Taking Derivatives
Hello everyone,
I am solving a Poisson equation, and that works well, but I also want to take some partial derivatives from the variational form. I am encountering multiple errors and would really appreciate some help. I am taking two derivatives one with respect to K and one with respect to G.
  1. When I use dK = TrialFunction I get
NotImplementedError: Cannot take length of non-vector expression.
It seems to work if I use dK = Function(V), I do not understand why? Similarly for G.
  1. I can assemble the derivative with respect to K but not with respect to G. When I try to assemble with respect to G I get the following error
ufl.algorithms.check_arities.ArityMismatch: Integrand arguments (Argument(FunctionSpace(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), FiniteElement('Lagrange', triangle, 1)), 0, None),) differ from form arguments (Argument(FunctionSpace(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), FiniteElement('Lagrange', triangle, 1)), 0, None), Argument(FunctionSpace(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), FiniteElement('Lagrange', triangle, 1)), 1, None)).
Is that because G is on the boundary (ds)?
Thank you very much for the help in advance!
def solve_steady_state_heat(V,mesh,boundary_markers, K, G):
    bmesh = dl.BoundaryMesh(mesh, "exterior", True)
    bdim  = bmesh.topology().dim()
    bot_top_mesh = bot_mesh(mesh,boundary_markers,bmesh,bdim)
    boundary_mesh = bmesh #for ease going from 2D to actual mesh
    submesh_bottom = bot_top_mesh[0]
    submesh_top = bot_top_mesh[1]
    # boundary measure and normal vector
    # ds(1) --> bottom, ds(2) --> top
    ds = dl.Measure("ds", domain=mesh, subdomain_data=boundary_markers)
    # define Trial and Test Functions
    u_trial = dl.TrialFunction(V)
    u_test = dl.TestFunction(V)
    # initialize input functions
    f = dl.Constant(0.0)
    u0 = dl.Constant(253.0)
    bmesh_markers = dl.MeshFunction('size_t', bmesh, bdim)
    bmesh_markers.set_all(0)
    # 1 -- bottom
    # 2 -- top
    for i, facet in enumerate(dl.entities(bmesh, bdim)):
        p_meshentity = bmesh.entity_map(bdim)[i]
        p_boundarynumber = boundary_markers.array()[p_meshentity]
        bmesh_markers.array()[i] = p_boundarynumber
    bottom_submesh = dl.SubMesh(bmesh, bmesh_markers, 1)
    top_submesh = dl.SubMesh(bmesh, bmesh_markers, 1)
    bc = dl.DirichletBC(V, u0, boundary_markers, 2)
    def a(K,G,u_trial,u_test,f):
        return dl.inner(ufl.exp(K) * dl.grad(u_trial), dl.grad(u_test)) * dl.dx - f * u_test * dl.dx - G*u_test*ds(1)
    res_form = steady_state_heat_varf(Kappa,G,u_trial,u_test,f)
#    dK = dl.TestFunction(V) <-- when. I use I get the error
#   dG = dl.TestFunction(V)
    dK = dl.Function(V) #<--- Question 1) Why does this work? I thought we should use            TestFunction
    dG = dl.Function(V)
    theta_kappa_form = dl.derivative( res_form, K,dK)
    theta_kappa = dl.assemble(theta_kappa_form)
    theta_G_form = dl.derivative( res_form, G,dG)
    theta_G = dl.assemble(theta_G_form)
    A_form = ufl.lhs(res_form)
    b_form = ufl.rhs(res_form)
    A, b = dl.assemble_system(A_form, b_form, bcs=bc)
    theta = dl.Function(V)
    dl.solve(A, theta.vector(), b)
    return theta
Please make sure that the code you supply is a standalone code, that when copy pasted by other can reproduce your error message.
Please also remove all unused variables from the code.
Thank you for your feedback Prof. Dokken,
I would directly edit the post to improve it, I cannot find an edit option. I modified one of the basic demos to give me the same errors.
import dolfin as dl
mesh = UnitSquareMesh(32, 32)
# Define Dirichlet boundary (x = 0 or x = 1)
def boundary(x):
    return x[0] < DOLFIN_EPS or x[0] > 1.0 - DOLFIN_EPS
# Define boundary condition
u0 = Constant(0.0)
bc = DirichletBC(V, u0, boundary)
f = Expression("10*exp(-(pow(x[0] - 0.5, 2) + pow(x[1] - 0.5, 2)) / 0.02)",element=V.ufl_element())
g = Expression("sin(5*x[0])",element=V.ufl_element())
a = inner(grad(u), grad(v))*dx
L = f*v*dx + g*v*ds
# Compute solution
K = Function(V)
solve(a == L, K, bc)
def aa(u,v,f,g):
    return dl.inner(ufl.exp(K)*dl.grad(u), dl.grad(v))*dl.dx - f*v*dl.dx + g*v*ds
res_form = aa(u,v,f,g)
#dK = dl.TestFunction(V) #<--- does not work, it seems we have to use Function, but I guess K is a function as well
dK = dl.Function(V)
aa_K = dl.derivative( res_form, K,dK)
Ak = dl.assemble(aa_K)
#dg = dl.TestFunction(V) #Similar issue
dg = dl.Function(V)
aa_g = dl.derivative( res_form, g,dg)
Ag = dl.assemble(aa_g)
In your variational form, you already use a TrialFunction (u) and a TestFunction (v). You cannot have two test functions multiplied by each other in the same form, and therefore the derivative command does not work.
I understand so we have multiple Trial and Test functions. Then what is the proper way to take the derivative of the weak form aa with respect to g?
In FEniCS there is a concept of scalar, vector and tensors (of order 2).
i.e.
Consider a functional, \int_\Omega c u^2 \mathrm{d}x where u and c is a function.
If we want to compute the derivative (Gateaux derivative, Integrating a functional, followed by differentiation - #2 by kamensky)
we call
mesh = UnitSquareMesh(10, 10)
J = c * inner(u, u) * dx
dJdu = derivative(J, u)
dJdu_v = derivative(J, u, v)
assert(dJdu == dJdu_v)
assembling dJdu will assemble into a vector:
print(type(assemble(dJdu)))
<class 'dolfin.cpp.la.Vector'>
If you again differentiate dJdu, which is equal to \int_\Omega2 c u\cdot v ~\mathrm{d} x you obtain \int_\Omega 2c \cdot du \cdot v ~\mathrm{d} x which assembles into a matrix:
dJdudv = derivative(dJdu, u)
du = TrialFunction(V)
dJdu_vdu = derivative(dJdu_v, u, du)
assert(dJdudv == dJdu_vdu)
print(type(assemble(dJdudv)))
<class 'dolfin.cpp.la.Matrix'>
In dolfin, we do not have a concept of tensors with higher order than two, and thus you cannot differentiate this form with respect to a TrialFunction or TestFunction, as it would increase the dimensionality of the object.
However, you can differentiate it with respect to a Function, i.e derivative(dJdudv, c, Function(V)) will give you a resulting matrix, and you can create the tensor by looping over all dofs, inserting a one for each dof and zero for all the others if you want to emulate differentiating with respect to a trial or test function.
