Time dependent dirichlet conditions at a single point
Hi, I am trying to implement time dependent Dirichlet boundary conditions to a single point in the middle of the side of a square bar (in this case a displacement ramping up to some arbitrary amplitude).
I followed similar threads on the topic such as this one, but I couldn’t seem to apply it to my geometry. It also feels like there is a better way to define the BC rather than using the interpolate function, since it is only at a single point. See the code below:
from dolfinx import fem, mesh, default_scalar_type, log
import dolfinx.fem.petsc
import dolfinx.nls.petsc
import time
start_time = time.time()
# Create mesh and function space
L = 1.0  # Length of the rod
nx, ny, nz = 4, 4, 20  # Number of elements in x, y, and z directions
domain = mesh.create_box(MPI.COMM_WORLD, [np.array([0, 0, 0]), np.array(
    [0.1, 0.1, L])], [nx, ny, nz], cell_type=mesh.CellType.hexahedron)
V = fem.VectorFunctionSpace(domain, ("CG", 1))
#no penetration in z dir boundary conditions
def nopen_boundary(x):
    return np.isclose(x[2], 0)
boundary_facets = mesh.locate_entities_boundary(domain, fdim, nopen_boundary)
bc = fem.dirichletbc(default_scalar_type(0), fem.locate_dofs_topological(V.sub(2), fdim, boundary_facets), V.sub(2))
#time dep boundary conditions
Amp=1e-3 #amplitude of perturbation
def point1(x):
    return np.allclose(x, [0.05,0.0,0.0])
class time_dependent_dbc1:
    def __init__(self):
        self.t = 0.0
    def eval(self, x):
        #return np.stack((np.full(x.shape[0], Amp*self.t), (np.zeros(x.shape[1])),(np.zeros(x.shape[2])) ))
        return np.array([Amp*self.t, 0.0,0.0])
V2 = V.sub(2).collapse()[0]
point1_pert = time_dependent_dbc1()
point1_pert.t = 0.
bc_fun = fem.Function(V2)
bc_fun.interpolate(point1_pert.eval)
point1_dofs = fem.locate_dofs_geometrical((V.sub(2),V2), point1)
bc1 = fem.dirichletbc(bc_fun, point1_dofs, V.sub(2))
allbcs=[bc, bc1]
# Elasticity constants
E = 1.0e6
nu = 0.3
mu = E / (2.0 * (1 + nu))
lmbda = E * nu / ((1.0 + nu) * (1.0 - 2.0 * nu))
# Time integration parameters
am = 0.2
af = 0.4
g = 0.5 + af - am
alpha_m = fem.Constant(domain, am)
alpha_f = fem.Constant(domain, af)
gamma = fem.Constant(domain, g)
beta = fem.Constant(domain, (g + 0.5)**2 / 4.0)
rho = 1.0
eta_m = 0.0
eta_k = 0.0
T = 1.0
Nsteps = 50
dt = fem.Constant(domain, T / Nsteps)
# Functions and fields
u_ = ufl.TestFunction(V)
u = fem.Function(V, name='Displacement')
u_old = fem.Function(V)
v_old = fem.Function(V)
a_old = fem.Function(V)
# External load
# B = fem.Constant(domain, PETSc.ScalarType((1.0, 0.0, 0.0))
#                  )  # Applied load in the x-direction
# Measures
dx = ufl.Measure("dx", domain=domain)
# GA method functions
def sigma(r):
    return lmbda*ufl.nabla_div(r)*ufl.Identity(len(r)) + 2*mu*ufl.sym(ufl.grad(r))
def m(u, u_):
    return rho*ufl.inner(u, u_)*dx
def k(u, u_):
    return ufl.inner(sigma(u), ufl.grad(u_))*dx
def c(u, u_):
    return eta_m*m(u, u_) + eta_k*k(u, u_)
# update variables
def update_a(u, u_old, v_old, a_old, ufl_=True):
    if ufl_:
        dt_ = dt
        beta_ = beta
        return (u-u_old-dt_*v_old)/beta_/dt_**2 - (1-2*beta_)/2/beta_*a_old
        dt_ = float(dt)
        beta_ = float(beta)
def update_v(a, u_old, v_old, a_old, ufl_=True):
    if ufl_:
        return v_old + dt*((1-gamma)*a_old + gamma*a)
        return v_old + float(dt) * ((1 - float(gamma)) * a_old + float(gamma)*a)
def update_fields(u, u_old, v_old, a_old):
