Symbolic form of derivated stiffness matrix
Hi all,
given is the nonlinear poisson problem
\begin{align*} -\mathrm{div}{(q(x) \nabla u(x))} &= f(x), \quad x \in D = (0,1)^2 \\ u(x) &= 0, \quad x \in \partial D \end{align*}
Let’s use the diffusion coefficient q(x) = 1.0 + r_1 \cdot \sin{(\pi x_1)} + r_2 \cdot \sin{(\pi x_2)} as an example.
The weak formulation is given by
a(u, v) := \int_{D} q \nabla u \nabla v \, \mathrm{d}x = \int_{D} f v \, \mathrm{d}x =: L(v), \quad \forall v \in \hat{V}
I’d like to get the symbolic form of \nabla_r A = (\frac{\partial A}{\partial r_1}, \frac{\partial A}{\partial r_2}) as a python function of r_1 and r_2. Here A denotes the assembled stiffness matrix with A_{ij} = a(\phi_i, \phi_j) for the bilinear form a.
Here’s what I tried so far:
import fenics
def evaluate_grad_A(r1, r2):
	# rhs of the PDE
	f = fenics.Expression(rhs_string, degree=2)
	# Homogenous Dirichlet Boundary, i.e. u = u_D = 0 on the boundary
	u_D = fenics.Constant(0.0)
	bc = fenics.DirichletBC(V, u_D, lambda x, on_boundary: on_boundary)
	u = fenics.TrialFunction(V)
	v = fenics.TestFunction(V)
	dot, grad, dx = fenics.dot, fenics.grad, fenics.dx
	sin, cos, pi = fenics.sin, fenics.cos, fenics.pi
	x = fenics.SpatialCoordinate(mesh)
	r = fenics.Constant((r1, r2))
	q = fenics.Constant(1.0) + r[0] * sin(pi*x[0]) + r[1] * sin(pi*x[1])
	# Bilinear form
	a = q * dot(grad(u), grad(v)) * dx
	# define r as variable for the derivative
	w = fenics.variable(r)
	dF = fenics.diff(a, w)
	L = f*v * fenics.dx
	u = fenics.Function(V)
	# Assemble
	A, b = fenics.assemble_system(A_form = dF, b_form = L, bcs=bc)
	return A.array()
if __name__ == '__main__':
	fenics.parameters["reorder_dofs_serial"] = False # Disable reordering
	rhs_string = "100*(sin(2*pi*x[1])-sin(2*pi*x[0]))"
	mesh_nx, mesh_ny = 3, 3
	mesh = fenics.UnitSquareMesh(mesh_nx, mesh_ny)
	V = fenics.FunctionSpace(mesh, "P", 1)
Unfortunately, it isn’t working:
In [28]: evaluate_grad_A(0.0, 0.0)
<ipython-input-28-7872e1f48688> in <module>
----> 1 evaluate_grad_A(0.0, 0.0)
<ipython-input-15-88778f7be973> in evaluate_grad_A(r1, r2)
     33
     34         # Assemble
---> 35         A, b = fenics.assemble_system(dF, L, bc)
     36         return A.array()
     37
/usr/lib/petsc/lib/python3/dist-packages/dolfin/fem/assembling.py in assemble_system(A_form, b_form, bcs, x0, form_compiler_parameters, add_values, finalize_tensor, keep_diagonal, A_tensor, b_tensor, backend)
    428         assembler.assemble(A_tensor, b_tensor, x0)
    429     else:
--> 430         assembler.assemble(A_tensor, b_tensor)
    431
    432     return A_tensor, b_tensor
RuntimeError:
*** Error:   Unable to successfully call PETSc function 'MatSetValuesLocal'.
*** Reason:  PETSc error code is: 63 (Argument out of range).
*** Where:   This error was encountered inside /build/dolfin-cZGj9S/dolfin-2019.2.0~git20200629.946dbd3/dolfin/la/PETScMatrix.cpp.
*** Process: 0
*** Git changeset:  unknown
Am I missing something? In case you need further information, please let me know. Any help is really appreciated!
Best,
Johnny
Note that your code does not run, and requires some modification to be executed. How about the following:
import fenics
# rhs of the PDE
r1,r2= fenics.Constant(0),fenics.Constant(0)
q = fenics.Constant(1.0) + r1 * sin(pi*x[0]) + r2 * sin(pi*x[1])
# Bilinear form
dF1 = fenics.diff(a, r1)
dF2 = fenics.diff(a, r2)
L = f*v * fenics.dx
dF = dF1+dF2
# Assemble
