Unabel to create subdomain from orginal using MeshView
Dear Sir
I need to extract a subdomain(interior=1) from a domain that contains 4 subdomains. But I am facing the following problem.
thermal_mesh=MeshView.create(interior,1)
NameError: name ‘MeshView’ is not defined
    print("number of cells in thermal cells:",thermal_mesh.num_cells())
    print("number of nodes in thermal cells:",thermal_mesh.num_vertices())
    W1=FunctionSpace(thermal_mesh, "CG", 1)
As it says MeshView is not defined, what version of dolfin are you running?
I am presently using dolfin 2019.1.0. And I know meshview is working fine dolfin 2019.2.0 version. my question is what is the alternative for MeshView in dolfin 2019.1.0.
many Thanks in advance
