Summary of mesh information
I apologise for asking what is probably an FAQ, but here goes:
In my readings on fenicsx, including this forum, I have seen a one-line command that prints a summary of a mesh. That is, it produces a list containing the number of nodes, the number of triangles, tets, quads, hexas, as well as other summary information.
My problem is that I cannot remember the command and nor can I find it anywhere.
If someone could point this out to me, I would be most grateful.
Thank you very much,
Peter.
Within DOLFINx itself, there is no such command. You can get the number of cells, and the cell_type with:
print(mesh.topology.index_map(mesh.topology.dim).size_global, mesh.topology.cell_type)
Getting information about sub entities, such as facets (triangles in 2D), you change the input to index_map.
Getting the number of nodes in the mesh,
print(mesh.geometry.index_map().size_global)
Thanks for that Jorgen,
I think I must have got confused with the poly_data command in pyvista or something similar.
Regards,
Peter.
