Solving eigenmodes of a 2D rectangular cavity
Greetings everyone,
I am fairly new to Fenicsx, I did the tutorials available in the Fenicsx documentation, read some examples but that’s about it.
I want to study the acoustic eigenmodes of an acoustic cavity with Fenicsx, to start easily, I tried doing it on a simple 2D rectangular cavity. I tried applying the same method as in the tutorial by setting up Dirichlet boundary condtions and using the Helmholtz equation. However, I am facing a problem when it comes to defining the equation. Since I want to study the eigen modes of the cavity, I don’t know the value of the wave number in the helmholtz equations. For the moment I tried implementing by adapting this :
but without much success :
mport numpy as np
from dolfinx.fem import Function, FunctionSpace
from ufl import dx, grad, inner
wavenumber still need to be given
k0 = 2.75 * np.pi
L=1
number of elements in each direction of msh
n_elem = 128
msh = mesh = dolfinx.mesh.create_rectangle(
MPI.COMM_WORLD,
[[0, 0], [L, L]],
[n_elem, n_elem])
n = ufl.FacetNormal(msh)
Source amplitude
A = 1
Test and trial function space
V = FunctionSpace(msh, (“Lagrange”, 1))
Define variational problem
u = ufl.TrialFunction(V)
f = Function(V)
f.interpolate(lambda x: A * k02 * np.cos(k0 * x[0]) * np.cos(k0 * x[1]))
a = inner(grad(u), grad(v)) * dx - k0
2 * inner(u, v) * dx
L = inner(f, v) * dx
#Implementing boudary conditons
def BX0(x):
return np.isclose(x[0],0)
def BXL(x):
return np.isclose(x[0],L)
def BY0(x):
return np.isclose(x[1],0)
def BYL(x):
return np.isclose(x[1],L)
bx0_dofs = dolfinx.fem.locate_dofs_geometrical(V, BX0)
bxl_dofs = dolfinx.fem.locate_dofs_geometrical(V, BXL)
by0_dofs = dolfinx.fem.locate_dofs_geometrical(V, BY0)
byl_dofs = dolfinx.fem.locate_dofs_geometrical(V, BYL)
bcxo= dolfinx.fem.dirichlet(dolfinx.default_scalar_type(0), bx0_dofs, V)
bcxl= dolfinx.fem.dirichlet(dolfinx.default_scalar_type(0), bxl_dofs, V)
bcyo= dolfinx.fem.dirichlet(dolfinx.default_scalar_type(0), by0_dofs, V)
bcyl= dolfinx.fem.dirichlet(dolfinx.default_scalar_type(0), byl_dofs, V)
bcs = [bcxo, bcxl, bcyo, bcyl]
Compute solution
uh = Function(V)
uh.name = “u”
problem = LinearProblem(a, L, u=uh,bcs=bcs, petsc_options={“ksp_type”: “preonly”, “pc_type”: “lu”})
problem.solve()
Save solution in XDMF format (to be viewed in Paraview, for example)
with XDMFFile(MPI.COMM_WORLD, “/home/daep/mar.baudry/Documents/results/plane_wave.xdmf”, “w”, encoding=XDMFFile.Encoding.HDF5) as file:
file.write_mesh(msh)
file.write_function(uh)
Is there a way to define a PDE with an unknown parameter or maybe is there another method ? I also tried using Fenics eigenvalues solver but I am not convinced of the result and I’m not sure I understand what the matrix are representing :
import fenics
Test for PETSc and SLEPc
if not has_linear_algebra_backend(“PETSc”):
print (“DOLFIN has not been configured with PETSc. Exiting.”)
exit()
if not has_slepc():
print (“DOLFIN has not been configured with SLEPc. Exiting.”)
exit()
Define mesh, function space
lx = 8
ly = 8
c = 341
f = 57.17 # Frequency of the Simulation, Hz
s = c / (10 * f) # Element Size
Nx = np.intp(np.ceil(lx / s)) # Number of elements for each direction
Ny = np.intp(np.ceil(ly / s))
tol = 1e-10 # Tolerance for boundary condition definitions
mesh = UnitSquareMesh(lx, ly)
V = FunctionSpace(mesh, “Lagrange”, 1)
Define basis and bilinear form
#a = inner(grad(u), grad(v)) * dx - k_sq * inner(u, v) * dx
#L = inner(f, v) * dx
a = (ufl.inner(ufl.nabla_grad(u), ufl.nabla_grad(v)) * ufl.dx)
m = inner(u, v) * dx
Assemble stiffness form
A = PETScMatrix()
assemble(a, tensor=A)
M = PETScMatrix()
assemble(m, tensor=M)
#Boundary conditions
def BX0(x, on_boundary):
return on_boundary and fenics.near(x[0], 0, tol)
def BXL(x, on_boundary):
return on_boundary and fenics.near(x[0], lx, tol)
def BY0(x, on_boundary):
return on_boundary and fenics.near(x[1], 0, tol)
def BYL(x, on_boundary):
return on_boundary and fenics.near(x[1], ly, tol)
#Definition of boundary conditions here for a completely closed box
bcx0 = DirichletBC(V, 0, BX0)
bcxl = DirichletBC(V, 0, BXL)
bcy0 = DirichletBC(V, 0, BY0)
bcyl = DirichletBC(V, 0, BYL)
bcs = [bcx0, bcxl, bcy0, bcyl]
bcx0.apply(A)
bcx0.apply(M)
bcxl.apply(A)
bcxl.apply(M)
bcy0.apply(A)
bcy0.apply(M)
bcy0.apply(A)
bcyl.apply(M)
Create eigensolver
eigensolver = SLEPcEigenSolver(A,M)
Compute all eigenvalues of A x = \lambda x
print (“Computing eigenvalues. This can take a minute.”)
eigensolver.solve()
Extract largest (first) eigenpair
r, c, rx, cx = eigensolver.get_eigenpair(0)
print ("Largest eigenvalue: "), r
Initialize function and assign eigenvector
u.vector()[:] = rx
Plot eigenfunction
plot(u)
interactive()
Thanks for reading this and for your help !
Have a nice day
If you are willing to use non legacy dolfin but dolfinx instead, I’ve made a video on how to perform acoustic modal analysis:
https://www.youtube.com/watch?v=SH4yjPiGxXA
Best,
Antonio
Thanks a lot a will watch it with great interest !
