Dolfin can't successfully read the xdmf file consisted with tetra and wedge mesh
Continuing the discussion from Gmshio can't successfully read the msh file created by Gmsh:
When I exported the mesh as .xdmf using meshio, and used dolfin to read the file, it dosen’t work either when the xdmf could be opened with paraview. I tried to export only tetrahedra or wedge, and only the file contained tetraIs could be read. fenics couldn’t read the msh file that contains two and more kinds of mesh?
import matplotlib.pyplot as pt
msh = meshio.read("msh_generate.msh")
#mesh
meshio.write("mesh.xdmf", meshio.Mesh(points=msh.points, cells={"tetra": msh.cells["tetra"],"wedge": msh.cells["wedge"]}))
#boundary face
meshio.write("mf.xdmf", meshio.Mesh(points=msh.points, cells={"triangle": msh.cells["triangle"],"quad": msh.cells["quad"]},cell_data={"triangle": {"name_to_read": msh.cell_data["triangle"]["gmsh:physical"]},"quad": {"name_to_read": msh.cell_data["quad"]["gmsh:physical"]}}))
#boundary cell
meshio.write("cf.xdmf", meshio.Mesh(points=msh.points, cells={"tetra": msh.cells["tetra"],"wedge": msh.cells["wedge"]},cell_data={"tetra": {"name_to_read":msh.cell_data["tetra"]["gmsh:physical"]},"wedge": {"name_to_read":msh.cell_data["wedge"]["gmsh:physical"]}}))
mesh = Mesh()
    infile.read(mesh)
boundary_markers=MeshFunction("size_t",mesh,mvc)
#print(boundaries.value())
mvc = MeshValueCollection("size_t", mesh, 3)
with XDMFFile("cf.xdmf") as infile:
The error is as follows:
  File "meshfile.py", line 15, in <module>
    infile.read(mesh)
RuntimeError:
*** Error:   Unable to recognise cell type.
*** Reason:  Unknown value "mixed".
*** Where:   This error was encountered inside XDMFFile.cpp.
*** Process: 0
*** DOLFIN version: 2019.1.0
*** Git changeset:  2e001bd1aae8e14d758264f77382245e6eed04b0
Dolfin does not support wedge meshes or Mixed meshes.
Can other methods be used to implement the boundary layer grid over there? Neither dolfin nor dolfinx can calculate the simulation model with boundary layers?
You would have make a mesh consisting of either only tetrahedra or hexahedral elements.
There has been done some work on supporting meshes with mixed cell types, but the work is not complete
Can’t both dolfin and dolfinx recognize wedge or mixed cell types? If that’s the case, I’m really looking forward to the new version.
As @dokken said, neither of them currently supports that. There is no ETA on when this feature will land in the new version.
