Split a 2d solution to add different constants to each component and write to file
Hi there, I am trying to solve a two body problem and as a first step started with two parallel membranes.
I define the space
V=FunctionSpace(mesh, VectorElement(“P”, triangle, degree = 1, dim = 2))
Define forces on each membrane
f1 = Constant(-40.0)
f2 = Constant(40.0)
Define boundary conditions
u_D = Constant((0.,0.))
def boundary(x, on_boundary):
return on_boundary
Split in two components the function and the test function (this I will need when putting unilateral conditions)
u1,u2 = split(u)
v1,v2 = split(v)
Provide my variational formulation
F = dot((grad(u1)), (grad(v1)))dx+dot((grad(u2)), (grad(v2)))dx- (f1v1+f2v2)*dx
And solve
solve(F == 0, u, bc)
Now I wanto to write to one file u1+L and to one another u2-L and all my attempts failed. I can show on screen by using
plot(u1+L, title=‘Deflection1’)
plot(u2-L, title=‘Deflection2’)
To be honest, I get a warning that “Object cannot be plotted directly, projecting to piecewise linears”.
But further, all my attempts to write to file failed. I try
file1 = File(“place/u1.pvd”)
file2 = File(“place/u2.pvd”)
file1<< u1+L
file2<< u2-L
But I get "AttributeError: ‘Sum’ object has no attribute ‘_cpp_object’ "
I tried to interpolate and project the constant L before adding to u1 or u2, but I am doing something wrong and do not know what to try next.
This is probably very basic stuff, sorry for bothering you with this issue, but any help will be appreciated.
Please make a minimal reproducible example, as L is not defined in your snippets above, and your error is thus kot reproducible.
Also make sure you use 3x` encapsulation, ie
```python
#add code here
I moved the lines that dont work in the end
mesh = UnitSquareMesh(20, 20)
V=FunctionSpace(mesh, VectorElement("P", triangle, degree = 1, dim = 2))
# Define loads
f2 = Constant(40.0)
# Define boundary condition
    return on_boundary
u = Function(V)  # Note: not TrialFunction!
u1,u2 = split(u)
v1,v2 = split(v)
mu1=1.0
mu2=1.0
F = mu1*dot((grad(u1)), (grad(v1)))*dx+mu2*dot((grad(u2)), (grad(v2)))*dx- (f1*v1+f2*v2)*dx
# Compute solution
(u1,u2)=u.split()
ele=1.
plot(u1+ele, title='Deflection1')
plot(u2-ele, title='Deflection2')
file1 = File("sofo/u1.pvd")
file2 = File("sofo/u2.pvd")
#file1<< u1+ele
#file2<< u2-ele
# Curve plot along x = 0.5 comparing gap between membranes
tol = 0.001  # avoid hitting points outside the domain
y = np.linspace(0 + tol, 1 - tol, 101)
points = [(0.5, y_) for y_ in y]  # 2D points
teta_line = np.array([2*ele+u1(point)-u2(point) for point in points])
#p_line = np.array([p(point) for point in points])
plt.plot(y, teta_line, 'k', linewidth=2)
#plt.plot(y, p_line, 'b--', linewidth=2)
plt.grid(True)
plt.xlabel('$y$')
plt.legend(['gap'], loc='upper left')
#plt.savefig('poisson_nonlinear/curves.pdf')
plt.savefig('sofo/curves.png')
file1<< u1+ele
file2<< u2-ele
As ele is a floating point vale, you can simply call
u1.vector()[:] += 1.
u2.vector()[:] -= 1.
and then write the corresponding function u1 or u2 to file.
Thank you. It kinda works. But I am still doing something wrong. For example how can it be that if I modify just one, only one of the two components, let’s say u2, then u1 is automatically modified as well. This should not happen, right?
# Define loads
f2 = Constant(40.0)
    return on_boundary
u1,u2 = split(u)
v1,v2 = split(v)
mu1=1.0
mu2=1.0
# Compute solution
(u1,u2)=u.split()
#u1,u2=u.split()
print("u1 value at (0,0): %.2f" %(u1(0.,0.)))
print("u2 value at (0,0): %.2f" %(u2(0.,0.)))
#print(np.array([u1(0.,0.)]))
u2.vector()[:]+=1.  #I JUST MODIFY THIS ONE
print("u1 value at (0,0): %.2f" %(u1(0.,0.)))#THIS ONE GETS MODIFIED AS WELL
ele=1.
plot(u1, title='Deflection1')
plot(u2, title='Deflection2')
file1<< u1
file2<< u2
# Curve plot along x = 0 comparing p and w
u1_line = np.array([u1(point) for point in points])
u2_line = np.array([u2(point) for point in points])
plt.plot(y, u1_line, 'k', linewidth=2)
plt.plot(y, u2_line, 'b--', linewidth=2)
plt.grid(True)
plt.xlabel('$y$')
plt.legend(['u1 line','u2 line'], loc='upper left')
Thank you again
Use deepcopy=True in the split, as explained in: Bitbucket
WOW, thank you! It’s perfect now.