    u_vec, u0_vec = u.x.array[:], u_old.x.array[:]
    v0_vec, a0_vec = v_old.x.array[:], a_old.x.array[:]
    a_vec = update_a(u_vec, u0_vec, v0_vec, a0_vec, ufl_=False)
    v_vec = update_v(a_vec, u0_vec, v0_vec, a0_vec, ufl_=False)
    v_old.x.array[:] = v_vec     #numpy.ndarray stored inside dolfinx.fem.function.Function
    a_old.x.array[:] = a_vec
    u_old.x.array[:] = u_vec
def avg(x_old, x_new, alpha):
    return alpha*x_old + (1-alpha)*x_new
a_new = update_a(u, u_old, v_old, a_old, ufl_=True)     #ufl.algebra.Sum
v_new = update_v(a_new, u_old, v_old, a_old, ufl_=True)
## Problem setup
res = m(avg(a_old, a_new, alpha_m), u_) + c(avg(v_old, v_new, alpha_f), u_) + \
    k(avg(u_old, u, alpha_f), u_) #- rho * ufl.inner(B, u_)*dx  # residual to solve
problem = fem.petsc.NonlinearProblem(res, u, bcs=allbcs) #petsc.linear problem?
## Solver setup
solver = dolfinx.nls.petsc.NewtonSolver(MPI.COMM_WORLD, problem)
solver.atol = 1e-8
solver.rtol = 1e-8
# solver options
ksp = solver.krylov_solver
opts = PETSc.Options()
ksp.setFromOptions()
# Quantities to track
times = np.linspace(0, T, Nsteps + 1)
# Create file
with XDMFFile(domain.comm, "rod_dbc0.xdmf", "w") as xdmf_file:
    xdmf_file.write_mesh(domain)
    xdmf_file.write_function(u, 0)
# Solve time to assess time spent in each component
# solve_time = 0
# Write function at each time step
for i in range(Nsteps):
    t = times[i + 1]
    print("Time = %s" % t)
    point1_pert.t=t
    # log.set_log_level(log.LogLevel.INFO)    # Convergence info
    # s = time.perf_counter()
    num_its, converged = solver.solve(u)
    # e = time.perf_counter()
    # solve_time += e-s
    # print(solve_time)
    assert converged
    # print(f"Number of interations: {num_its:d}")
    u.x.scatter_forward()
    # Update old fields with new quantities
    # Write the function to the XDMF file
    xdmf_file.write_function(u, t)
print("--- %s seconds runtime ---" % (time.time() - start_time))
Note: the code runs fine if the time dependent BCs are taken out.
Thanks!
Update, I have got the code to run without error. However now I am not actually sure it is implementing the boundary condition I would like it to (at all).
In the below code, I have two points (point1 and point2) with opposite dirichlet boundary conditions on opposite sides of the rod. I think the issue is in the definition of the time_depedent_dbc1/2 classes.
Any help would be greatly appreciated!
import time
    return np.isclose(x[2], L)
Amp=1e-6 #amplitude of perturbation
def point1(x):
    return np.logical_and(np.logical_and(np.isclose(x[2], 0.0), np.isclose(x[1], 0)), np.isclose(x[0], 0.05))
def point2(x):
    return np.logical_and(np.logical_and(np.isclose(x[2], 0.0), np.isclose(x[1], 0.1)), np.isclose(x[0], 0.05))
    def __init__(self):
        self.t = 0.0
    def eval(self, x):
class time_dependent_dbc2:
    def __init__(self):
        self.t = 0.0
    def eval(self, x):
        return np.array([-1*Amp*self.t, 0.0,0.0])
point1_pert.t = 0.
bc_fun1 = fem.Function(V2)
bc_fun1.interpolate(point1_pert.eval)
point2_pert = time_dependent_dbc2()
point2_pert.t = 0.
bc_fun2 = fem.Function(V2)
bc_fun2.interpolate(point2_pert.eval)
point1_dofs = fem.locate_dofs_geometrical(V, point1)
bc1 = fem.dirichletbc(bc_fun1, point1_dofs)
point2_dofs = fem.locate_dofs_geometrical(V, point2)
bc2 = fem.dirichletbc(bc_fun2, point2_dofs)
allbcs=[bc,bc2]
E = 200e9
nu = 0.27
am = 0.2
af = 0.4
g = 0.5 + af - am
rho = 7990
eta_m = 0.
eta_k = 0.
