I am trying use the SubMesh function on a 3D hexahedral mesh, but I get the following error: Unable to order hexahedron cell. *** Reason: Cell is not orderable.
Does anyone know a workaround for this error? I know SubMesh works for tetrahedral meshes but I have some other functions in my code which relies on using a hexmesh which is why I am trying to debug this.
MWE:
#Define geometry
L = 10; W = L; H = 5
Nx = 30; Ny = Nx; Nz = 15
mesh = BoxMesh.create(MPI.comm_world,[Point(0, 0, 0), Point(L, H, W)],[Nx, Ny, Nz],CellType.Type.hexahedron)
#Select subdomain
class SUBDOMAIN(SubDomain):
return (((1-0.1)*H) - x[1] >= -1e-16 and ((0.1)*H) - x[1] <= -1e-16)
OptDom = OptimizationDomain()
domains = MeshFunction('size_t', mesh,3)
domains.set_all(0)
OptDom.mark(domains, 1)
#Fails here
OptMesh = SubMesh(mesh, domains, 1)
I have tried to create the mesh in GMSH and split the domain, however I can’t seem to import hexahedral meshes into FEniCS.
I am using DOLFIN version 2019.1.0 on MacOS 10.15
Thanks in advance,
Kiri
