Time series data in pyvista - XdmfReader
This suggests to me that it is entirely a pyvista problem. I just installed pyvista 0.42.3. When I run the following with python
import pyvista as pv
def plot_sol(func, min, max):
    """ Analyse 2d solution over time """
    cmap = "plasma"
    def load_time(value):
        """ Load solution at value specified using the slider """
        reader.set_active_time_value(value)
        grid = reader.read()[1]
        grid.set_active_scalars(func)
        p.add_mesh(grid, cmap=cmap, clim=[min, max], scalar_bar_args=sargs)
    # Load in data
    xdmf_file = "phi.xdmf"
    reader = pv.get_reader(xdmf_file)
    reader.set_active_time_value(0.0)
    # Create plot
    width = 0.6
    sargs = dict(width=width, height=0.1, position_x=(1-width)/2, position_y=0.01)
    p = pv.Plotter()
    p.show_bounds(xtitle="", ytitle="", ztitle="")
    p.view_xy()
    p.add_slider_widget(load_time, [0.0, 1.0], value=0.0, title="Time",
                        interaction_event="always", pointa=(0.25, 0.93),
                        pointb=(0.75, 0.93))
    p.show()
plot_sol("phi", 0.0, 1.1)
it all works fine with no errors. Is this the case with you, as well?
