Structural Modal Analysis
I am trying to replecate the eigenfrequencies from this paper: Modal Analysis of Single Rectangular Cantilever Plate by Mathematically, FEA and Experimental
Ashish R. Sonawane, Poonam S. Talmale
I cant get to achive results anywhere near that after trying a lot of things.
My resulting frequencies seam quite low leading me to belive that my boundry condition isn’t applied correctly. I create the mesh using gmsh.
Here my python code:
from dolfinx.fem import Function, form, functionspace, dirichletbc, locate_dofs_topological
from dolfinx.fem.petsc import assemble_matrix
from slepc4py import SLEPc
from ufl import dx, grad, inner, TrialFunction, TestFunction
from dolfinx.io import XDMFFile, gmshio
from ufl import sym, Identity, div
import os
PART = "STEEL_BEAM"  # Name of the part being analyzed (used for file naming)
GEO_FILE = "~/Dev/BA/simulation/" + PART + ".geo"
MSH_FILE = "~/Dev/BA/simulation/" + PART + ".msh"
# Material properties
E = 70e9  # Young's modulus [Pa]
nu = 0.35  # Poisson's ratio [-]
rho = 2700  # Density [kg/m³]
# create mesh
try:
    os.system("gmsh " + GEO_FILE + " -3 -o " + MSH_FILE)
except Exception:
    print("GMSH Geometry (.geo) file could not be converted to a Mesh (.msh) file")
    quit()
print("Mesh creation finished.\n")
# mesh import
mesh, cell_tags, facet_tags = gmshio.read_from_msh(PART + ".msh", MPI.COMM_WORLD, 0, gdim=3)
# test and trial functions
deg = 2
V = functionspace(mesh, ("CG", deg, (3,)))  # Vector function space for displacement
# Lame parameters
mu = E / (2 * (1 + nu))
lambda_ = E * nu / ((1 + nu) * (1 - 2 * nu))
# Strain and stress
    return sym(grad(u))
def sigma(u):
    return lambda_ * div(u) * Identity(3) + 2 * mu * epsilon(u)
# boundary conditions
fixed_end = facet_tags.find(1)  # Assuming region 1 corresponds to the fixed end
u_zero = np.zeros(3, dtype=PETSc.ScalarType) # Zero displacement
bc = dirichletbc(u_zero, locate_dofs_topological(V, 2, fixed_end), V)
# matrix assemblys
k_form = form(inner(sigma(u), epsilon(v)) * dx)
m_form = form(rho * inner(u, v) * dx)
K = assemble_matrix(k_form, [bc])
M = assemble_matrix(m_form, [bc])
K.assemble()
M.assemble()
# setup eigensolver
solver = SLEPc.EPS().create()
solver.setDimensions(4)  # number of eigenvalues to compute
solver.setProblemType(SLEPc.EPS.ProblemType.GHEP)  # generalized Hermitian eigenvalue problem
st = SLEPc.ST().create()
st.setType(SLEPc.ST.Type.SINVERT)
st.setShift(0.1)
st.setFromOptions()
solver.setST(st)
solver.setOperators(K, M)
# solve the problem
solver.solve()
xr, xi = K.createVecs()
tol, maxit = solver.getTolerances()
nconv = solver.getConverged()
print(f"\nNumber of iterations: {solver.getIterationNumber()}")
print(f"Solution method: {solver.getType()}\n")
print(f"Stopping condition: tol={tol:.4g}, maxit={maxit}\n")
eig_vector = []
eig_freq = []
if nconv > 0:
    print("Eigenvalues:")
    for i in range(nconv):
        k = solver.getEigenpair(i, xr, xi)
        fn = np.sqrt(k.real) / (2 * np.pi)
        eig_freq.append(fn)
        print(f"Mode {i}: {fn} Hz")
        vect = xr.getArray()
        eig_vector.append(vect.copy())
My geo file for gmsh is:
// Manual Method: Define Points, Lines, Surfaces
mesh_size = 0.05;  // Mesh size
l = 1;    // Length [m] x-direction
b = 0.05;   // Width [m] z-direction
h = 0.005;   // Height [m] y-direction
Point(1) = {0, 0, 0, mesh_size};
Point(2) = {0, h, 0, mesh_size};
Point(3) = {0, h, b, mesh_size};
Point(4) = {0, 0, b, mesh_size};
Line(1) = {1, 2};
Line(2) = {2, 3};
Line(3) = {3, 4};
Line(4) = {4, 1};
Transfinite Curve {2, 4} = 6 Using Progression 1;
Transfinite Curve {1, 3} = 4 Using Progression 1;
Curve Loop(1) = {1, 2, 3, 4};
Plane Surface(1) = {1};
