Time dependent integration of hyperelastic plate
I am trying to find out the displacement and acceleration data when a hyperelastic plate is stretched uniaxially by giving only Dirichlet boundary condition at left and right side using linear momentum balance similar to tutorial given in dolfin with topic “time dependent integration of elastodynamics equation”. But it is giving an error as mentioned below.
Please help!!!
import fenics as fe
## Defining Boundaries
def left(x, on_boundary):
    return (on_boundary and fe.near(x[0], 0.0, 1.0e-5))
def right(x, on_boundary):
    return (on_boundary and fe.near(x[0], 1.0, 1.0e-5))
# Mass density
rho = Constant(1.0)
# Generalized-alpha method parameters
alpha_m = Constant(0.2)
alpha_f = Constant(0.4)
gamma   = Constant(0.5+alpha_f-alpha_m)
beta    = Constant((gamma+0.5)**2/4.)
# # Time-stepping parameters
T       = 1.0
Nsteps  = 10
dt = Constant(T/Nsteps)
mesh = RectangleMesh(Point(0., 0.), Point(1., 1.), 40, 40)
# Define function space for displacement, velocity and acceleration
# Current (unknown) displacement
u = Function(V, name="displacement")
# Fields from previous time step (displacement, velocity, acceleration)
u_old = Function(V)
v_old = Function(V)
a_old = Function(V)
# Test and trial functions
du = TrialFunction(V)
u_ = TestFunction(V)
I = Identity(len(u))
bc_l = DirichletBC(V.sub(0), 0.0, left)
bc_r = DirichletBC(V.sub(0), 0.1, right)
bc = [bc_l,bc_r]
# Mass form
def m(u, u_):
    return rho*inner(u, u_)*dx
def P(u,I,u_):
    return inner(dWdf(u,I),grad(u_))*dx
def dWdf(u,I):
    F = I + grad(u)             # Deformation gradient
    J = det(F)
    C = F.T*F                   # Right Cauchy-Green tensor
    B = F*F.T
    I1 = tr(C) + 1              # Invariants of deformation tensors
    I2 = 0.5*((tr(C)+1)**2 - (tr(C*C)+1))
    I3  = J**2
    I1_bar = J**(-2/3)*I1
    I2_bar = J**(-4/3)*I2
    F_inv = inv(I) - (1/(1+tr(grad(u)*inv(I))))*(inv(I)*grad(u)*inv(I))
    dWdF = (J*F_inv)*((((2*(0.5))/J**(5/3))*B)-(2/(3*J))*(I1_bar*0.5)*I+(3*J-3.0)*I)
    return dWdF
def avg(x_old, x_new, alpha):
    return alpha*x_old + (1-alpha)*x_new
a_new = (du-u_old-dt*v_old)/beta/dt**2 - (1-2*beta)/2/beta*a_old
v_new = v_old + dt*((1-gamma)*a_old + gamma*a_new)
F = m(avg(a_old, a_new, alpha_m), u_) + P(avg(u_old, u, alpha_f),I,u_)
solve(F == 0, u, bc)
And I am getting this error
No Jacobian form specified for nonlinear variational problem.
Differentiating residual form F to obtain Jacobian J = F'.
