Hello everyone,
I’m having some trouble implementing the energy equation alongside with the NS, so I can create a simulation for steady thermal flow in some microchannels. Here’s my code:
So, this first part is just standard steady NS solving and everything works great.
import mshr
from mshr import *mu = 1.05E-3
rho = 1000Generate mesh with mshr
domain = (Rectangle(dolfin.Point(0.,0.), dolfin.Point(0.2E-2,1.2E-2)) +
Rectangle(dolfin.Point(0.2E-2,0.2E-2), dolfin.Point(1.8E-2,0.4E-2)) +
Rectangle(dolfin.Point(0.2E-2,0.6E-2), dolfin.Point(1.8E-2,0.8E-2)) +
Rectangle(dolfin.Point(0.2E-2,1.0E-2), dolfin.Point(1.8E-2,1.2E-2)) +
Rectangle(dolfin.Point(1.8E-2,0.2E-2), dolfin.Point(2.0E-2,1.4E-2)))
mesh = generate_mesh(domain, 100)
V = VectorElement(“P”, mesh.ufl_cell(), 2)
Q = FiniteElement(“P”, mesh.ufl_cell(), 1)
TH = MixedElement([V, Q])
W = FunctionSpace(mesh, TH)Defining the boundary
inflow = ‘near(x[1], 0.0)’
outflow = ‘near(x[1], 1.4E-2)’
walls = ('near(x[0], 0.0E-2) || near(x[1], 0.2E-2) || near(x[0],2.0E-2) || ’ +
'near(x[1], 1.2E-2) || near(x[0], 0.2E-2) || near(x[0],1.8E-2) || ’ +
'near(x[1], 0.4E-2) || near(x[1], 0.6E-2) || near(x[1],0.8E-2) || ’ +
‘near(x[1], 1.0E-2)’)Defining boundary conditions
bcu_inflow = DirichletBC(W.sub(0), Constant((0,0.1)), inflow)
bcp_outflow = DirichletBC(W.sub(1), Constant(0), outflow)
bcu_noslip = DirichletBC(W.sub(0), Constant((0,0)), walls)
bcs = [bcu_noslip, bcu_inflow, bcp_outflow]
#Define variational forms
v, q = TestFunctions(W)
w = Function(W)
u, p = split(w)Equation
F1 = mu*inner(grad(u),grad(v))dx + rhoinner(dot(grad(u),u),v)dx
- pdiv(v)dx - qdiv(u)*dx
J = derivative(F1, w)problem = NonlinearVariationalProblem(F1, w, bcs, J)
solver.parameters[“newton_solver”][“krylov_solver”][“maximum_iterations”] = 50
solver.solve()
So far so good. Next I tried to use the velocity u result from the previous simulation in a convective heat transfer case:
Defined some constants
cp = Constant(4182) #J/kgK
k = Constant(0.6) #W/mK
s = Constant(1.0E5) #W/m3 source termNew Function space and T function
E = FunctionSpace(mesh, ‘CG’, 1)
T = TrialFunction(E)
r = TestFunction(E)
Here the boundary condition is only defined in the inflow as the other boundaries are the outflow and walls, which are dT/dx=0, a condition which I assumed to be naturally assumed with the variational formulation.
#boundary conditions
bct = DirichletBC(E, Constant(0), inflow)
Finally the equation:
F2 = rhocpinner(dot(grad(T),u),r)dx - kinner(grad(T),grad®)*dx
L = inner(s,r)*dx
solve(F2 == L, T, bct)
The error message when I try this is:
Expecting second argument to be a Function.
I defined T as the Trial Function in this case, so I don’t understand the error. But I’m also second guessing my solution to the convective term: rhocpinner(dot(grad(T),u),r)*dx
I’ve been stuck in this for ages and have found no solution in the forum or the tutorial pdfs, as there is no specific case of steady thermal flow documented.
Thanks for reading!
