Temperature dependent material data from file
for my time dependent heat convection-diffusion equation I have some material data from files: density, conductivity and specific heat. All depend on the current local temperature, i.e. local solution of the PDE. I tried the following, that works well with constant material data (as Constant() or Expression()):
# material data from file, int(temperature) == index
cpX    = np.genfromtxt('analyse/cpX.ana')[:,1]
rhoX   = np.genfromtxt('analyse/densityX.ana')[:,1]
lmbdaX = np.genfromtxt('analyse/conductX.ana')[:,1]
class userMaterial(UserExpression):
    def __init__(self, temp, valArray, **kwargs):
        super().__init__(kwargs)
        self.temp     = temp
        self.valArray = valArray
    def eval(self, value, x):
        intT     = max(1,min(int(self.temp(x)),1600))
        value[0] = self.valArray[intT]
    def value_shape(self):
        return ()
U = Function(V)
U_data = np.array(U.vector())*0+100
U.vector().set_local(U_data)
lambdaU = userMaterial(temp=U,valArray=lmbdaX,degree=0)
rhoU    = userMaterial(temp=U,valArray=rhoX,degree=0)
cpU     = userMaterial(temp=U,valArray=cpX,degree=0)
E_thd = lambdaU/(rhoU*cpU) # thermal diffusivity
E_rcp = 1.0/(rhoU*cpU)     # 1 / rho * cp
for i in bcond:
    if 'Dirichlet' in bcond[i]:
        bc = DirichletBC(V,bcond[i]['Dirichlet'],boundary_markers,i)
        bcs.append(bc)
    elif 'Neumann' in bcond[i]:
        if bcond[i]['Neumann'] != 0:
            g = bcond[i]['Neumann']
            integrals_N.append(E_dt*E_rcp*g*v*ds(i))
    elif 'Robin' in bcond[i]:
        r,s = bcond[i]['Robin']
        integrals_R_a.append(E_dt*E_rcp*r*u*v*ds(i))
        integrals_R_L.append(E_dt*E_rcp*r*s*v*ds(i))
# PDE
#  rho*cp*grad(T,t)+rho*cp*w*grad(T,x)=div(lambda*grad(T,x),x)
# weak problem formulation
F    =   u*v*dx + E_dt*E_thd*dot(grad(u),grad(v))*dx - u_n*v*dx \
       + E_dt*inner(E_w,grad(u))*v*dx \
       + sum(integrals_R_a) + sum(integrals_N) - sum(integrals_R_L)
a, L = lhs(F), rhs(F)
t = 0
while t < tFinal:
    # Update current time
    print(t,"s /",tFinal,'s')
    # Compute solution
    solve(a == L, U, bcs)
    # Save to file and plot solution
    vtkfile << (U, t)
    # plot(u)
    # Update previous solution
    u_n.assign(U)
    # update material data
    lambdaU.temp = U
    rhoU.temp    = U
    cpU.temp     = U
Unfortunately, this doesn’t work and is also extremely slow.
How can measured, temperature dependend table data be applied to the PDE?
Write it into a function once, save it as a checkpoint using XDMFFile.write_checkpoint such that it can be reloaded in parallel with basically no cost using XDMFFile.read_checkpoint for later experiments.
Wow, this sounds as you know what you do. But I don’t understand much, since I’m new to FEniCS :frowning:
Could you add some pseudo code?
What I thought meanwhile is to use a MeshFunction and update it only on the vertices to avoid the expencive call to temp(x). Would this be possible?
See for instance: Read mesh from XDMF file (write_checkpoint) - #3 by dokken
Hmmm … since the material data change after each time step, I don’t think that storing the data once is sufficient. I just learn to understand how Function and UserExpression operates. I now switched over to:
lambdaU = Function(V)
rhoU    = Function(V)
cpiU    = Function(V)
lambdaU.vector()[:]  = updateMatdata(lambdaX,U)
rhoU.vector()[:]        = updateMatdata(rhoX,U)
cpiU.vector()[:]        = updateMatdata(cpiX,U)
which avoids calling a function at every time step and I think this is at the moment ok for me. updateMatdata ist more or less comparable to class userMaterial(UserExpression). I hope I use the Function statement the right way.
