How can I use Twenty-node brick element in FEniCs environment?
Hi @mohamad1365,
I’m not at all an expert, but I know that this amazing project has a complete selection of finite elements that you can use for your codes. Try to check here.
Good luck
It looks like the twenty node brick element is the same as the S2 element on femtable (@androd, you are right that femtable is amazing).
In dolfinx, these elements are not yet implemented, although the Q spaces on hexahedra are. Depending on whether or not anything is missing in FIAT/FFCx, it might not be much work to get them working. I’ll have a look next time I have a programming day.