Recombine Surface {1}; // Quad mesh base surface (1)
Transfinite Surface {1};
Extrude {1, 0, 0} {
    Surface{1};
    Layers{50};
    Recombine;
Coherence;
Physical Surface("FixedEnd") = {1};
Physical Volume("SteelBeam") = {1};
// Set mesh options
Mesh.Algorithm = 8;  // Frontal-Delaunay for quads
Mesh.MshFileVersion = 2;
// Generate mesh
Mesh 3;
My resulting eigenfrequencies are:
Eigenvalues:
Eigenvalues:
Mode 0: 0.15915494309189526 Hz
Mode 1: 0.15915494309189532 Hz
Mode 2: 0.15915494309189532 Hz
Mode 3: 0.15915494309189537 Hz
Mode 4: 0.1591549430918954 Hz
Mode 5: 0.15915494309189818 Hz
Mode 6: 4.137811871898824 Hz
Mode 7: 25.930992886274172 Hz
Mode 8: 41.14547178779196 Hz
Mode 9: 72.63890011999023 Hz
Mode 10: 142.46413270523485 Hz
For the boundry condition I also tried:
def clamped_boundary(x):
    return np.isclose(x[0], 0.0)  # e.g., x=0 plane
fixed-end = locate_entities_boundary(mesh, 2, clamped_boundary)
The expected natural freuquencies are (experimental from linked paper):
1: 0.233
2: 1.142
3: 1.737
4: 4.799
5: 8.32
6: 9.36
7: 11.67
8: 15.013
9: 23.617
10: 23.944
With specefied values:
L=1000mm
b=50mm
h=5mm
E=70e3 N/mm^2
nu=0.35
rho=2700kg/m^3
one should remove the strongly enforced dofs from the system, i.e. something along the lines of:
I would do something along the lines of:
from dolfinx.io import XDMFFile, gmsh as gmshio
import os
def extract_sub_matrix(A:PETSc.Mat, V: dolfinx.fem.FunctionSpace, bcs:list[dolfinx.fem.DirichletBC])->PETSc.Mat:
    num_dofs_local = V.dofmap.index_map.size_local*V.dofmap.index_map_bs
    num_ghosts = V.dofmap.index_map.num_ghosts*V.dofmap.index_map_bs
    not_dirichlet = np.full(num_dofs_local+num_ghosts, 1, dtype=np.int32)
    for bc in bcs:
        not_dirichlet[bc.dof_indices()[0]] = 0
    idx_set = np.flatnonzero(not_dirichlet).astype(np.int32)
    idx_set_row = idx_set[idx_set<num_dofs_local]
    idx_set_col = idx_set[idx_set<num_dofs_local]
    isx_row = PETSc.IS(A.getComm()).createGeneral(idx_set_row)
    isx_col = PETSc.IS(A.getComm()).createGeneral(idx_set_col)
    lgm_row = A.getLGMap()[0].applyIS(isx_row)
    lgm_col = A.getLGMap()[1].applyIS(isx_col)
    A_sub = A.createSubMatrix(lgm_row, lgm_col)
    A_sub.assemble()
    return A_sub, (idx_set_row, idx_set_col)
GEO_FILE = PART + ".geo"
MSH_FILE = PART + ".msh"
# create mesh
try:
except Exception:
    quit()
# mesh import
try:
    from dolfinx.io import gmshio
except ImportError:
    from dolfinx.io import  gmsh as gmshio
    mesh_data = gmshio.read_from_msh(PART + ".msh", MPI.COMM_WORLD, 0, gdim=3)
    mesh = mesh_data.mesh
    cell_tags = mesh_data.cell_tags
    facet_tags = mesh_data.facet_tags
deg = 2
# Lame parameters
# Strain and stress
    return sym(grad(u))
def sigma(u):
# matrix assemblys
K.assemble()
M.assemble()
K_sub, (idx_set_row, idx_set_row) = extract_sub_matrix(K, V, [bc])
M_sub, _ = extract_sub_matrix(M, V, [bc])
# setup eigensolver
st.setShift(0.1)
st.setFromOptions()
solver.setST(st)
solver.setOperators(K_sub, M_sub)
# solve the problem
solver.solve()
xr, xi = K_sub.createVecs()
eig_vector = []
eig_freq = []
d = Function(V)
if nconv > 0:
        eig_freq.append(fn)
        d.x.array[idx_set_row] = vect
        with dolfinx.io.VTXWriter(d.function_space.mesh.comm, f"EigenVector{i}.bp", [d]) as bp:
            bp.write(0.0)
which would yield:
Mode 0: 4.137863516946098 Hz
Mode 1: 25.930998859980065 Hz
Mode 2: 41.14547192302046 Hz
Mode 3: 72.63890229130486 Hz
Mode 4: 142.46413512919722 Hz
Mode 5: 152.11218623471086 Hz
Mode 6: 235.7921718294653 Hz
Mode 7: 254.833591000687 Hz
Mode 8: 352.78470736837915 Hz
I’m not an expert in modal analysis, maybe @jackhale or @michalhabera can comment on anything obviously wrong?
