate(lambda x: body_force_fun(x))
bcs = [bc0, bc2]
w = fem.Function(W)
(u, p) = ufl.split(w)
(v, q) = ufl.TestFunctions(W)
F = rho_air*inner(grad(u)*u, v)*dx + \
mu_air*inner(grad(u), grad(v))*dx + \
inner(Force_per_unit_vol, v)*dx - \
inner(p, div(v))*dx - \
div(u)*q*dx
dw = ufl.TrialFunction(W)
dF = ufl.derivative(F, w, dw)
problem = NonlinearProblem(F, w, bcs=bcs, J=dF)
solver.rtol = 1e-6
#solver.max_it = 2
solver.report = True
solver.error_on_nonconvergence = False
# Custom solver options
opts = PETSc.Options()
ksp = solver.krylov_solver
ksp.setFromOptions()
# Compute the solution
start = time.time()
solver.solve(w)
end = time.time()
print('\n')
print(msh.topology.index_map(msh.topology.dim).size_local)
print((end - start) / 60)
u = w.sub(0).collapse()
p = w.sub(1).collapse()
# Write to file
u2 = fem.functionspace(msh, P2)
coords = u2.tabulate_dof_coordinates()
with open('coords_vcomps.txt', 'w') as file:
for i, coord in enumerate(coords):
file.write("%s %s %s " % (coord[0], coord[1], coord[2]))
for b in range(u2.dofmap.bs):
file.write("%s " % (u.x.array[i*u2.dofmap.bs+b] * 1000,))
file.write('\n')
# Write the solution to file
with io.XDMFFile(MPI.COMM_WORLD, "velocity.xdmf", "w") as ufile_xdmf:
u.x.scatter_forward()
P1 = basix.ufl.element("Lagrange", msh.basix_cell(), 1, shape=(msh.geometry.dim,))
u1 = fem.Function(fem.functionspace(msh, P1))
u1.interpolate(u)
ufile_xdmf.write_mesh(msh)
ufile_xdmf.write_function(u1)
The file can be checked using the following code:
# File path to your text file
filename = 'coords_vcomps.txt'
# Load data, skipping the first 8 lines (starts from line 9)
data = np.loadtxt(filename, skiprows=0)
print(data.shape)
# Assuming the columns are: x, y, z, vx, vy, vz
n_skip = 100
v_points = data[::n_skip, 0:3]
#v_points[:,2] = v_points[:,2] + 0.01
v_comps = data[::n_skip, 3:]
print(v_points.shape)
print(np.max(np.sqrt(v_comps[:,0]**2 + v_comps[:,1]**2 + v_comps[:,2]**2)))
# Create a 3D vector field plot
fig = plt.figure(figsize=(10, 8))
ax = fig.add_subplot(111, projection='3d')
# Plot vector field using quiver
ax.quiver(v_points[:,0], v_points[:,1], v_points[:,2],
v_comps[:,0], v_comps[:,1], v_comps[:,2], length=0.004, normalize=False, color='blue')
# Set axis labels
ax.set_xlabel('X')
ax.set_ylabel('Y')
ax.set_zlabel('Z')
ax.set_title('3D Vector Field')
ax.set_aspect('auto')
Thank you,
Alex
