Hello to All,
I wanted to separate the function space within Thermo-elastic evolution problem (full coupling) https://comet-fenics.readthedocs.io/en/latest/demo/thermoelasticity/thermoelasticity_transient.html into separate Function Space for a staggered algorithm.
The following is the modified code of the thermoelasticity_transient.py found for the above problem
L = 1.
R = 0.1
N = 50
domain = Rectangle(Point(0.,0.), Point(L, L)) - Circle(Point(0., 0.), R, 100)
mesh = generate_mesh(domain, N)
T0 = Constant(293.)
DThole = Constant(10.)
E = 70e3
nu = 0.3
lmbda = Constant(E*nu/((1+nu)*(1-2*nu)))
mu = Constant(E/2/(1+nu))
rho = 2700.
alpha = 2.31e-5
kappa = Constant(alpha*(2*mu + 3*lmbda))
cV = Constant(910e-6)*rho
k = Constant(237e-6)
d = 1 # interpolation degree
Vue = VectorElement('CG', mesh.ufl_cell(), d)
Vte = FiniteElement('CG', mesh.ufl_cell(), d)
MixedSpace = FunctionSpace(mesh, MixedElement([Vue, Vte]))
VectorSpace = FunctionSpace(mesh,Vue)
ScalarSpace = FunctionSpace(mesh,Vte)
def inner_boundary(x, on_boundary):
return near(x[0]**2+x[1]**2, R**2, 1e-3) and on_boundary
def bottom(x, on_boundary):
return near(x[1], 0, DOLFIN_EPS) and on_boundary
def left(x, on_boundary):
return near(x[0], 0, DOLFIN_EPS ) and on_boundary
bc1 = DirichletBC(VectorSpace.sub(0), Constant(0.), left)
bc2 = DirichletBC(VectorSpace.sub(1), Constant(0.), bottom)
bcT = DirichletBC(ScalarSpace, DThole, inner_boundary)
bcU = [bc1, bc2]
u = Function(VectorSpace)
T = Function(ScalarSpace)
vu = TestFunction(VectorSpace)
vT = TestFunction(ScalarSpace)
un = Function(VectorSpace)
Tn = Function(ScalarSpace)
def eps(v):
return sym(grad(v))
def sigma(v, T):
return (lmbda*tr(eps(v)) - kappa*T)*Identity(2) + 2*mu*eps(v)
dt = Constant(0.)
u = TrialFunction(VectorSpace)
mech_form = (inner(sigma(u, Tn), eps(vu)))*dx
au, Lu = lhs(mech_form), rhs(mech_form)
mechproblem = LinearVariationalProblem(au, Lu, u, bcU)
mechsolver = LinearVariationalSolver(mechproblem)
T = TrialFunction(ScalarSpace)
therm_form = (cV*(T-Tn)/dt*vT + kappa*T0*tr(eps(u-un))/dt*vT + dot(k*grad(T), grad(vT)))*dx
aT, LT = lhs(therm_form), rhs(therm_form)
thermalproblem = LinearVariationalProblem(aT, LT, T, bcT)
thermsolver = LinearVariationalSolver(thermalproblem)
fileResults = XDMFFile('FENICS_FILE/Dynamic.xdmf')
fileResults.parameters["flush_output"] = True
fileResults.parameters["functions_share_mesh"] = True
tt = 0
Nincr = 10
t = np.logspace(1, 4, Nincr+1)
Nx = 100
u.rename("Displacement", "label")
T.rename("Temperature", "label")
fileResults.write(u,tt)
fileResults.write(T,tt)
for (i, dti) in enumerate(np.diff(t)):
dt.assign(dti)
print("Increment " + str(i+1),float(dt))
tt+=float(dt)
thermsolver.solve()
Tn.assign(T)
mechsolver.solve()
un.assign(u)
Why is this code giving a different result to the original code?
