Not sure how to fix how to fix the error in my code. I am getting a syntax error in the f expression (line 61) any help would be much appreciated.
C0_K = 273.15
T0 = 305.0
T_cool = C0_K
# K
T_air = 300.0
# W/m^3
q0 = 15
# W/m/K
k_Al = 205.0
# W/ m^2 /K
h_air = 12.12
# m
#L=16
#xmax=12
#ymax=12
#wf=0.01
L =0.15
R_radius=0.06
#ymax = 0.06
wf=0.01
#ring thickness (m)
wz = .02
#space between rings (m)
g = .02
#Findings number of rings
N_value = (L - g) / (g + wz)
N = round(N_value)
Znmin = ((N-1)*(g+wz) + g)
Znmax = (N*(g + wz))
#Making a cylindrical geometry 6 cm radius and 15 cm height in S.I
c1 = Cylinder(Point(0.0,0.0,0.0),Point(0.0,0.0,L),R_radius,R_radius)
geometry = c1
mesh = generate_mesh(geometry, 50)
# Define Dirichlet boundary (x = 0 or x = 1)
def boundary(x):
return x[2] < DOLFIN_EPS
# Define boundary condition
uC = Constant(T_cool)
bc = DirichletBC(V, uC, boundary)
#u0 = project(Constant(T0),V)
#UPDATED EXPRESSION
f = Expression("sqrt(pow(x[0],2) + pow(x[1],2)) > R && sqrt(pow(x[0],2) + pow(x[1],2)) < R + w ? && ((Nv-1)*(gz+w_z) + gz) ? && (Nv*(gz + w_z)) ? && (pi*(pow(R + w, 2) - pow(R,2))*q_0*L1)/2 / k: 0.0 ", w=wf, R=R_radius, L1=L, q_0 = q0, k=k_Al, Nv = N, gz = g, w_z = wz, degree=2)
#f = Expression("sqrt(pow(x[0],2) + pow(x[1],2)) > R && sqrt(pow(x[0],2) + pow(x[1],2)) < R + w ? && ZNmin && ZNmax ? && (pi*(pow(R + w, 2) - pow(R,2))*q_0*L1)/2 / k: 0.0 ", w=wf, R=R_radius, L1=L, q_0 = q0, k=k_Al, ZNmin = Znmin, ZNmax = Znmax, degree=2)
g = Expression("h * (t0 - ta)", k=k_Al, tc= T_cool, h=h_air, t0=T0, ta=T_air, degree=2)
a = inner(grad(u), grad(v))*dx
L = f*v*dx + g*v*ds
# Compute solution
solve(a == L, u, bc)
nsteps=1
for i in range(nsteps):
u1 = u.copy()
g1 = Expression(" h * (uu - ta)", uu=u1,k=k_Al, tc= T_cool,h=h_air, t0=T0, ta=T_air, degree=2)
# Save solution in VTK format
file = File("neumann_poisson.pvd")
file << u
# Plot solution
#import matplotlib.pyplot as plt
#plot(u)
#plt.show()
