Dear all,
Is there any method to apply a abs() to the integration?
For example, in FEniCS,
abs(1)*dx(mesh) is valid
while abs(1*dx(mesh)) would be invalid, and it would tell that TypeError: bad operand type for abs(): 'Form'.
Thanks a lot!
Dear all,
Thanks a lot!
Consider the following, using numpy.abs:
mesh = UnitSquareMesh(10, 10)
c = Constant(1)
a = c*dx(mesh)
print(-assemble(a), np.abs(-assemble(a)))
returning
-1.0000000000000007 1.0
Dear Dokken,
Thanks for your reply.
The assemble() do work when we try to obtain a value.
However, in my case I tried to write it in the form (for solving).
For instance,
Pi = (psi)*dx + (1/2)*(pen)*ppos( dot(position,position)*ds(2) - dot(position,position)*ds(1) )
F = derivative(Pi, u, u_test)
J = derivative(F, u, u_tr)
fe.solve(F==0, u, bcs, J=J)
where
def ppos(x):
return (x+abs(x))/2.
and the result would tell:
So, maybe FEniCS just simply cannot implement these kind of code, and should start trying different approaches (?)
So are you trying to assemble \vert \int g(position) ~\mathrm{d}s\vert?
Are you sure you do not want \int \vert g(position)\vert\mathrm{d}s?
If you really want the first thing, you need to write out F and J explicitly, as dolfin does not know how to differentiate (or take the absolute value of the whole integral, only the integrand)
Yes, I’m trying to implement the first equation you mentioned.
Thanks for your information and advice, I’ll try to carry out the F and J form explicitly.
