By running gmsh -2 on this file and then opening the resulting msh file in gmsh, you will observe that there are no volume elements in the mesh.
With the following modifications:
SetFactory("OpenCASCADE");
Point(1) = {0, -0.1, 0, 1.0};
Point(2) = {0, 1, 0, 1.0};
Point(3) = {2, 1, 0, 1.0};
Point(4) = {2, 0, 0, 1.0};
Recursive Delete {
Point{1};
Point(5) = {0, 0, 0, 1.0};
Line(1) = {2, 5};
Line(2) = {5, 4};
Line(3) = {4, 3};
Line(4) = {3, 2};
Curve Loop(1) = {4, 1, 2, 3};
Plane Surface(1) = {1};
Transfinite Surface {1} = {2, 3, 4, 5};
Transfinite Curve {1, 3} = 20 Using Progression 1;
Transfinite Curve {4, 2} = 40 Using Progression 1;
Recombine Surface {1};
Physical Curve("inlet", 5) = {1};
Physical Curve("outlet", 6) = {3};
Physical Curve("top", 7) = {4};
Physical Curve("bottom", 8) = {2};
Physical Surface(9) = {1};
you can convert your mesh with the following commands
import numpy
mesh_from_file = meshio.read("transf_gmsh.msh")
out_mesh = meshio.Mesh(points=mesh.points, cells={
cell_type: cells}, cell_data={"name_to_read": [cell_data]})
if prune_z:
out_mesh.prune_z_0()
return out_mesh
line_mesh = create_mesh(mesh_from_file, "quad", prune_z=True)
meshio.write("mesh_quad.xdmf", line_mesh)
line_mesh = create_mesh(mesh_from_file, "line", prune_z=True)
meshio.write("facet_mesh.xdmf", line_mesh)
but as I said, you should use FEniCSx if you want to work with quad meshes
