** Solver problem using the Logaritm of Left Cauchy-Green tensor (spatial configuration)**
hello guys, I’m trying to implement code for large deformations using the Hecky’s tensor ,
I’m trying to use a non-linear solver model, given the conditions of the problem, however, I don’t know how to configure it, the model perform two iterations and finish. Would anyone have any ideas to help me?
Version: Dolfinx 0.6.0 Python
Windows Subsystem for Linux (WSL) in Visual Studio Code
from dolfinx import fem
from dolfinx import fem,log, nls ,mesh
from dolfinx.io import gmshio
*Geometry , boundary conditions and Scaled variable:*
carregamento= -50000
E = 78e6
poisson = 0.3
lambda_ = E*poisson / ((1+poisson)*(1-2*poisson))
G= E / 2*(1+poisson)
#Geometry
domain= mesh.create_rectangle(MPI.COMM_WORLD, [np.array([0,0]), np.array([2,1])],
[100,100], cell_type=mesh.CellType.triangle)
V = fem.VectorFunctionSpace(domain, ("CG", 1))
#boundary conditions
def clamped_boundary(x):
return np.isclose(x[0], 0)
u_D = np.array([0,0], dtype=ScalarType)
bc = fem.dirichletbc(u_D, fem.locate_dofs_topological(V, fdim, boundary_facets), V)
#Aproximação das funções teste e funcao incognita
u= fem.Function(V)
#tensor de cauchy-Green left
d = len(u)
I = (ufl.Identity(d))
F =(I + ufl.grad(u))
C= (F * F.T )
#jacobian
Jhc_e= ufl.det(F)
J= Jhc_e
#Hencky's Strain
N, M = C.ufl_shape
T_hencky=ufl.as_tensor([[(1/2)*(ufl.ln(C[i,j])) for i in range(N)] for j in range(M)])
#Tensor de tension
T_tension= (1/J)*(2.0 * G * T_hencky+ lambda_ * ufl.tr(T_hencky) * I )
#Function load
f = fem.Constant(domain, ScalarType((0,carregamento )))
#Formulação variacional para Div T = 0, em Tn= f,u= 0 em x=0
a = ufl.inner(ufl.grad(v),T_tension) * ufl.dx
L = ufl.inner(f, v) * ufl.ds
#Weak form for Div T = 0, Tn= f, u= 0 in
F_bilinear = + ufl.inner(ufl.grad(v),T_tension) * ufl.dx - ufl.inner(f, v) *ufl.ds
#Formulação variacional para Div T = 0, em Tn= f,u= 0 in facet_tags.find(16)
problem = fem.petsc.NonlinearProblem(F=F_bilinear ,u=u,bcs=[bc])
#solver no linear
solver = nls.petsc.NewtonSolver(MPI.COMM_WORLD, problem)
solver.rtol = 1e-15
solver.report = True
#solver linear
ksp = solver.krylov_solver
opts = PETSc.Options()
ksp.setFromOptions()
#vizualization
n, converged = solver.solve(u)
assert(converged)
Failed: 2023-08-22 20:53:30.274 ( 2.108s) [main ] petsc.cpp:677 INFO| PETSc Krylov solver starting to solve system. 2023-08-22 20:53:30.334 ( 2.168s) [main ] petsc.cpp:677 INFO| PETSc Krylov solver starting to solve system. 2023-08-22 20:53:30.339 ( 2.173s) [main ] NewtonSolver.cpp:36 INFO| Newton iteration 2: r (abs) = 0 (tol = 1e-10) r (rel) = -nan(tol = 1e-15) 2023-08-22 20:53:30.340 ( 2.173s) [main ] NewtonSolver.cpp:255 INFO| Newton solver finished in 2 iterations and 0 linear solver iterations. Number of interations: 2 2023-08-22 20:53:30.500 ( 2.334s) [main ] loguru.cpp:526 INFO| atexit