T = 5.0e-4
Nsteps = 100
# External load
# Measures
def sigma(r):
def m(u, u_):
def k(u, u_):
def c(u, u_):
# update variables
    if ufl_:
        dt_ = dt
        beta_ = beta
        dt_ = float(dt)
        beta_ = float(beta)
    if ufl_:
## Problem setup
## Solver setup
solver.atol = 1e-8
solver.rtol = 1e-8
# solver options
tt=0
# Create file
# solve_time = 0
    tt += float(dt)
    print("Time = %s" % tt)
    point1_pert.t=tt
    point2_pert.t=tt
    solver.atol = 1e-8
    solver.rtol = 1e-8
    # solver options
    # solve_time += e-s
    # print(solve_time)
    assert converged
    xdmf_file.write_function(u, tt)
    #Write Von Mises stress to XDMF File
    # s = sigma(u) - 1. / 3 * ufl.tr(sigma(u)) * ufl.Identity(len(u))
    # von_Mises = ufl.sqrt(3. / 2 * ufl.inner(s, s))
    # V_von_mises = fem.FunctionSpace(domain, ("DG", 0))
    # stress_expr = fem.Expression(von_Mises, V_von_mises.element.interpolation_points())
    # stresses = fem.Function(V_von_mises, name='Von Mises Stress')
    # stresses.interpolate(stress_expr)
    # xdmf_file.write_function(stresses, t)
import time
nx, ny, nz = 8, 8, 20  # Number of elements in x, y, and z directions
def point1(x):
def point2(x):
# class time_dependent_dbc1:
#     def __init__(self):
#         self.t = 0.0
#     def eval(self, x):
#         return np.array([Amp*self.t, 0.0,0.0])
# class time_dependent_dbc2:
#         self.t = 0.0
#         return np.array([-1*Amp*self.t, 0.0,0.0])
# V2 = V.sub(2).collapse()[0]
# point1_pert = time_dependent_dbc1()
# point1_pert.t = 0.
# bc_fun1 = fem.Function(V2)
# bc_fun1.interpolate(point1_pert.eval)
# point2_pert = time_dependent_dbc2()
# point2_pert.t = 0.
# bc_fun2 = fem.Function(V2)
# bc_fun2.interpolate(point2_pert.eval)
def input1(t):
    return np.array([Amp*t, 0.0,0.0], dtype=default_scalar_type)
def input2(t):
    return np.array([-1*Amp*t, 0.0,0.0], dtype=default_scalar_type)
ti=0
bc_fun1=input1(ti)
bc_fun2=input2(ti)
bc1 = fem.dirichletbc(bc_fun1, point1_dofs, V)
bc2 = fem.dirichletbc(bc_fun2, point2_dofs, V)
allbcs=[bc,bc1,bc2]
E = 200e9
nu = 0.27
am = 0.2
af = 0.4
g = 0.5 + af - am
rho = 7990
eta_m = 0.
eta_k = 0.
T = 5.0e-4
Nsteps = 100
# External load
# Measures
def sigma(r):
def m(u, u_):
def k(u, u_):
def c(u, u_):
# update variables
    if ufl_:
        dt_ = dt
        beta_ = beta
        dt_ = float(dt)
        beta_ = float(beta)
    if ufl_:
## Problem setup
## Solver setup
solver.atol = 1e-8
solver.rtol = 1e-8
# solver options
tt=0
# Create file
# solve_time = 0
    tt += float(dt)
    # point1_pert.t=tt
    # point2_pert.t=tt
    bc_fun1=input1(tt)
    bc_fun2=input2(tt)
    bc1 = fem.dirichletbc(bc_fun1, point1_dofs,V)
    bc2 = fem.dirichletbc(bc_fun2, point2_dofs,V)
    allbcs=[bc,bc1,bc2]
    solver.atol = 1e-8
    solver.rtol = 1e-8
    # solver options
    # solve_time += e-s
    # print(solve_time)
    assert converged
Closed as per user request.
