Hi, I have a simple time dependent equation set here:
and I’m trying to solve this equation set with reference to the mixed Poisson demo Bitbucket. Following is my MWE:
# timestep
dt = 1
# define mesh and FunctionSpace
mesh = UnitSquareMesh(32,32)
V1 = FiniteElement('CG',mesh.ufl_cell(),1)
V2 = FiniteElement('CG',mesh.ufl_cell(),1)
V = FunctionSpace(mesh,V1*V2)
# initial condition projection
w_n = Function(V)
u10,u20 = w_n.split()
u10 = project(Expression('1+x[1]+x[0]',degree=1),V.sub(0).collapse())
# Define TrialFunctions and TestFunctions
u1,u2 = TrialFunctions(V)
v1,v2 = TestFunctions(V)
a = u1*v1*dx+dt*inner(grad(u2),grad(v1))*dx+u1*v2*dx-(1+u2)**(-1.5)*v2*dx
L = u10*v1*dx
# Solve and time stepping
w=Function(V)
out1=File('mixed/u1.pvd')
out2=File('mixed/u2.pvd')
t=0
for t in range(0,40):
A = assemble(a)
b = assemble(L)
solve(A,w.vector(),b)
u1,u2 = w.split()
out1 << u1
out2 << u2
w_n.assign(w)
t += 1
When I run this MWE, an error occurs as:
ufl.algorithms.check_arities.ArityMismatch: Applying nonlinear operator Power to expression depending on form argument v_1.
So what should I do to eliminate this error?
And also, as I tried to dodge the error by simplly replacing the (1+u2)**(-1.5)*v2*dx
with u2*v2*dx
, the u1
and u2
seems can’t update. Is there something wrong in my initial condition projection or somewhere else? Thanks!
