The code for the 3d cantilever beam using solid elements is shown below.
L = 5000.
H = 600.
W = 300.0
mesh = BoxMesh(Point(0, 0, 0), Point(6, 2, 1), Nx, Ny, Nz)
E = Constant(1e5)
nu = Constant(0.3)
mu = E/2/(1+nu)
lmbda = E*nu/(1+nu)/(1-2*nu)
def eps(u):
return sym(grad(u))
d = mesh.topology().dim()
def sigma(v):
return lmbda*tr(eps(v))*Identity(d) + 2.0*mu*eps(v)
V = VectorFunctionSpace(mesh, 'Lagrange', degree=1)
rho_g = 1e-3
f = Constant((0, -rho_g,0))
a = inner(sigma(u), eps(v))*dx
l = inner(f, v)*dx
def left(x, on_boundary):
return near(x[0], 0.)
bc = DirichletBC(V, Constant((0.,0.,0)), left)
u_sol = Function(V, name="Displacement")
solve(a == l, u_sol, bc)
Can you pls share some references for modifying it for the beam element?
dokken
September 11, 2023, 10:50am
2
When you say beam-element do you mean a hexahedral cell?
This is supported in for instance DOLFINx.
A beam element has 6 DoF’s per node. 3 displacements and 3 rotations.
dokken
September 12, 2023, 6:56am
4
Could you send a formal definition, along the lines of:
as I’m not familar with how you define these degrees of freedom and corresponding functionals.
dokken
September 12, 2023, 1:24pm
5
As far as I can understand from discussions with co-workers, you just want to use a first order vector Lagrange element on a hexahedral grid.
I found one old post(link ) regarding beam elements. @bleyerj had suggested this tutorial . I want a similar study using 3D beam elements for a 3D cantilever beam problem.
Hi, were you able to model the beam with beam-element ?
I am trying similar problem.
I am looking for suggestions.
