In this tutorial, we learn that if we are interested in finding the error of a numerical solution u_h to a given problem with exact solution u_{ex}, we should not compute directly the integral
\displaystyle \epsilon := \int_\Omega | u_h - u_{ex} |^2
which corresponds to
V = FunctionSpace(mesh, ("Lagrange", degree))
error = form((uh - u_ex)**2 * ufl.dx)
E = np.sqrt(comm.allreduce(assemble_scalar(error), MPI.SUM))
Question 1: I assume, that form() is the function that calls the quadrature function in the background, which finds an approximation (depending on the quadrature rule and the degree of u_h and u_{ex}) to the integral above, right?
The reason is that after expanding the square root in the integral, the compute tries to integrate
\displaystyle u_{ex}^2 + u_h^2 - 2u_{ex}u_h
where the terms u_{ex}^2 + u_h^2 and 2u_{ex}u_h are of a similar size, if u_{ex} and u_h are of similar size (which is the case when the error is small) - leading to round-off errors.
Instead of that we should interpolate both u_h and u_{ex} into a higher order space of polynomials.
W = FunctionSpace(mesh, (family, degree + degree_raise))
u_W = Function(W)
u_W.interpolate(uh)
u_ex_W = Function(W)
u_ex_W.interpolate(u_ex)
and then we subtract the nodal values (the expansion coefficients of the FEM functions) of the two functions and compute the error as before:
e_W = Function(W)
e_W.x.array[:] = u_W.x.array - u_ex_W.x.array
error = form(ufl.inner(e_W, e_W) * ufl.dx)
Question 2: why do we subtract the arrays of nodal values instead of subtracting the Function objects inside the ufl.inner() like we did for the naive error computation?
Question 3: Why should this procedure give a more accurate error? Morally speaking, we are loosing information by interpolating the exact solution in a polynomial space, right? I tried to work it out, but I can not see why this approach avoids round-off errors.
