Three dimensional time dependent heat equation with constant flux boundary
Hi all,
I am sure I am making a silly mistake with my time-stepped heat equation problem, but I cannot for the life of me find the error. I am a bit of newbie with using time stepping in Fenics.
I am solving the usual 3D heat equation in time within a cylinder of conductivity K with no internal sources
\frac{\partial T}{\partial t} - \nabla\cdot K\nabla T = 0,
where I have a constant flux source on the top (Neumann boundary) and a constant temperature on the bottom (Dirichlet boundary):
\begin{array}{ll} K\frac{\partial T}{\partial n} = 10 & \textrm{on top} \\ T = 0 & \textrm{on bottom} \end{array}
The variational form for implicit Euler is
a = \int\limits _\Omega(\Delta t K \nabla v\cdot\nabla T^{n+1} + v\cdot T^{n+1} - v\cdot T^n)dV - \Delta t \int\limits_{\partial\Omega_{top}} v \cdot \Phi ds
where \Phi is a fixed flux value, v is the test function, \Delta t is the time increment and n is the time step number.
The code runs without error. The problem is that the solution is always zero. The solution does not advance with the time step.
import os, sys, traceback
tol = 1.0e-8
K = Constant((1.0))
# time stepping params
dt = 0.1
NumSteps = 2
C1 = Cylinder(dolfin.Point(0,0,0), dolfin.Point(0, 0, 2), 1.0, 1.0)
mesh = generate_mesh(C1, 45)
class Free(SubDomain):
        return on_boundary
class FixedTemp(SubDomain):
        return on_boundary and near(x[2], 0.0, tol)
class HeatFlux(SubDomain):
        return on_boundary and near(x[2], 2.0, tol)
info(mesh)
# Output mesh for inspection
File("CylMesh.pvd").write(mesh)
# Mark boundaries
sub_domains = MeshFunction("size_t", mesh, mesh.topology().dim() - 1)
sub_domains.set_all(3)
FREE = Free()
FREE.mark(sub_domains, 0)
FIXEDTEMP = FixedTemp()
FIXEDTEMP.mark(sub_domains, 1)
HEATFLUX = HeatFlux()
HEATFLUX.mark(sub_domains,2)
File("BoxSubDomains.pvd").write(sub_domains)
#Input heat flux
Qs = Expression(('10.0'), degree=0)
# Set up function spaces
cell = tetrahedron
ele = FiniteElement('Lagrange', cell, 1)
V = FunctionSpace(mesh, ele)
un = Function(V)
u1 = Function(V)
#Initial condition
g = Expression('0.0', degree = 0)
pp0 = interpolate(g, V)
un.assign(pp0)
u1.assign(pp0)
#Boundary condition dictionary
boundary_conditions = {0: {'FREE' : 0.0},
                       1: {'FIXEDTEMP': 0.0},
                       2: {'HEATFLUX': Qs}}
#Build boundary conditions
bcs = []
integrals_source = []
# Fixed temp to zero on edges
for i in boundary_conditions:
    if 'FIXEDTEMP' in boundary_conditions[i]:
        bcs.append(DirichletBC(V, Constant((0.0)), sub_domains, i))
# Build constant power heat source on surface
    if 'HEATFLUX' in boundary_conditions[i]:
        Q = boundary_conditions[i]['HEATFLUX']
        bb = v * Q * ds(i)
        integrals_source.append(bb)
a = (dt * K * inner(grad(v), grad(u)) + v * u) * dx
L = dt * sum(integrals_source) + v * un * dx
vdim = u1.vector().size()
print ('Solution vector size = ',vdim)
#A, b = assemble_system(a, L, bcs)
#solver = PETScLUSolver("mumps")
#solver.parameters['symmetric'] = True
fpp = File('Temp.pvd')
# Do time stepping
t = 0
for nn in range(NumSteps):
    #Solve
    #solver.solve(A, u1.vector(), b)
    solve(a == L, u1, bcs, solver_parameters = {'linear_solver' : 'mumps'})
    #Update solution
    un.assign(u1)
    fpp << (u1, t)
sys.exit(0)
Your measure has not been defined with subdomain data, thus this integral is always equal to zero.
If you add:
ds = Measure("ds", subdomain_data=sub_domains)
before the for-loop, you get a non-zero result
Yep! That fixed it. I knew a second pair of eyes would spot the error in no time. Thanks heaps!