  File "/Users/mohammad.anas7777gmail.com/opt/anaconda3/envs/fenicsproject/lib/python3.9/site-packages/spyder_kernels/py3compat.py", line 356, in compat_exec
    exec(code, globals, locals)
  File "/Users/mohammad.anas7777gmail.com/Downloads/untitled13.py", line 59, in <module>
  File "/Users/mohammad.anas7777gmail.com/opt/anaconda3/envs/fenicsproject/lib/python3.9/site-packages/dolfin/fem/solving.py", line 220, in solve
  File "/Users/mohammad.anas7777gmail.com/opt/anaconda3/envs/fenicsproject/lib/python3.9/site-packages/dolfin/fem/solving.py", line 260, in _solve_varproblem
    problem = NonlinearVariationalProblem(eq.lhs, u, bcs, J,
  File "/Users/mohammad.anas7777gmail.com/opt/anaconda3/envs/fenicsproject/lib/python3.9/site-packages/dolfin/fem/problem.py", line 90, in __init__
    F = Form(F, form_compiler_parameters=form_compiler_parameters)
  File "/Users/mohammad.anas7777gmail.com/opt/anaconda3/envs/fenicsproject/lib/python3.9/site-packages/dolfin/fem/form.py", line 43, in __init__
    ufc_form = ffc_jit(form, form_compiler_parameters=form_compiler_parameters,
  File "/Users/mohammad.anas7777gmail.com/opt/anaconda3/envs/fenicsproject/lib/python3.9/site-packages/dolfin/jit/jit.py", line 47, in mpi_jit
  File "/Users/mohammad.anas7777gmail.com/opt/anaconda3/envs/fenicsproject/lib/python3.9/site-packages/dolfin/jit/jit.py", line 97, in ffc_jit
  File "/Users/mohammad.anas7777gmail.com/opt/anaconda3/envs/fenicsproject/lib/python3.9/site-packages/ffc/jitcompiler.py", line 217, in jit
    module = jit_build(ufl_object, module_name, parameters)
  File "/Users/mohammad.anas7777gmail.com/opt/anaconda3/envs/fenicsproject/lib/python3.9/site-packages/ffc/jitcompiler.py", line 130, in jit_build
    module, signature = dijitso.jit(jitable=ufl_object,
  File "/Users/mohammad.anas7777gmail.com/opt/anaconda3/envs/fenicsproject/lib/python3.9/site-packages/dijitso/jit.py", line 165, in jit
    header, source, dependencies = generate(jitable, name, signature, params["generator"])
  File "/Users/mohammad.anas7777gmail.com/opt/anaconda3/envs/fenicsproject/lib/python3.9/site-packages/ffc/jitcompiler.py", line 65, in jit_generate
    code_h, code_c, dependent_ufl_objects = compile_object(ufl_object,
  File "/Users/mohammad.anas7777gmail.com/opt/anaconda3/envs/fenicsproject/lib/python3.9/site-packages/ffc/compiler.py", line 142, in compile_form
    return compile_ufl_objects(forms, "form", object_names,
  File "/Users/mohammad.anas7777gmail.com/opt/anaconda3/envs/fenicsproject/lib/python3.9/site-packages/ffc/compiler.py", line 185, in compile_ufl_objects
    analysis = analyze_ufl_objects(ufl_objects, kind, parameters)
  File "/Users/mohammad.anas7777gmail.com/opt/anaconda3/envs/fenicsproject/lib/python3.9/site-packages/ffc/analysis.py", line 89, in analyze_ufl_objects
    form_datas = tuple(_analyze_form(form, parameters)
  File "/Users/mohammad.anas7777gmail.com/opt/anaconda3/envs/fenicsproject/lib/python3.9/site-packages/ffc/analysis.py", line 89, in <genexpr>
  File "/Users/mohammad.anas7777gmail.com/opt/anaconda3/envs/fenicsproject/lib/python3.9/site-packages/ffc/analysis.py", line 169, in _analyze_form
    form_data = compute_form_data(form,
  File "/Users/mohammad.anas7777gmail.com/opt/anaconda3/envs/fenicsproject/lib/python3.9/site-packages/ufl/algorithms/compute_form_data.py", line 387, in compute_form_data
    check_form_arity(preprocessed_form, self.original_form.arguments())  # Currently testing how fast this is
  File "/Users/mohammad.anas7777gmail.com/opt/anaconda3/envs/fenicsproject/lib/python3.9/site-packages/ufl/algorithms/check_arities.py", line 152, in check_form_arity
    check_integrand_arity(itg.integrand(), arguments)
  File "/Users/mohammad.anas7777gmail.com/opt/anaconda3/envs/fenicsproject/lib/python3.9/site-packages/ufl/algorithms/check_arities.py", line 145, in check_integrand_arity
    args = map_expr_dag(rules, expr, compress=False)
  File "/Users/mohammad.anas7777gmail.com/opt/anaconda3/envs/fenicsproject/lib/python3.9/site-packages/ufl/corealg/map_dag.py", line 37, in map_expr_dag
    result, = map_expr_dags(function, [expression], compress=compress)
  File "/Users/mohammad.anas7777gmail.com/opt/anaconda3/envs/fenicsproject/lib/python3.9/site-packages/ufl/corealg/map_dag.py", line 86, in map_expr_dags
    r = handlers[v._ufl_typecode_](v, *[vcache[u] for u in v.ufl_operands])
  File "/Users/mohammad.anas7777gmail.com/opt/anaconda3/envs/fenicsproject/lib/python3.9/site-packages/ufl/algorithms/check_arities.py", line 42, in sum
    raise ArityMismatch("Adding expressions with non-matching form arguments {0} vs {1}.".format(a, b))
ArityMismatch: Adding expressions with non-matching form arguments () vs (Argument(FunctionSpace(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 6), VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2)), 1, None),).
