I am working on a 1D problem embedded in 3D space.
The problem requires taking the derivative of a function in the direction of the mesh. I have an inelgant solution by projecting the 3D derivative (although I’m unsure how this is defined as mesh.topology.dim == 1) along the direction of the mesh, but this seems to be quite inelegant and potentially inaccurate.
Is there a better way of doing this? I understand that the integral equivalent of this problem can be solved neatly using ufl.Measure(). Is there a similarly neat solution for differentiation?
MWE:
# %% Imports
from dolfinx import mesh
from dolfinx import fem
from dolfinx import io
import ufl.constant
# Seems to work but is not an elegant solution for a mesh which is topologically 1D
def build_mesh():
"""create a 1D mesh that lives in 3D space"""
gmsh.option.setNumber('General.Verbosity', 1)
pts = []
lines = []
meshSize = 0.1
pts.append(gmsh.model.geo.addPoint(0., 0., 0., meshSize=meshSize, tag=1))
pts.append(gmsh.model.geo.addPoint(1., 1., 0., meshSize=meshSize, tag=2))
lines.append(gmsh.model.geo.addLine(1, 2))
gmsh.model.addPhysicalGroup(dim=1, tags = lines)
gmsh.model.geo.synchronize()
gmsh.model.mesh.generate(1)
(msh, _, _) = io.gmshio.model_to_mesh(gmsh.model, comm=MPI.COMM_WORLD, rank=0)
gmsh.finalize()
return msh # returns a mesh with cells along the vector [1, 1, 0]
msh = build_mesh() # create 1D mesh
print("mesh topological dimension = ", msh.topology.dim, " mesh geometric dimension = ", msh.geometry.dim)
V = fem.functionspace(msh, ("DG", 1)) # create 1D functionspace
U = fem.Function(V)
U.interpolate(lambda x: x[0] + x[1]) # set initial condition
l = fem.Function(V)
l.interpolate(lambda x: x[0] + x[1] + x[2]) # set mesh vertex position function
# ufl.grad(l) seems to return l.dx(0) + l.dx(1) + l.dx(2) despite the 1d topological dim
l_hat = ufl.grad(l)/ ufl.sqrt(ufl.dot(ufl.grad(l), ufl.grad(l))) #create normalised mesh direction vector
u_trial = ufl.TrialFunction(V)
v_test = ufl.TestFunction(V)
dx = ufl.Measure("dx", domain=msh)
a_expr = ufl.inner(u_trial, v_test)*dx
L_expr = ufl.inner(ufl.dot(ufl.grad(U), l_hat), v_test)*dx #the variational form of the projection of grad(U) in the mesh direction. e.g. dUdl
problem = LinearProblem(a_expr, L_expr)
dUdl = problem.solve()
dUdl = dUdl.x.array
assert np.allclose(dUdl, np.sqrt(2)), "test_failed"
print("test passed")
